Question about Car Audio & Video
Hello i need an audio speaker with 30watt& 8ohm 12cm cone can you help me?
    Problem Solver:
  • 11 Answers
RADIO SHACK!
Posted on Sep 19, 2009
The volume of my model's volume only goes up to 40...is there a way to increase the volume?
Sometimes you can connect a lower ohm speakers. However you must NOT go lower than the amp can take. For example if the amp has 8ohm as the lowest for it you can go to 8ohm speakers, if it has 16ohm speakers connected, but must connect 6ohm speakers. If the amp allows 6ohm than you can connect 6ohm speakers. Changing from higher level speakers to lower level ones will make the volume louder. But you must not connect ones lower than the rating of the amp.
The only other way is if there is something wrong with the amp and that it won't go higher due to a fault.
Oct 27, 2017 | The Audio Players & Recorders
Hi, I want to know what is the best way to wire these subs. (Pair). I have heard of several ways. I have a 4 channel amp the soundstream picasso 4.760. Bridged it produces the most power. I was told...
Hello , I will be glad to help you.As far as your speakers..It depends on what impedance your subs are rated and if your Picasso amp can be bridged at 4ohm or 8ohm. If your subs are 8ohm each you can wire your subs in parallel and wire them to picasso amp in bridged mode. If your subs are 4ohm each.Then wire the subs in series then wire them to amp in bridged mode..caution do not wire subs in parallel if they are 4ohm .This would bring impedance to about 2 ohms and would be harsh for amp to handle...Goodluck
Sep 22, 2011 | Planet Audio BB212D Car Speaker
My speaker just rip.. i like to know any subwoofer is ok for replace??
it's an 8 ohm driver. It need to be VERY efficient, around 90-91db @ 1w. Measure the enclosure size LxWxH then divide by 1728. That will give you your cu. ft. internal airspace of the box. Then look for a driver that will effectively work in that space. Shouldn't be too expensive, paper cone, foam surround, 8ohm impedance. Hope this helps
Dec 12, 2009 | KLH ASW10-120 Subwoofer
Getting overload display i have 4 ohm speakers hooked up to it
Receiver is designed for 8ohm speakers. you can't use car audio speakers. they are 4ohm. Most receivers will tolerate 6ohms but not 4. This will short the mains and destroy your power amp!
Nov 17, 2009 | Panasonic SA-HE200 Receiver
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
How many speakers and woofer solid audio f2000 2 channel amp can support ?
  • 8ohm Stereo / 1200 W
  • 8ohm Bridged / 3400 W
  • 4ohm Stereo / 2000 W
  • 4ohm Bridged / 4300 W
  • 2ohm Stereo / 2900 W
  • it can support 6 but i would use 4 but make sure the subs have more watts than the amp
    Jul 11, 2009 | Solid Audio Formula Series F2000 2-Channel...
    Str-D590
    This is not a reset. Most likely one or more transistors have shorted and need to be replaced. Does the front display come on OK?
    Dan
    Apr 29, 2008 | Audio Players & Recorders
    ALESIS M1 ACTIVE MK2 CONE VIBRATION!
    Hello!
    my speaker Alessis M1 Active 620, with a roar is very strong in the speaker, the potentiometer does not attenuate, change the volume. Ja switched capacitor C8, based on my research of other users, but got no result. When you press the power button, the LED lights in blue, and even change the color to red, producing a noise (snoring) very strong.
    help!
    Please help me!
    Mar 17, 2008 | Alesis M1-Active-MK2 Powered Studio...
    Car Audio & Video Logo
    21 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
