Question about GE DSXH47EGWW Electric Dryer
Dryer control panel flashing - GE DSXH47EGWW Electric Dryer
I have a whirlpool cabrio gas dryer that take along time to dry. It has a code of F1 stored on it.The dryer vent is clean.Is the control panel bad.
change gas valve coils. for f1 error, if dryer is running don't worry about it. in future if your dryer beeps and flash f1 error you can unplug dryer get main control board out check dry solder on motor control rely it it is dry solder you can solder and you good to go or not solder problem then you need new control board. good luck.
Jan 21, 2017 | Whirlpool Dryers
GLEQ2152ES0 dryer stops after ten minutes and then blinking lights on the right of the side panel. The lights that blink simultaneously.
The dryer is telling you what is wrong with it. Count the number of flashes the drying, cooldown, pressaver and clean filter light are flashing then count the number of times the control/start light is flashing. That will give you the error code number.
Dec 04, 2016 | Dryers
Why won't dryer start?
The door switch frequently fails on clothes dryers. You can check it by manually holding the tab tight to the panel and attempt to start the dryer. There should be a distinct click of a switch behind the panel when you depress the tab.
If dryer works when manually depressing tab but not when door is closed slightly bend the tab out to futher increase the travel of the tab when the door closes.
No click likely bad switch!
Replacement requires qualified technician. Part is inexpensive and readily available.
Feb 28, 2016 | Whirlpool Dryers
Perfect Steam dryer control panel occasionally flashes and will not start.
If its an electric dryer check your outlet and power cord for bad connection.
Oct 06, 2015 | Electrolux EIMGD55I 27" Gas Dryer with 8.0...
Frigidaire front load dryer not drying all panel lights flashing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 30, 2015 | Frigidaire Dryers
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
Control lights come on briefly, then turn off, dryer will not run
make sure your getting 220v from the receptacle . good luck APPLIANCES R EN
Mar 02, 2013 | Maytag MDE4806 Electric Dryer
Dryer won't run, control panel lit, start/pause light flashing green, none of the buttons work. Checked door switch & both thermal fuses, all okay. Was thinking it was control panel, purchased and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer goes off after ten minutes an=d the bank of lights
check thermistor on outlet side of blower. if its worn thru plastic to sensor then its bad. this causes several control board issues. remove top then front panel to access this at bottom front.
Jul 05, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Control pannel wont cut on and dryer wont start
We are having the same problem. We have the Neptune dryer MDE5500AYZ. The control panel doesn't come on. We know it's getting electricity as the light in the dryer is on. Is there a reset button in the dryer?
May 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
GE DSXH47EGWW Electric Dryer Logo
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
