Question about Hansgrohe Plumbing
How to tighten loose hot cold handle - Hansgrohe Plumbing
silly girl
  • 513 Answers
SOURCE: loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Posted on Apr 30, 2006
SOURCE: Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Posted on May 29, 2009
  • 10 Answers
SOURCE: one handle is loose-how can I tighten it
shoulb be screws under cap on handle remove and tighten that should do the trick
Posted on Aug 18, 2009
blueextc3221
  • 15935 Answers
SOURCE: The door handles are loose. I want to tighten them
Remove the door gasket - and you will find the handle screws.
CLICK HERE to see the diagram.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jan 13, 2010
SOURCE: loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Posted on Jan 19, 2010
The cold water handle is flopping around and seems to be in need of tightening but I can't figure out how to tighten it
There is a little allen screw under the handle. It is loose get a little allen wrench that fits use long end and tighten
Hope this helps Mike
Jan 30, 2016 | Plumbing
The handle on the cold water side is loose and I can't figure out how to tighten it
If the handle is round and has a disc in the middle that is either blue or has C (for cold) on it or may even be plain, then this will lift off exposing a screw that you tighten down to hold the handle firm. If it is a lever handle then there should be some form of grub screw that holds it on, but these do vary greatly depending on the make.
There are two shower handles, one to divert to the shower head and another to divert to the rain head. one of these handles has loosened and falls away from the neck.
Look for an Allen screw hole the Allen is loose or has stripped and needs to be changed out. Sometimes if they are over righted they strip on bottom, also make sure it hasn't backed out completely. Some older handled have a square piece that the handle goes over then the screw is tightened under a plastic cap tha has hot H or cold C on cover.
Aug 29, 2015 | Grohe Home
Loose single handle no brand name faucet
There is a little rubber icon Red for Hot and Blue for the cold on the front of the handle. Remove the rubber insert from the handle. There is a small allen screw that needs tighten to tighten your handle.
Mar 05, 2013 | American Standard Plumbing
Fixed leaking faucet, now handles leak at the base & the water pressure is low
No, air can't get trapped in there. I don't think you did anything wrong. It sounds like the valve or internal parts are worn more than new washers take up for. Tightening down the valve just reduced travel for valve to open fully. Can't think of a fix; where's that joe da plumber?
Nov 23, 2011 | Plumbing
HELLO THE FAUCET DRIPS AT THE HANDLE AND THE HOT AND COLD SEEM REVERSED
On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
Aug 15, 2010 | Price Pfister Universal 0X8-310A Pressure...
I have a kenmore refidgerator with loose door handle
usually there door tightening screws at the top edge and bottom of most frig doors there will be plastic caps covering the screws..
Nov 14, 2009 | Washing Machines
I have a single handle Moen kitchenfaucet. I
You turned the faucet body when you tightened faucet you need to loosen and reposition body so handle goes left and right equally and retighten while making sure faucet body does not move
Nov 12, 2009 | Moen Plumbing
How do I take a loose handle off of an American Standard Hampton faucet?
The following link is the installation instructions for your faucet.
http://www.americanstandard-us.com/assets/documents/amstd/install/Install_555.pdf
Basically, what you need to do is gently pry the cap (with the hot/cold indicator) off the top of the handle. This will expose a screw-head, that you tighten to fix the looseness or loosen to remove the handle. If it's the other part of the handle that's loose (the bit that sticks out sideways rather than the whole handle). I've attached a diagram of how that is attached.
http://www.americanstandard-us.com/assets/documents/amstd/parts/Parts_555.pdf
Sep 07, 2009 | American Standard Town Square Two Lever...
One Handle Tap has gone random and hot/cold keep moving position.
look under the cap for a screw,see if you can tighten,if no screw under the handle is a plastic piece that is attached to the faucet diverter,this may have broken or the screw has come loose.you may have to replace the handle
Jul 30, 2009 | Plumbing
Plumbing Logo
32 people viewed this question
Top Hansgrohe Plumbing Experts
GCcontractor
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
