Question about Garden
20h.p.onan performer model# p220v-1/10893h s/n:h93722487 the starter will click when turning the key. the starter gear will come up but with little force and does not engage the flywheel. put new starter on and got the same results. the battery,cables,post and connections have beened cleaned and tested. Even tried another good known battery. found the condenser wire broken and replaced with new one. could it be the rectifier/reg? if so how do you test it. Any other suggestions. Thanks
    Top Expert:
  • Garden Master
  • 79,865 Answers
I would suspect the positive battery cable is defective. Have seen this many times before.
Posted on May 19, 2017
  • 117 Answers
SOURCE: starter
the most common problem would be the starter relay,
the contacts burn out so just replace the relay.
cheers
Posted on Jun 30, 2008
alicantecoli
  • 22326 Answers
SOURCE: starter runs but won't engage flywheel
engine crank thrusts worn and crank moved back enough to not engage ,with a manual the clutch would push it forewards.or the flex plate on the back of the torque converter damaged and broke in teh centre where bolts to the crank
Posted on Dec 27, 2008
  • 12 Answers
SOURCE: 1994 Toyota Camry 4 cylinder Starting problems
your starter is bad.... the two contacts inside the solinoid are worn out only way to fix is replace the unit as a whole bet ya you get click click click then my start.. bet my life on this one been fixin toyotas for 20+ years
Posted on Dec 30, 2008
  • 82 Answers
SOURCE: mower starter pinion gear won't stay on flywheel to start it
you can actually just replace the starter bendix
Posted on May 09, 2009
  • 376 Answers
SOURCE: craftsman riding mower repair starter will spin but not engage
You need to buy a Starter Drive Kit. If you starter has a flat piece on top held on by a retaining ring, it's part # 696541. If you have the older type starter with roll pin holding the drive on, you need part # 696540. You probably have the first one. To install the retaining ring, use a 3/8 socket to tap it into the groove. Dwain
Posted on May 29, 2009
JOHN DEERE L115 WON'T engage starter?
Need a little more information..is it is doing nothing Check the battery if ok it may be your starter solenoid try this turn your key to on and using a jumper wire or screwdriver and connect ( cross the two large connectors on the selonoid ) it should turn the engine over. If you hear clicking but not turning over It most likely a bad starter. If the starter clicks and spins but not turning engine..it is the gear on the end of the starter it most likely stripped as many are plastic....need to remove the starter and check it..is ok try doing a bench test..just use any 12 volt supply..attach the hot wire ( +) to the connector on the starter and attach the neg ( ground ) to the starter body..it should click,push the gear upward and spin..if not NEW STARTER...hope this helps..if not let me know what you found......one more thing if nothing at all may be one of the safey switches. Good luc
Oct 17, 2014 | Garden
Starter motor is not good
Before removing the starter check the battery terminals and wires for tightness and are free from ciorrosin build up which will affect the starter performing.. If it is missing engaging the ring gear it will have to come out for repair/ replacement. If it just clicks when you turn the key. check battery with a load test for a dead cell and low charge
Feb 21, 2013 | Fiat 1300 Cars & Trucks
Onan 7000 watt generator rv starter problems
Can you be more specific than just starter problems?
Jan 17, 2013 | Onan Marquis RV Generator 7000 Watts Gas
I have a 1997 onan emerald series GenSet 6500 I have been thru 4 starters it keeps breaking the drive gear assmbly WHAT CAN I DO PLEASE ITS ALREADY COST ME 400.00
Have you replaced the solinoid too? If not, maybe the solinoid is staying engaged, which keeps your starter, well starting. If the starter stays energised the flywheel WILL tear up the starter gear.
hope this helps
Nov 04, 2010 | Watts Onan Portable Generator - 5000 ,...
Solenoid clicks will not engage 4000KW Onan
4000 kW is a very big generator. I asume that your is 4000W = 4 kW.
If - with electrical start it should be MicroQuiet 4000.
Never mind by all types of electricaly started engines this will mean:
If by "not engage" you mean that solenoid only clicks, but neither the starter motor is turning, nor the bendix wheel is engaged to wlywheel. This may mean that battery voltage is low, in order to engage the bendix and make its power contact, or the bendix is mechanicaly blocked.
If by "not engage" you mean that solenoid clicks, the starter motor is not turning, but the bendix wheel is engaged to wlywheel. This may mean that the bendix relay power contacts are bad or starter motor collector or brushes are bad.
If by "not engage" you mean that solenoid clicks, the starter motor is turning with a scratching sound, the bendix wheel is partially or not engaged to wlywheel. This may mean that the bendix throw out lever is bent or broken, or the wheels on bendix and flywheel are worn out..
Aug 01, 2010 | Watts Onan Portable Generator - 4000 ,...
I have a 1990 Camaro RS with automatic transmission. The guy I bought it from said the engine is a AcDelco rebuilt 350 V8 from a 1989 Blazer. There was a Acdelco plate on the engine. I replaced the...
I would think the starter you need would be the 90 camaro one, and not the 89 blazer, as you still are dealing with a camaro tranny and flex plate. Inspect your ring gear closely when you have the starter off, and make sure the teeth aren't buggered. Let me know what you find. Good luck.
Apr 20, 2010 | 1990 Chevrolet Camaro
Onan model 5BGMFA26105D GENERATOR need to replace starter and solenoid. starter will not engage.
Hi, well i would take the starter motor off and check out the "Bendix" spring, that is the part that "Throws" the start gear into contact to mesh with the starter ring gear. Often these simply "Seize" and need a good whack and lube... try that first before outlaying any money, this just may fix it. Also check to see if the solenoid is OK, do this by applying 12 V DC to the solenoid, wires, and see if it activates, also check that the "Contacts" aren't "Blown Off" by putting a meter set to OHMS across the solenoid contacts and when activated it should go "Short Circuit" across the terminals.
Feb 22, 2010 | Watts Onan Portable Generator - 5000 ,...
Deere 318 with Onan B43G won't start w/ starter engaged, but if the engine "catches" when I turn off igniton, it runs fine. I can only get it to start by pulsing the starter on and off--only starts when...
318's are known to have flywheel problems and poor engagement of the starter due to incorrect alignment of the starter to the ring gear.To check either of these things you need to take the motor out of the tractor to look at the ring gear,starter drive and starter aliggnment.Before you go through this pain replace the ignition switch or have it tested.p.s deere only supplies a replacement flywheel but a ring gear can be ordered through a case dealer if you get it for a stinner with the onan engine.
Nov 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Onan Microquiet 4000 starter will spin but not turn engine
bendix is actual the spring that pushes the gear back out of the ring gears engagement your issue is more likely a rusted /corrodied incline engagemnt gear a little lube will probably bring ti right back (do not us WD_40) this is not a lubricant it is an anti lubricant any light oil will do Good Luck
Oct 12, 2009 | Electrical Supplies
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
