Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
How to change a blower wheel on a maytag bravos med6400tqo dryer
  • 142 Answers
SOURCE: Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Posted on Jun 03, 2009
SOURCE: ''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Posted on Dec 27, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Bravos dryer heats but does not blow air.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
Posted on Jan 11, 2010
SOURCE: AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Posted on Mar 18, 2010
Testimonial: "Thanks so much!"
mkh5094
  • 145 Answers
SOURCE: maytag bravos dryer belt needs to be replaced
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
Posted on May 02, 2010
My dryer says to check the lint trap
A sensor is saying ". . .airflow is blocked. . " Blockage could be the air filter or trap or ducts within the dryer or the 4" flex duct attached to the back. First, remove the 4" duct and see if there is good air flow with dryer running. If so, ream the duct all the way to the outside. If not, disassemble dryer to get to internal rigid ducting and blower. Also, make sure the blower wheel is not broken and can rotate freely.
Oct 17, 2014 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
Dryer won't stop on sensor cycle
Check for clogged or kinked vent line and then after that it could be the blower wheel. But need a model to answer more precisely
Sep 26, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Take of front of a maytag med6400tqo
if the lint filter is on top then the top always pops up,unplug the dryer,pull out the lint filter and remove the two screws in front of the filter,now there are clips one on each side of the top panel,stick a putty knife or screw driver between the front and top panel and push the clip in,get a flash light and look in between the top and front panel near the corners around an inch or two in and you'll see the clips,push in on them one at a time and lift the top,hope this helps,if you live in mass and need an appliance repair tech peter de's is a good company,781-438-9442
Jan 12, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Replace belt on a maytag med6400tqo
bCheck out a video on youtube. This is a fairly simple do it yourself, but you will need to remove the cabinet of the dryer just leaving the barrel. Remove back cover, remove lint screws. Slide belt between cabinet and barrel. Lay dryer on back and around tension pulley and motor.
Have a Maytag Bravos XL MEDB9504WO that works, but very noisy. Bought a pulley that sits on top of
Sounds like you need new drum rollers, so you need to disassemble the front of the machine and remove drum replace all drum rollers and idler pulley also check blower for damage.
Jul 31, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Replacing pulley on Blower Housing
If there is no access panel on lower right side behind machine, you will have to lift the top of the machine from the front and remove the front panel to access the inside of the machine. While there it would be a good idea to check out the drum rollers if present and drum glides for wear. Also make sure that the blower wheel is not loose on the motor shaft. All of these will cause noise issues and are common.
Jul 31, 2013 | Maytag Bravos XL High-Efficiency Electric...
Dryer has Heat but NO AIR
Many of these have a belt driven blower wheel, could be a broken belt or it came off, There was also a bulliten out on several models where the blower wheel would come loose from the drive shaft, the fix was to re attach using a medium body thread lock compound so it would not unscrew again.
Sep 25, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag bravos will turn on; totally dead, its plugged in properly and breaker is connected
Bravos dryer picture
Bravos service manual
A lot of these are malfunctioning due to the small belt and pulley that drives the blower falls off. It is recommend lock tite on the nut will fix the problem.
Sep 22, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer won't dry. Replaced old vent hose. Only had 6-7 loads go through total. Vent outside house doesn't have air (hot or otherwise) coming out.
Try removing the hose off of the back of the unit its self and start up if you don't have any air flow the blower wheel is broken, if you do have air flow at the back of the unit somewhere in the house their IS a problem
Jan 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
29 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
