Question about Video Cameras
T reel sony ev-s9000 - Video Cameras
The pictures are so bright and very blurred
Hi there:
I suggest check EV setting is on the + side and not neutral (0). Either that or Image Adjustment setting is wrong. Check EV by pressing the +/- button (right side near On/Off switch). Hold EV selector and make sure 0.0 is in the display.
Hope this helps.
Aug 23, 2012 | Sony Cyber-Shot DSC-W570 Digital Camera
Dvp-S9000 the video off and digital off indicator lights are on and there is no picture on the tv. How can I switch on the video
I had this problem also, after having my DVP-s900 stored for a few years, put a SACD in the player, press the Audio Direct button on the player(not on remote). This will turn the video on.
Dec 15, 2010 | Sony DVP-S9000 ES DVD Player
Sony TC 330 reel to reel tape recorder. Tape will rewind and fast-forward but will not play. I think a new drive belt might be needed. How do I check?
REEL TO REEL RECORDER SONY TC 330 - on back side of the set voltage selector knobe is lost,so how can i fix it ?
Oct 15, 2010 | Sony Audio Players & Recorders
Tape stuck in sony uvw-1800
02-874 error code signifies a defective takeup reel. The reel is not winding the tape in, so the deck won't go through the eject procedure. Check the connection to the takeup reel motor; if that's OK, the motor itself may be bad. Rarely, the takeup reel motor assembly will need to be replaced; usually it's a connection problem.
Jul 02, 2009 | Sony UVW1800 VCR
Sony Reel to Reel preamp board.
Did you ever get your schematic? I recently got the Model 260 and it has the original owner's manual. I could try scanning the page for you, if you still need the info (if you think that would help you).
--Dave
Mar 28, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
Error :c3122
I assume this is a Sony camcorder since you did not provide brand or model information. The error you listed is a T reel fault, caused by the microprocessor not receiving pulses from the takeup reel on the mechanism. There are several things that can cause this:
a bad tape
a bent reel
a bad reel pulse sensor on the mechanism
some other mechanism fault not allowing the takeup reel to turn
Oct 20, 2008 | Video Cameras
Adding lenses to s9000
Yes. but only the conversion lens
Mar 05, 2008 | Fuji FinePix S9000 Zoom Digital Camera
Video Cameras Logo
27 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
