Question about Konica Minolta bizhub C250 All-In-One Laser Printer
I have a Konica/Minolta bizhub c252 with the c 3452 code on the panel. How do I reset the machine to factory settings?
  • Konica Minolta Master
  • 6,161 Answers
Sir/Mam
MINE YOU THAT IF THIS PROCEDURE DOES NOT WORK DO NOT RESET GAIN YOU ARE DEALING WITH THE FUSER IT CAN CATCH ON FIRE THAT WILL RUIN A PERFECTLY GOOD DAY!!!!!!!! have tech come out replace the fuser
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Posted on Jan 10, 2016
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
ayamaya
  • 143 Answers
SOURCE: Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
Posted on Aug 26, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Desbloqueo del codigo 3806 en konica minolta bizhub 501
Power off the machine, ensure the sub power switch is on that is the one on the control panel, now hold down the utility/counter button and turn on main power switch, wait to see trouble reset on screen the touch get OK then power off. Wait 10 second power on. if code comes back replace the fuser unit do not reset again or the machine can catch on fire the code you are resetting is for the fuse the HOT Part, that could ruin a perfectly good day
Jun 10, 2014 | Konica Minolta bizhub 161f All-In-One...
How to reset bizhub 350 to factory settings
why to factory setting? problem with memory? code or certain problem?????
Jun 02, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C252 factory reset
if you mean to initialize the machine then go to service mode, then go to system 1, from there you can initialize the machine settings to factory settings.
Nov 20, 2012 | Konica Minolta Bizhub c203 Copier
My Konica Minolta bizhub C280 is connected on the network but when i try printing,nothing happen,no job iin the list,how can i reset the settings on factory settings or how can i solve this problem?there...
Simply uninstall the printer.Restart your PC.Now again install the printer.Use new driver instead of previous drivers.Ping confirmation from PC.Ping from Machine.If connection is okay then there is no need to reset the machine.There is network problem.
Sep 09, 2011 | Konica Minolta Bizhub C300 All-In-One...
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Dec 12, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
