Question about Panasonic Office Equipment & Supplies
Call service 3 showing dis play in control pannel
  • 37 Answers
Call Service 3 relates to the temperature of the fuser unit.(or more importantly that it is not correct!).
The only way for a "user" to cure this is to switch off and on. Otherwise it probably has failed componant of the fuser unit and would need an engineer to assess/repair.
Posted on Jun 18, 2009
What role would computer tools play in setting the timming mark of 3.7L Liberty jeep,2002 model
what great question, ROLES.
what are you doing, service,? or troubleshooting? what? new heads?
no context or just curious....???
first off , is this spark timing or cam?
my guess is spark,
and the FSM is clear there, (ever seen a FSM?)
factory service manual or look online at alldata.com
it says, there is no spark timing on DIS engines.
(there are exception on early DIS systems (i have one)
its fixed, the 2 timing sensors cam/ crank are hard fixed.
This allows the ECU to advance the timing and NEVER be wrong.
now the proof.
i log into alldata.com for you.
i click search , spark timing.
and.
"Ignition timing is controlled by the Powertrain Control Module (PCM). No adjustment is possible."
now the ROLE question, answer , ALL.
the PCM does it ALL. (software/firmware)
Mar 12, 2014 | 2002 Jeep Liberty
Prinder show in control pannel but if iam give print command then printer show offline in control pannel. i does not give printout
Turn off the printer.
Disconnect the printer and unplug it from power.Do the same with the PC.
Reconnect them after a while.
Turn the printer on and start the PC.
Make sure the usb connections are well fixed.
Now print.
Hope this helps.Thanks!
Oct 10, 2011 | HP DeskJet D1460 InkJet Printer
My J3680 keeps dis[playing "Cartridge Error:" "
Remove both cartridges, switch off then on, printer detects cartridge missing, install cartridges one by one & observe which one showing faulty, replace faulty cartridge..end..
Oct 07, 2011 | HP J3680 Officejet All In One Printer
I cannot connect to the internet
click start then go to control pannel the go to network connections right click and click dis able after wards right clickit and click enable try this!
Jan 03, 2011 | Computers & Internet
I can't see all the files on my Sansa 230 to erase them? Either in Windows explorer or Windows Media player, but you can scroll through and play them on the device?
ok
See if that your folder options is not set to (do not show hidden files and folders .
Follow these steps to check it:
1. open control pannel.
2.Double click folder options then click view
3. then scroll and locate Hidden files and folders.
4.select show hidden files and folders.
5.Also untick the hide extension for known files type:
ok
cheers
uttam
Jan 13, 2010 | SanDisk Sansa m230 MP3 Player
Print spooler not running
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
thanks.
Jul 11, 2009 | HP Office Equipment & Supplies
Dell studio- audio output device not working . solve
please try these steps..
1) Try updating to the latest drivers/BIOS as available on the Dell website.
2) Go to control panel and check dis..
Control Panel -> Sound, what do you have set as your default sound output?
3) In the device manager, what are you showing under the sound controllers?
Mar 19, 2009 | Dell Computers & Internet
Regarding audio problem
Goto device manager and check whether ur multimedia contrlooer is showing there in yellow color.Download the driver for the card and install it .It will work.
Oct 31, 2008 | Computers & Internet
Heater Core
1) disconnectnegative battery cable
2) remove coolant reservoir
3) dis-connect heater hoses from heater core and plug holes in heater core, some coolant will drain out
4) remove mounting bolts and nuts on fire wall
5) remove glove box liner and door
6) lable and dis-connectheater controls
7) dis-connectand remove computer and mounting bracket
8) move radio antenna wire
9) remove kick pannel and un-bolt lower corner of dash
10) remove screws and nuts holding the housing inside the cab
11)remove the heater housing from the vehicle
12) detatch the core retaining straps and remove the heater core
13) installation is this procedure in reverse
I hope that this fixes your problem good luck and please take the time to rate this response.
Oct 17, 2008 | Chevrolet Suburban 1500 Cars & Trucks
How to replace heater core on 89 s15
disconnect negative battery cable
dis-connect heater hoses at heater core
remove mounting screws and nuts from the heater housing in the engine compartment
remove glove box door and liner
disconnect heater controls ( be sure to lable them so you know where to put them later )
disconnect the computer ( ECM ) an mounting bracket
remove the radio antenna cable
remove the kick pannel and detech the right lower corner of the dash pannel.
pull the heater assembly to the rear for access and dis-connect the wiring harness
remove the screws and nuts retaining the heater housing inside the cab
detach the core retaining straps
and wala you got it
to install it just reverse these steps.
good luck
Jun 16, 2008 | 1988 GMC S-15
140 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
