Question about Jura Capresso CoffeeTeam Luxe 453 Coffee Maker
Open machine fix digital readout
The red backlight is so bright and the letters/numbers so dim I can't read it.
My babylock esante esi-2 digital readout is very dim. is it adjustabel and/or what part do i change to bring it back to be able to read
The problem is probably the backlight of the LCD display or the LCD display. It's hard to determine which but either repair requires opening the case of the sewing machine to access the LCD. This site, https://janomememorycraft.com/products/baby-lock-esante-esi-2-lcd-backlight-replacement-kit , has a replacement backlight and a manual that walks you through the steps. This site, http://bargainbox.com.au/babylock-esante-esi2-replacement-lcd-backlight/ , has the LCD screen.
I hope this helps.
Apr 09, 2018 | Sewing Machines
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
Apr 26, 2014 | Bose Wave Radio Am/fm Awr1-1w Remote...
System works fine, plays well etc. However, the digital readout is no longer visible. Ideas?
There is typically a dimming feature among these types of systems. There may be a button on your remote/system panel to adjust how dimmed the display through which you can adjust it. If not, then try to enter the system setup mode and adjust the brightness of the display.
OR if the digital readout is not very dim and is in fact blank then your LCD panel has failed. You should replace the panel or get a new receiver. I would start by calling the customer support line as this will surely be under the manufacturer's warranty.
please rate my solution
Jul 31, 2010 | Bose Lifestyle 25 System
Dell screen goes black , after 2 seconds but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time ,
but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time......WHAT?
Can you explain in a bit more detail please...I don't know what you mean by.........
'when low down the brightness it work good'?
But try holding down the FN key on your keyboard & tapping the 5fc1ca0.png Button that alters the brightness.
Sep 04, 2009 | Dell InspironTM 1501 Notebook
My brightness is very low. I can't see anything
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 14, 2009 | Toshiba Computers & Internet
My laptop will, once in a while (every couple months), have3 "issues" with its brightness/contrast. If I leave the brightness alone, it will turn most of the screen red. If I lighten the brightness AND the...
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 14, 2009 | Gateway M320X Notebook
Dim Dashboard read
On most vehicles you have a dimmer switch ( not talking about headlights) which you can adjust how bright or how dim the dashboard lights are because some people want them bright and others prefer dim either check your owners manual or check all around for it from drivers seat ( within drivers reach) when you find it if you can't adjust it then you want to consider replacing dash lights or switch.
Apr 01, 2009 | 2001 Audi A6
Dim screen
A New Backlight, or new bulbs for your backlight..
Jun 09, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Digital readout brightness
What is your power wired into? Are your head lights dim also? You may have a battery issue?
Feb 12, 2008 | Jensen CD-2010X CD Player
Jura Capresso CoffeeTeam Luxe 453 Coffee Maker Logo
26 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
