Question about Golds Gym Trainer 410 Treadmill
Golds gym trainer 410 treadmill belt stopped while walking
While walking on the treadmill, the belt came to a complete stop. I removed key, unplugged, and turned off for 1 hour. turned back on and belt will not move.
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: golds gym trainer 410 treadmill belt either too tight or too loose. When it's too tight it wont go and when it's loosened like it says to do, it makes a strange noise.
LUBE the deck belt, maybe you have now A WORN deck belt, see the videos and proceed according.
God bless you
Posted on Nov 28, 2012
ercupa190
  • 12223 Answers
SOURCE: Golds Gym Trainer 410 belt and incline do not work
LUBE THE DECK BELT SEE THE VIDEO ATTACHED
2) RUN THE SOFTWARE CALIBRATION FOR EASY DIAGNOSE, TROUBLESHOOTING AND FIX IT. GO under the HOOD motor, and follow the steps.
God Bless you
Posted on Dec 13, 2012
Golds gym trainer 410d Belt doesnt work when I hit the start button
If you wish to get some details About treadmill repair; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 14, 2016 | Golds Gym Trainer 410 Treadmill
My Golds Gym trainer 480 treadmill minimum speed is 3 miles at lowest setting and it will not slow down when pressing the down arrow
Gold's Gym Treadmill Product Support ' ManualsOnline.com
fitness.manualsonline.com/support/golds-gym/treadmill/
My goldsgym treadmill just goes up and down when t. Gold's Gym ... my treadmill walking belt will not turn. ... Golds gym trainer 480 start button stopped working.
Repair Your Own Treadmill With Mark Peterson - YouTube
? 1:16
https://www.youtube.com/watch?v=B997gX07hW4
May 6, 2008 - Uploaded by Mark Peterson
A certified Fitness Specialist by the cooper clinic in Dallas, and a personal trainer for the first 16 years of my fitness career. .... I purchased a used Golds Gym Treadmill model# GGTL396100 which I tested when buying ... The treadmill will fully incline thennot go down, I have tried to recalibrate the incline ..
Nov 26, 2015 | Exercise & Fitness
The belt is not running
Lower board has probably died, needs to be replaced. Probably blew because walking belt needs to be replaced.
www.atlantafitnessrepair.com
Oct 17, 2015 | Golds Gym Trainer 410 Treadmill
Everything working except the belt
do you have the magnetic tag attached to you and the machine? it prevents operation unless its attached.
Jan 15, 2014 | Golds Gym Trainer 410 Treadmill
I have the 1750 Commercial Treadmill and the screen is "froze" on the program for the sd card or WiFi. When I push on the stop button or unplug and replug in the power it still is STUCK on that screen. ...
use this steps and fix it. God bless you
Step 1
Plug the power cord into a UL 1449 single-outlet surge suppressor and then plug the surge suppressor into an electrical outlet that is not GFCI-equipped if the power does not turn on. If the treadmill is plugged in and the power still does not work, make sure the key is in the console and that the Reset/Off circuit breaker has not been tripped. Press the switch to "Reset" if it has been tripped.
Sponsored Links
Gym Equipment Choose from 1M+ Verified Suppliers. Contact Directly & Get Live Quotes! www.alibaba.com/Gym-Equipment
Step 2
Check the Reset/Off circuit breaker if the power switches off while in use. Wait five minutes and switch the button to reset. Check that the power cord is still plugged in securely; pull the plug out and plug it back in after five minutes. Pull out the console key and reinsert to see if the machine will turn back on.
Step 3
Place the chest pulse sensor tightly right underneath your pectoral muscles or breasts for it to operate properly. Position it lower or higher on your chest if it does not work properly. Wet the electrodes with a saline solution. Walk near the walking belt's center within an arm's reach of the console.
Step 4
Remove the console key and unplug the treadmill to loosen the walking belt if it slows when in use. Turn the rear roller bolts counterclockwise with the hex key 1/4 of a turn until you can lift the walking belt's edges 3 to 4 inches from the platform.
Step 5
Remove the key and unplug the treadmill to adjust the walking belt if it is off-center or slips when in use. Loosen the rear roller bolts with the hex key and reposition the walking belt. Tighten the roller bolts. Walk on the treadmill to determine if the walking belt is centered. If not, loosen the roller bolts again and make adjustments until the walking belt is centered.
Step 6
Recalibrate the incline system if the treadmill's incline does not adjust correctly. Press the "Incline" button and remove the console key. Wait a few seconds and replace the console key. The incline will automatically recalibrate by moving to the maximum incline level and then the minimum level.
Step 7
Press the "Stop" button for a few seconds to turn off the demo mode if the console display stays lit after you remove the console key.
Read more: http://www.livestrong.com/article/241157-nordic-track-treadmill-troubleshooting/#ixzz2geWlKdPR
Oct 02, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
I have a gold gym trainer 410 treadmill that by a power out stop working I notice the motor card was burned out so I bought a used one in ebay but still wont turned on what could be wrong with it
you may have a faulty board.Does it have a light on it when you turn it on. If not it is faulty or the power lead is faulty or safety switch is faulty.
If all else fails call a tech to come out and look at it for you.
Sep 25, 2013 | Golds Gym Trainer 410 Treadmill
I have a Gold's Gym trainer 410 treadmill. I
please RUN the software calibration for easy diagnostic and fix it.
Go under the HOOD cover for motor, and see the instruction and follow the instruction
God bless you
Jul 20, 2013 | Exercise & Fitness
Golds Gym Treadmill motor will not start after sitting for about a year.
see the video and LUBE . However after you did if the problem remain test a) control board see the diagram block b) time to replace the old board deck belt.
God bless you
Mar 24, 2013 | Golds Gym Trainer 410 Treadmill
God Bless you
Dec 13, 2012 | Golds Gym Trainer 410 Treadmill
Golds Gym Trainer 410 Treadmill Logo
Top Golds Gym Exercise & Fitness Experts
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Propulsive
Level 1 Expert
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
