Question about Canon PowerShot S2 IS Digital Camera
Camera wont start, lens do not go out - Canon PowerShot S2 IS Digital Camera
The lens wont open on my samsung es60 camera it start then stops how do i take camera apart
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Jul 12, 2011 | Cameras
Camera lens wont open
Saw a similar problem recently, same cause, and result was the lens was jammed.
Did manage to wiggle it free after many attempts...it only stays on for a few seconds before faulting and going off...but it's a bit hard to get a hold on the edge of the lens to pop-out the low side.
Started by laying it on it's back and checking the level of the lens edges for the low spot, then used a thick sewing needle to lift up while turning the unit on (again and again) until the gear-ring popped back in during the lens-check at start-up.
Apr 06, 2010 | Casio Exilim EX-Z40 Digital Camera
Focus error on camera wont take pictures wont put
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 12, 2010 | Fuji FinePix A500 Digital Camera
Lens error, lens wont come out at all just started wasnt dropped hit or anything
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 27, 2009 | Sanyo Vpc-s1070w Digital Camera
Lens error
The lens on my canon camera power shot A430 wont open and when I try to start it is says lens error restart the camera
Aug 04, 2008 | Canon PowerShot A430 Digital Camera
Optio M40 turns itself off and the lens wont retract into the camera when off
yes me too! one side of my lens hit the ground and is stuck. it wont come out and my camera also automatically turns itself off once i try to start it. i think you shoudl go get your lens fixed...mines stuck and wont go in or come out
Apr 28, 2008 | Pentax Optio M40 Digital Camera
Cannon Power shot SD630 Lens Problem
Sorry to here that you can send it to a repair company like me for repair. cost about $120.00 plus shipping to fix.
Feb 26, 2008 | Kodak Easyshare M753 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
