Question about Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46
I Have a new 2013 Husqvarna v46 mower, I need to remove the lower dash panel to get to the oil change plug. The plastic screw(?) that holds the panel in places only rotates but will not come out, so I cannot get the panel off. Should I just remove this screw and put something it its place, and if so what would I use so that I don't have the same problem later.....
  • 398 Answers
SOURCE: Need part number/ exploded diagram for 455 chiansaw
http://www.partstree.com/parts/?lc=husqvarna&mn=450+e+%282007-03%29&dn=33_56_0029 they should cover it
Posted on Mar 20, 2009
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
  • 1129 Answers
SOURCE: Brand new Husqvarna R53SV 53cm Petrol Mower wont start
Buy some starting fluid and spray some in the carb or air cleaner intake port, if the machine is flooding do not choke while using the starting fluid, make sure you do not have too much oil in the mowwer.
Posted on Jul 15, 2009
nova2nv
  • 197 Answers
SOURCE: I have a husqvarna 55. I put in a new carb, coil,
If you are still having problems I would check or replace white grommet inserted into cylinder and connected to manifold,they have issues with breaking or blowing out.This model also has problems with the black intake boot not sealing around cylinder and manifold,an easy check by spraying a LITTLE carb cleaner around problem area.
Posted on Nov 18, 2009
ginko
  • 19396 Answers
SOURCE: Husqvarna riding mower w/20 hp
Hi.
There is gas smell in the carburetor because the engine is not starting and carburetor is flooding.
As first thing ensure that there is spark, pull the spark plug wire and put the end near to engine block while cranking. You will see the spark. If there is no spark, check distribution coil and wires.
If there is spark, check if there is fuel pressure, if there is smell from carb, then the fuel pressure should be Ok.
Once you are sure that the pump is doing its job, and that there is pressure, check the carburetor settings. The mixture is probably too rich or too lean, and for that reason it is not igniting.
If it is not a matter of carburetor settings, then the carb must be taken apart to check carburetor filter.
To get parts and diagrams see: Outdoor Distributors - Lawn Mower Parts
Posted on Sep 26, 2010
How do i cahnge the oil
There a plug on right side of motor.Screw it out and turn off oil filter
Sep 06, 2015 | Husqvarna YTH22V46 46" 22HP Lawn Tractor...
Video how to change oil by removing lower dash cover
There is a drain cock located on the lower left side of the engine. The tractor should have come with a clear plastic tube to attach to the drain cock. See the video. Husqvarna Lawn Tractors Maintenance
May 28, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Astra aircon switch
1.remove the audio system.
2.remove cig lighter
3.remove lower compartment door and assembly under radio.
4.remove compartment under radio
5.then remove all necessary screws that hold the plastic panel on.
6.once all screws are removed and you can either lift the panel up enough or remove it total depending on you.then you will have easy access to the switchers..
Jan 04, 2014 | Holden Astra Cars & Trucks
How to change the crank case gasket briggs 23hp
Yes you need to drain the oil, turn the engine onto its flywheel, remove all the crankcase screws, clean the exposed crank to remove any rust or dirt, now gentlty ease the base off, it should come away with the oil pump gear.
Dec 09, 2012 | Husqvarna 23hp Briggs & Stratton 48-inch...
Four way flashers and signal lights are not working on 1998 for taurus have changed the delay relay switch
Replace the flasher unit. The flasher/turn signal is screwed into the metal support above the fuse panel, you must take the bottom of the dash off and remove the plastic cover. this is for a sable that has light out detection.
Look under your dash for a blue box screwed into the right side of the dash panel. This of course is done, with you laying on your back, and your feet in the back seat.
It's a blue box, about the size of half a twinkie (cream filled, golden sponge cake).
Remove the plug that holds it in, unscrew the screw that holds it to the frame, and go to Autozone or other parts store, to get a new relay.
You will have to reuse the metal piece that holds the relay to the dash panel, so be sure and save that before you throw the old part away.
Installation is the reverse.
May 08, 2011 | 1998 Ford Taurus
Ford explorer no heat clicking in dash
NO NEED TO REMOVE WHOLE DASHBOARD!!! REMOVE TWO7MM SCREWS FROM THE BOTTOM OF STEERING PANEL & PRY AND REMOVE PANEL.
NEXT REMOVE TWO 7MM SCREWS ON BLACK PLASTIC STRIP THAT YOU SEE AFTER REMOVING STEERING PANEL....PRY THIS STRIP OF PLASTIC OUT JUST A LITTLE AND CUT IN THE MIDDLE .
NEXT REMOVE TWO 7MM SCREWS FROM AROUND TOP OF INSTRUMENT PANEL (BY GAUGES ) PRY PANEL STARTING FROM AROUND VENT ON LEFT BY DRIVERS DOOR ""THIS PANEL WILL STAY IN PLACE LOOSE... NO NEED TO REMOVE!""
NEXT YOU WILL SEE 0NE 7MM SCREW BY GEAR SELECTOR AREA.. BEHIND THE LOOSE PANEL REMOVE THIS SCREW.. ALSO IN SAME AREA BUT LOWER THERE IS ONE 7MM SCREW THAT NEEDS TO BE REMOVED THAT HOLDS LOWER DASH PAD ITS FOUND BEHIND LOWER CORNER OF DASH PAD.( LOWER DASH PAD GAS PEDAL AREA )
"DON'T"!!! REMOVE THE FOUR 10MM BOLTS!!!! IN SAME AREA
NEXT REMOVE RADIO /AC CONTROL TRIM WITH THIN SCREW DRIVER OR PANEL TOOL IT HELD IN BY SIX CLIPS...NO NEED TO DISCONNET ANYTHING IT WILL STAY THERE HANGING!!
NEXT REMOVE TWO CENTER CONSOLE LOWER LARGE PLASTIC CLIPS BY FLOOR MATS. NEXT UNDER SQUARE BLACK RUBBER AT CENTER CONSOLE REMOVE ONE SILVER SCREW. MOVE SEATS FOWARD AND REMOVE TWO 8MM SCREWS FROM SIDES OF CENTER CONSOLE FROM BACK SEAT.
PRY CUP PANEL SECTION THAT WAS HELD DOWN BY SILVER SCREW ...PRY UP TOP HALF OF CONSOLE STARTING FROM SECTION WHERE ARMREST DOOR IS.. DISCONNECT LIGHTER PLUG AND REMOVE PANEL .
NOW YOU WILL SEE SIX SCREWS STARTING FROM BELOW RADIO TRIM WORKING BACK TO ARMREST DOOR
Dec 04, 2010 | 2004 Ford Explorer
How do you remove the radio on a 2004 Monte Carlo SS
Begin sitting in the front passenger seat. Open the glove box. Find the screw attached to the dash board (on the left). Remove that screw. Move to the drivers seat. Remove the narrow panel that holds the light bulb below the steering wheel. There are two plastic clips that hold that piece on the car. Removing that panel reveals a few Phillips head screws. Remove those screws. With the drivers door open, locate the fuse panel. Remove that panel. You will see a few screws there, remove the lower one (or two, I can't remember for sure). Next, tilt the steering wheel as low as you can get it. Slowly (using your hands only) pry the panel just above the steering wheel outward toward yourself. Slowly move toward the radio pulling the panel toward yourself. Once you have freed the large panel, fish your hand in behind it to disconnect the hazard button (This is a must!!!). Once that has been disconnected, pull up on the panel to move it past the steering wheel (it is a tight fit). Once that it done, there are two screws holding the radio in the dash. Remove those screws as well as the radio antennae plug and the two wiring clips in the rear of the radio.
Dec 21, 2009 | 2004 Chevrolet Monte Carlo
Changing out the radio on 1996 buck century
Remove the hex screws from the lower section of the dash, under the steering column. This will reveal more screws that hold the wood tone panel down. There are more screws visible just under the top of the dash, look carefully as the upper screws, so you do not remove more than you need. Carefully, twist the woodtone panel around the steering column and remove. You will see 2 more hex screws to the right of the radio that hold the black plastic cover just to right of the radio. Carefully pop that cover off to reveal 2 more screws that hold the radio in place. Remove those 2 and the 2 on the left and you can pull the radio forward to unhook the harness and antenna wires.
Sep 26, 2009 | 1996 Buick Century
I don't know how much transmission oil need the Husqvarna wr360, 2000. I was buy this bike but I don't know how changing oil.
There is a screw on the side of the lower unit, you remove this screw, fill with proper lubricant and then hold the bike upright, it will then overflow to the proper level.
Jun 27, 2009 | 2000 Husqvarna WR 360
Heating
"Blend door stuck and clicks on your 2003 Ford Explorer?\" FIRST BUY OEM BLEND DOOR MOTOR $57.00 + UP TOOLS NEEDED : PANEL TOOL OR FLAT BLADE SCREWDRIVER ,1/4 SOCETS 7 & 8MM ....1/4 HANDLE...1/4 SMALL EXTENTION...1/4 RATCHET NO NEED TO REMOVE WHOLE DASHBOARD!!! REMOVE TWO7MM SCREWS FROM THE BOTTOM OF STEERING PANEL & PRY AND REMOVE PANEL. NEXT REMOVE TWO 7MM SCREWS ON BLACK PLASTIC STRIP THAT YOU SEE AFTER REMOVING STEERING PANEL....PRY THIS STRIP OF PLASTIC OUT JUST A LITTLE AND CUT IN THE MIDDLE . NEXT REMOVE TWO 7MM SCREWS FROM AROUND TOP OF INSTRUMENT PANEL (BY GAUGES ) PRY PANEL STARTING FROM AROUND VENT ON LEFT BY DRIVERS DOOR ""THIS PANEL WILL STAY IN PLACE LOOSE... NO NEED TO REMOVE!"" NEXT YOU WILL SEE 0NE 7MM SCREW BY GEAR SELECTOR AREA.. BEHIND THE LOOSE PANEL REMOVE THIS SCREW.. ALSO IN SAME AREA BUT LOWER THERE IS ONE 7MM SCREW THAT NEEDS TO BE REMOVED THAT HOLDS LOWER DASH PAD ITS FOUND BEHIND LOWER CORNER OF DASH PAD.( LOWER DASH PAD GAS PEDAL AREA ) "DON'T"!!! REMOVE THE FOUR 10MM BOLTS!!!! IN SAME AREA NEXT REMOVE RADIO /AC CONTROL TRIM WITH THIN SCREW DRIVER OR PANEL TOOL IT HELD IN BY SIX CLIPS...NO NEED TO DISCONNET ANYTHING IT WILL STAY THERE HANGING!! NEXT REMOVE TWO CENTER CONSOLE LOWER LARGE PLASTIC CLIPS BY FLOOR MATS. NEXT UNDER SQUARE BLACK RUBBER AT CENTER CONSOLE REMOVE ONE SILVER SCREW. MOVE SEATS FOWARD AND REMOVE TWO 8MM SCREWS FROM SIDES OF CENTER CONSOLE FROM BACK SEAT. PRY CUP PANEL SECTION THAT WAS HELD DOWN BY SILVER SCREW ...PRY UP TOP HALF OF CONSOLE STARTING FROM SECTION WHERE ARMREST DOOR IS.. DISCONNECT LIGHTER PLUG AND REMOVE PANEL . NOW YOU WILL SEE SIX SCREWS STARTING FROM BELOW RADIO TRIM WORKING BACK TO ARMREST DOOR .REMOVE ALL SIX..THESE HOLD THE BOTTOM PORTION OF THE CONSOLE ALSO DISCONNET ONE BLACK PLUG AND PULL ALL THE WIRES CLIPPED DOWN...PULL BOTTOM PORTION OF CONSOLE TO BACK SEAT. PULL LOWER DASH PAD GIVE A NICE TUG.. IT SHOULD MOVE OUT A LITTLE ..DID YOU REMEMBER ONE SCREW BEHIND CORNER DASH..!.STARTING FROM AREA BY GAS PEDAL LOOK UP IN THIS AREA YOU WILL HAVE ENOUGH ROOM TO GET A LONG EXTENTION WITH AN 8MM SOCKET TO REMOVE 3 SCREWS HOLDING MOTOR TO BLACK PLASTIC SECTION.. REMOVE SCREWS DISCONNECT SMALL BLACK PLUG AND PULL MOTOR FROM SOCKET GOING TOWARD DRIVERS DOOR DIRECTION. ALIGN NEW MOTOR SHAFT WITH SOCKET TIP.......IF NEED BE..... YOU COULD PLUG MOTOR HARNESS INTO NEW MOTOR THEN TURN IGNITION ON AND MOVE HEATER/AC CONTROLS TO GET THE SHAFT LINED UP..DONT MOVE ANY OTHER WAY!!!!!! NOW PUT SHAFT INTO SOCKET MAKE SURE YOU CONNECTED THE PLUG IF YOU HAVEN'T ALREADY!! INSTALL 8MM SCREWS AND TRY IT OUT YOU SHOULD HAVE HEAT NOW NOW INSTALL EVERTHING BACK IN REVERSE ORDER
Sep 29, 2008 | 2003 Ford Explorer
Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46 Logo
47 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
