Question about Panasonic Vacuums
Panasonic canister vacuum agitator won't spin
The suction works fine but the agitator brush won't spin when turned on. I've checked and cleaned the belt and the agitator which seem to be fine. Please help!
  • 48 Answers
SOURCE: no suction
Is there a blockage in the small hose in the bottom of the machine
take of the pod and you will see the small hose,
Is the main hose pushed into the bottom housing
Posted on Nov 22, 2007
SOURCE: The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
Posted on Mar 14, 2009
galati2k
  • 281 Answers
SOURCE: Brush will not turn and lights will not light
the problm is under the top cover of the base,there are some screws on the botton also remove the self adhiesive emblem on the top and remove the screw then the top will come off.ithink what you will find is a burnt circuit board that sets right above the motor
Posted on Apr 23, 2009
  • 14 Answers
SOURCE: weak suction on rainbow se vacuum
With years of use, you will collect a layer of "micro dust" on the impeller (the fan part) which reduces the efficiency. A toothbrush and some mild cleaner with gently scrubbing will restore it's power.
The impeller is that parts that spins that you can see when you take the top off to fill the water tank.
Hope this is the answer that you need!
Posted on Nov 15, 2009
SOURCE: no suction power ,brush wont spin on carpet power nozzle. When it
You need to replace the belt that turns the brush.
Posted on Jul 03, 2010
Hoover self propelled upright model u6323 930
In order to have suction you need air flow.Essentialy,a vacuum cleaner is trying to create a vacuum the whole time it's on.Just because the beater bar turns doesn't have anything to do with the suction.That is created inside the canister.You have an obstruction in the hose anywhere between the motor and the power brush.
Sep 06, 2014 | Vacuums
Dyson DC08 turbo brush won't turn but have suction in tube
Hi Cathy,
I'm sorry to hear you're having difficulties with your DC08's turbo brush. As you've already checked the machine for blockages and washed the filter, I'd encourage you to get in touch with us directly so we can provide further assistance to help resolve this.
You can call us on 0800 298 0298 - our UK Helpline is available from 7am until 10pm, 7 days a week. It will help if you have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 26, 2012 | Dyson DC08 Hepa Allergy Bagless Canister...
My vacuum isn't cleaning/suctioning very well. The hose attachment will work and pick up debris but the main part of the vacuum (where the brush is) doesn't pick up. The brush only spins but there...
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
Jul 09, 2011 | Panasonic MC-V7582 Bagless Upright Vacuum
Brush will not spin. filters are clean, no clogs, belt is fine. remove canister, it works fine plenty of suction.
Probably a good idea to remove the brush and clean as best you can. Add some WD40 at each end by the plastic clips and turn by hand until they move freely. Reassemble being sure the belt is on properly.
Oct 12, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Panasonic mc-v6840 Low suction.Changed bag and cleaned hose blockage
Check the sole plate where the roller brush is. There may be an obstruction leading from the sole plate to the main dirt channel. Usually on many Panasonic uprights the main dirt channel is a removable bent plastic tube before it meets the bottom of the hose. Check to see if this isn't obstructed. ALso check your filters on the vacuum as sometimes a blocked filter means a lack of suction.
Jul 04, 2008 | Panasonic Vacuums
Suction
No suction, but agitator was spinning and free of debris. Filters were clean. Finally disconnected both ends of the hose and discovered a giant fiber ball clog, the result of a new area rug shedding. Pushed it free with a broom handle.
Mar 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
My vacuum does not have any suction, and it spits out dirt when I roll it backwards. It is an upright Hoover Elite
Trouble Shooting guide:
1. Check to make sure that your agitator still spins. (Agitator = brush). If your agitator does not spin, it could very well be a belt gone bad and means there will be no suction.
2. If belt is fine and agitator spin, your vacuum could be clogged. A clogged vacuum can be cleaned with a brush inserted into the hose of the vacuum to pull out the debris.
Mar 07, 2008 | Vacuums
Vacuums Logo
22 people viewed this question
Top Panasonic Vacuums Experts
Jim Parker
Jim Parker
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
