Question about Bosch Nexxt 800 Dryer
Bosch 800 next series dryer lights up hit start button clicks and nothing
  • 7 Answers
SOURCE: bosch axxis wtl 5400 dryer
I found that the dryer will not start because the door isn't fully closed. My wife has basically split the plastic door a bit, but if you firmly close the door, it will start.
Posted on Aug 30, 2008
Ranglo
  • 1194 Answers
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jun 27, 2010
Macmarkus
  • 2605 Answers
SOURCE: my bosch nexxt wtmc3300 dryer
Hello, Welcome to FixYa.
There are a couple of scenarios which may prevent the dryer from starting with Bosch, but with the most common there are two thermostat's/switches
which could be reset, plus a no reset hi-limit ( on the lint housing )... i.e. macmarkus_15.jpg ...which cannot be reset, but the hi-limit is the one related to heating...located on the heater housing and the other (emergency shut off/belt switch) is by the motor shown below.
Anyway,
To save time and back and forth dialog, I`ll mention the most likely and what to do about it.
**Unplug the dryer before attempting any repair tips suggested here please...safety first**
There is an auto shut off or emergency kill switch next to the motor I alluded to which will prevent it to start in the event it was tripped for whatever reason.
This is the most likely scenario in my opinion based on your post...but again it depends on your model.
This will require you to remove the back panel again though. Once you've remove the rear panel, It will look like this image below and all you need to do is push it to the right ( from the back )...
i.e.
Since you`ve already taken the back of the dryer off before to gain access you should have no problem.
Either Scenario I alluded to will require the removal of that panel so let me know if you require further assistance to do this.
The other would be resetting the hi-limit cut out, You can see through the back vent opening when the vent tube is removed ( cannot be removed without removing rear panel the first time, but if attached a certain way can be done each time after ) and then by pushing the red button in...shown below.
i.e.
Keep me posted how you make out or if anything is not clear or if your model is completely different...some have line fuses at the back.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Jan 28, 2011
Macmarkus
  • 2605 Answers
SOURCE: BOSCH DRYER #WTL5400UC Thanks Gentlemen, All power
Welcome to FixYa.
Based on what I've read of your post...I'd suspect the hi-limit thermostat is tripped if it is indeed a WTL series Bosch.
I'm not clear as to whether or not you located the hi-limit safety, reset it, or ruled it out so I'm going to explain what to look for and what to do when you get there.
**Unplug the unit from the wall or switch off the breaker...safety first**
Once the dryer has been disconnected from any power, remove the rear panel...
i.e.
Once the panel has successfully been removed, you'll see the heater with the Hi-Limit and NTC attached. The Hi-limit is the thermostat with the red button in the center...
i.e.
push it in to reset it. As you can see by the images I've provided, if you have a multi-meter or ohm meter you can verify the proper values of the listed components.
If the hi-limit is tripped, obviously something triggered it, you can check the possible culprits such as the NTC's or heater with the info I provided above as I alluded to.
( Even so, I'd suggest running it through a cycle or two and monitor it's performance, it may have tripped simply due to poor air flow from a large load etc. and therefore nothing is actually wrong...human error )
You may run the dryer momentarily without the rear panel in place provided nothing electrical has been disconnected, don't attempt an entire cycle, just witness the heater functioning, but it isn't recommended for much longer than a minute or two.
Thank you for choosing FixYa and please let me know what you find out or if you indeed require further assistance. Good luck.
Regards,
Macmarkus :)
Posted on Mar 30, 2011
  • 3 Answers
SOURCE: bosch dryer has pwr but not turning on
Unplug everything, remove the lid (only two screws) and check if the belt is still there around the middle of the drum. If the belt looks good then the problem is prolly the broken-belt electric switch that has tripped. That's described elsewhere here on Fixya. Did someone put in a mess of soaking wet clothes!?
Posted on Oct 09, 2011
Bosch dryer won't run
bad air flow switch,check wire diagram.
Mar 04, 2014 | Bosch Dryers
I have a Bosch 500 Next series dryer. The dryer now is not working. The lights are on, and they give esitmated times for each drying setting. But when I click start, I hear 2 clicks, and nothing happe
Most Bosh dryer have a high limit sensor inside. Very easy to fix. disconnect power, remove back cover. there is lots of screws. usually torx head. you will see at the bottom of the dryer from the back side that there is 2 wires going to a round black "snap disk". there will be a bottom in the middle push the button in. if this dose not fix your problem you should get a in to fix it.
Jan 21, 2014 | Bosch Nexxt 500 Dryer
Can the dryer door be reversed to open the opposite way on the 800 series Bosch?
it is possible . I suggest that you talk to a service repair shop to get details of how to to it if it can be done.
Feb 06, 2013 | Bosch Nexxt 800 Dryer
try jumping the start button out on top if thats it ,replace it
Jan 15, 2013 | Kenmore Dryers
Bosch nexxt 800 series wtmc8520uc not working
How do you get to the motor mount? Where is it located?
Jan 22, 2012 | Bosch Nexxt WTMC8320US Electric Dryer
Bosch Dryer WTL 5410 UC do nothing after selecting a program and hitting the start button. The only thing that happens is that the Drying light lits and nothing else happens. I have tried to hit start...
Door switch may still be your problem. Mine showed lights as if working when closed but I decided to use a screwdriver and push in switch all the way in. It worked then without door closed. It will stay stuck until you pull it own a bit to release it. Give it a try. The door switch appears to have two switches in it requiring it to be all the way in.
Aug 12, 2011 | Bosch Axxis WTL 5400 Dryer
Bosch axiss dryer WTA3510US wont run checked power, fuses. i close the door hit start the drying light comes on but nothing happens no clicks noies's nothing. is it the relay board or somthing else?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 14, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Kenmore 80 series electric dryer wont start
Push the button manually and see if the light goes off . If it does , then the problem is the thermal fuse (a white slim piece of plastic with 2 wires connected to it ) located on the blower housing beneath the drum .
Jul 22, 2009 | Dryers
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Bosch Nexxt 800 Dryer Logo
186 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
