Question about Konica Minolta BizHub C252
I have a Bizhub C252 with the code C3452. How do I reset the machine back to factory settings?
  • Konica Minolta Master
  • 6,161 Answers
MINE YOU THAT IF THIS PROCEDURE DOES NOT WORK DO NOT RESET GAIN YOU ARE DEALING WITH THE FUSER IT CAN CATCH ON FIRE THAT WILL RUIN A PERFECTLY GOOD DAY!!!!!!!! have tech come out replace the fuser
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Posted on Jan 10, 2016
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
taminol
  • 62 Answers
SOURCE: when I turn on the machine (bizhub c300) error
This is a fuser related code.
To reset the code, please do the following
3. Touch Trouble Reset.
4. Check to make sure that OK is displayed and the it has been reset.
Good luck
Posted on Jan 29, 2010
xeerie
  • 347 Answers
SOURCE: bizhub C252 factory reset
if you mean to initialize the machine then go to service mode, then go to system 1, from there you can initialize the machine settings to factory settings.
Posted on Feb 15, 2013
  • 1294 Answers
SOURCE: I have a Konica Minolta Bizhub c252 what is code c-5102
C-5102/5103 - Main motor failure.
Check the motor connector,the drive coupling or the mechanical control board and DC power supply unit.90% mechanical rpoblem.
Posted on Feb 26, 2013
Factory reset KM bizhub C252
Utility/counter select admin (password 1234678 or 0 x 8) default select network.
Mar 18, 2015 | Office Equipment & Supplies
How to rest a C3452 error code on a minolta C300
try a trouble reset turn the machine off hold utility/counter power machine on select trouble reset reboot machine
Aug 17, 2014 | Konica Minolta Bizhub C300 All-In-One...
I have a Konica/Minolta bizhub c252 with the c 3452 code on the panel. How do I reset the machine to factory settings?
Sir/Mam
Apr 13, 2014 | Konica Minolta bizhub C250 All-In-One...
Error C3452
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
if the code comes back replace the fuser, continue to reset can cause fires.and that would ruin a perfectly good day
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
Error c3452
Power off the machine wait ten seconds then holding the down the clear/stop button power on the machine. should clear the code if the code comes back replace the fusing unit the hot part!
Jul 23, 2013 | Minolta bizhub 200 All-In-One Printer
Bizhub C252 factory reset
Nov 20, 2012 | Konica Minolta Bizhub c203 Copier
Bizhub 200 has error code c3452
Sir/mam check the right side door that you open to remove the image unit check that the two latches that hold the door close are OK especially the rear one. Close up. To reset. On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover with the machine on use a small screw driver and gentle depress the small black switch the machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. Code will come back but now press the Utility/counter button should see button that say maintenance mode press that see trouble reset press that machine again will go thru warm up procedure will see the "." DO Nothing! Should go to "Ready to Copy" if the code comes back have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. Can catch on fire! That will ruin a perfectly good day!!!!
Jan 23, 2012 | Minolta bizhub 200 Copier
Malfunction with error code C3452
HI, If its a hardware malfunctioning then go to nearby service center of contact customer care but before that you can try to reset the device to factory settings or if it's a software isue then you can try reinstalling the drivers from google, its simple.
Jul 29, 2010 | Konica Minolta bizhub C250 All-In-One...
When I turn on the machine (bizhub c300) error code c3452 appears, within 20 secs, How do I reset this code
Good luck
Jan 21, 2010 | Konica Minolta Bizhub C300 All-In-One...
Konica Minolta BizHub C252 Logo
64 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
