Question about Razor Flash Rider 360
Razor 360 stripped pedal crank
Model :x 3519 right pedal stripped
If it is the pedal's threads that are stripped just purchase a new pair. If it is the threads on the crank that the pedal goes into then either replace the crank arm if it's the left side or find a bike shop that can install a "Helicoil" to repair the crank. Threads will be stronger than the original
Jul 31, 2017 | Cycling
Pedal stripped
You will need to have that crank arm replaced. They do make repair threads, but the price to install is just as much as replacing the crank arm. Your local bike shop can provide the correct parts.
Mar 28, 2014 | Schwinn Cycling
Stripped bicycle pedal
Better replace the pedal and most probably the crank arm as well. Sometimes a new pedal can cut the threads true again on the crank arm but the crank arm may need replacement too, depending on the damage. Remember to fit the correct side pedal. The pedal threads differ between left and right and pedals are usually marked "L" or "R".
Jan 04, 2014 | Huffy 26" Womens DS-7 Dual Suspension...
How does a helicoil for stripped crank arm work?
I would just stop by a welding shop and have them weld the pedal arm on. You can buy another whole bike for what it costs to get a helicoil like that done. If it's the left hand thread, impossible.
Nov 25, 2013 | Huffy Blackwater Men's 26-Inch Mountain...
Huffy pedal
You need to replace the pedals( they come in pairs) but you have to make sure the crank arm isn't stripped also...if it is you'll have to replace that as well. That usually happens because the pedal wasn't tightened right in the first place
Aug 12, 2013 | Cycling
How do I fix a bike pedal that fell off and is stipped?
If the pedal post is stripped get a new pedal. If the crank side of it is stripped you can just replace the crank and put new pedals on it.
Aug 12, 2012 | Shimano Cycling
The pedal assembly on my blackwater somehow got stripped always had problem with pedals coming off
If the thread on the crank arms that hold the pedals are stripped, you will need a new set of cranks. That is definitely a job for the bike shop. Make sure the pedals are snug in the arm, Right side pedal has right-hand thread, left side (looking down when you are on the bike) has a left-hand (reverse!) thread.
Jul 10, 2011 | Huffy Blackwater Men's 26-Inch Mountain...
My right pedal is stripped. how can you repair/replace the part the pedal screws into?
If it's stripped the crank arm will need to be replaced. It's probably more expensive to fashion a repair with helicoils and taps, even if you COULD find a left-handed one for the left side.
Get on your favorite search engine and look for "(your brand of crank) (size)" or just take it to a Bike Shop and let them deal with it. You would need special tools for crank removal anyway.
http://www.parktool.com/blog/repair-help/categories/crank-service
Jun 14, 2011 | Dynacraft Cycling
Left pedal broke can i get replacement?
All depends on if you stripped the crank arm, you may have to replace your crank arm if you rode with a loose pedal. Pedals are sold in pairs, and there are 2 sizes, a one piece crank is 1/2" and 3 piece crank is 9/16", take your bike to the bike shop and they will tell you if you need a new crank arm or not. It will do no good to just replace your pedal if there is a bad crank arm thread, it will not hold.
Sep 26, 2010 | Cycling
My bicycle pedal is stripped and I can't get one on. How do I fix this? Thanx
Depending on left or right you will first need a crank puller to remove the crank in order to replace it. You will be better off taking it to a bicycle repair shop. Cranks usually only come in sets but the shop may have a spare or they might be able to order you a seperate one. The same applies for pedals. If the threads in the crank are not too damaged you might just need a new set of pedals or one replacement. Hope this helps.
May 21, 2009 | Dunlop Standard Tortex .60mm/ 12pack
Razor Flash Rider 360 Logo
Top Razor Cycling Experts
Erick Williams
Erick Williams
Level 1 Expert
Donald Ayers-Marsh
Lawrence Oravetz
Are you a Razor Cycling Expert? Answer questions, earn points and help others
