Question about Veho VBC-001-BLK SAEM Bluetooth Handsfree Car kit with Motion Sensor Power Save Function 2 years Standby Battery
Won't pair Won't connect to lg phone4s or lg which both have bluetooth
How to pair Plantrotics Voyager HD Pro with Phone4S
Get light flashing by hold down power button down. Go to setting on iPhone then to Bluetooth make sure lights flashing then phone should find your device push on the work pair then it should work
Feb 24, 2013 | Cell Phones
Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
Hope it works for you.
Cheers! Carlos
Apr 18, 2010 | LG GM200 Cell Phone
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
I can't connect my hbm-210 bluetooth to my
Go into your phone and under your bluetooth settings delete your headset profile. You can now just go through the pairing procedure again and your phone should find the headset and you can click yes pair with this device(headset) and just finnish you pairing. Also make sure you didn't turn your bluetooth power off on your phone by accident.
Jan 28, 2010 | LG Cell Phones
How to connect to bluetooth (ant) device with lg rumor phone
Not sure if you have paired your bluetooth with your phone yet. Hold your bluetooth button down untell it flashes (usualy blue and red) continuously your phone should then find your bluetooth then it will ask for a code. Usualy the code is 0000. If not make sure your bluetooth is turned on:)
Oct 25, 2009 | LG RUMOR Cellular Phone
How to connect LG cookie with Nokia Bluetooth BH 101
Put your Nokia Bluetooth BH 101 into pairing mode - this is normally done by pressing and holding the power key for several seconds. An alternate bleep will sound with a flash light to indicate that you are in pairing mode.
Now using your Cookie, press Menu > Settings > Bluetooth > Search
Your Cookie will find the Nokia BH101 bluetooth headset and then it will ask for a pass code. This is usually four zeros (0000).
You should now be connected!
Apr 10, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Lg env v pairs with jawbone but won't connect. is it the code?
I have had the same issue with MY Samsung bluetooth headset.
Here's the sequence that works for me:
  1. Delete the headset under the bluetooth menu.
  2. Turn off the bluetooth
  3. turn on the blue tooth
  4. Add the headset back. The default pair code for most devices is "0000" or "1234"
  5. Try to enable/connect. If it fais, simply power off the enV.
  6. Power on and try to connect again (just connect, not pair)
  7. Headset will then pair.
KingGypsy in Phx.
Jan 19, 2009 | LG enV VX9900 Cellular Phone
CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
Mar 31, 2008 | OEM Systems Bluetooth Headsets - Model...
Bluetooth HBM-730
just set the bluetooth earpiece to pairing mode and start searching bluetooth devices from your phone.
If you don't have a manual, just post back.
Feb 06, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Veho VBC-001-BLK SAEM Bluetooth Handsfree Car kit with Motion Sensor Power Save Function 2 years Standby Battery Logo
29 people viewed this question
Top Veho Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Veho Radio Communication Expert? Answer questions, earn points and help others
