Question about Dacor ECS130 Epicure Electric Single Oven
Dacor oven beeps f8 - Dacor ECS130 Epicure Electric Single Oven
vitg55
  • 70 Answers
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Posted on Dec 18, 2008
localwonder
  • 6784 Answers
SOURCE: Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Posted on Aug 01, 2009
TheMobilian
  • 8220 Answers
SOURCE: Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
Posted on Aug 20, 2009
TheMobilian
  • 8220 Answers
SOURCE: oven beeping
yOU NEED TO CHECK THE FAULT CODE F1 MOST LIKELY THIS IS A STUCK BUTTON . HERE IS THE DACOR MANUAL
Posted on Aug 21, 2009
localwonder
  • 6784 Answers
SOURCE: what does f8 on dacor self cleaning oven mean
HI. This will generally be an issue with either the wiring at the door switch mechanism, or the door switch itself. Check the door lock switches and wiring. If the wiring is connected well, this will lead to a failed door lock switch mechanism. Use my procedure below to confirm switch failure.
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. Once access is gained, set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use cuation when testing.
Posted on Jan 05, 2010
Testimonial: "thank you very helpful "
My Dacor oven keeps beeping and flashing PRB. How do I stop the beeping?
Most unwanted beeping on Dacor products are due to a bad touchpad... Use your model # and start looking for a replacement , by touchpad I mean a part something like this one: Dacor Touchpad 62678B
Jul 12, 2016 | Dacor Epicure 30" Double Wall Oven,...
My oven flashes and beeps F 4. What does it mean?
F4 on a Dacor oven is a bad temperature sensor.
The temperature sensor is inside the oven up high on the back wall
Mar 29, 2011 | Dacor PCS130 Preference Electric Single...
Dacor
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dacor single oven flashes an F2 error code and won't stop beeping!!!
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
May 22, 2008 | Dacor PCS130 Preference Electric Single...
Dacor error codes
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
SELF CLEANING DOES'T WORK
"F8" ERROR MESSAGE. This indicates a door latch failure.
Jun 25, 2007 | Dacor ECS130 Epicure Electric Single Oven
Dacor ECS130 Epicure Electric Single Oven Logo
43 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
ashburton
Jaime Hernandez
Are you a Dacor Oven Expert? Answer questions, earn points and help others
