Question about Craftsman 1700 PSI, 1.3 GPM Electric Pressure Washer w/ Steam Cleaner
Water leaking where hose goes into spray handle
LIttle Green Bissell Water goes directly to collection tank, won't spray
Had a problem with mine not spraying, took ot apart and the heater for the solution was plugged with scaling, cleaned it up and works the very best now. As far as clean water going directly into the collection tank, sounds like the little hose may have a break or a leak in the vacuum hose.
Mar 14, 2018 | Bissell Vacuums
Hoover max extract 77. It is leaking or spraying water only(sprayers)when in upright position after shampooing. Doesn't leak when turned off/on but does from catch basin under tank when pedal released
Obviously, it is either not fully inserted or the seals are leaking.
These shampooing devices are very picky about how you insert each part. They are not as temperamental as their older models, which I tossed in the garbage after getting a heated model, but they can still be difficult to handle.
Now, on difference is when the handle is upright all suction goes to the attachment hose. The further you lean the handle down the more suction goes to the lower compartment but you said it is leaking from the bottom. I suspect your supply chamber is the leaking area. You are just noticing is more because the lower section has less suction you suck up any leak before you see it.
Apr 16, 2015 | Heating & Cooling
What causes leaks under dashboard in Trailblazer during rain?
Crawl down there and watch with flashlight while someone sprays area from outside with hose.. when you see where the water is comning in fix it.. this is how a shop would determine where the leak is.. at about $100 an hour.. spray the water gentlly so you can see when it starts comning in. I would suspect windshield seal leak.
May 12, 2014 | 2004 Chevrolet TrailBlazer
The faucet leaks where the spray hose attaches to the spray head. Model 157-074r-st. The problem occurs when water is turned on. If the spray head is in the handle, water leaks below the sink. If the spray...
Yes the leak is the washer. You can get a new washer at any hardware store. Just take the damaged washer with you and have someone at the store help you.
Here is the washer size according to the manual 20X12X2.5
Page 2 of the link below.
http://www.blancoamerica.com/SPECIFICATIONS/157074R.pdf
Feb 27, 2011 | Blanco Classic Single Handle Faucet with...
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
Moen two-handle kitchen faucet, 1990's model installed new a few years ago, is leaking underneath at the center where the spray hose would connect. I didn't use the hose, though. The nut was tight. It...
The nuts used for capping off the sprayer attachment will bottom out and not seal. Unless there is tape or thread compound on the nut, it can spray a tiny jet up under the faucet when the faucet is activated. If there is clearly water leaking from above that, then the o ring for the spigot may be failing and need replacing. If this is the case, it will only leak when the faucet is activated. There is always the possibility of a crack in the casting of the faucet body; hope not:)
Aug 22, 2010 | Moen 7910 Chateau Two-Handle Kitchen...
Hi my 1999 Ford escort when it goes back to idle
sounds like a vacuume leak, take some soapy water in a spray bottle and spray the hoses slowly, when the motor levels out you found your leak, being 11 yrs old, i would change all the hoses anyway, they are overdue
Feb 16, 2010 | 1999 Ford Escort
Leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Sep 25, 2009 | Danze D403412 Melrose Single Handle...
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
Leaks from handle
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jan 27, 2009 | Danby DDW1805W Designer Series...
Craftsman 1700 PSI, 1.3 GPM Electric Pressure Washer w/ Steam Cleaner Logo
67 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
