Question about Canon S900 InkJet Printer
S900 Ink Pad location
Can someone please tell me how many Ink Pads there are on my S900?
I can only detect 1 which is under the print-head rest position. It sits on a rubber spring pad and can be easily removed (carefully), washed in water, dried and put back.
I have done this, re-set the counter and it works fine.
Have I missed any other pads?
Many thanks
Gerry
  • gdsilva779 Jun 19, 2009
    Thanks dougc5472 - I will pursue this one. Much appreciated.
    gdsilva779
    Scholar:
  • 117 Answers
That item your talking about is actually the purge unit. The ink pad is actually below that and usually requires a repair tech to service and replace the pad. Contact Canon for a repaiir center near you.
Posted on Jun 18, 2009
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Hi
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
Waste ink tank full
hi can yo please give out the part number and more detail of the problem
Sep 07, 2008 | Cannon Office Equipment & Supplies
Message says :"waste ink absorber
Clean it out, its a pad underneath the print head, you've not said which model printer you have so I suggest you go to the manufacturers web site, follow links for support and see if there's a FAQ frequently asked questions page with your issue mentioned.
Apr 18, 2011 | Office Equipment & Supplies
Replaced both color,and black cartriges and all color pictures i print are very dull (faded)
Make sure you are using authentic Canon inks, using anything will produce poor results and will void your warranty. Also make sure you are using photo paper. Using standard printing paper is not designed for printing sharp photographs. In the printer utilities, under maintenance there is an option to clean the print heads. Run this option and follow the on-screen instructions. This should be done each time the ink is replaced. If none of these options work, then contact Canon for warranty repair if it is still under warranty.
Mar 02, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Won't print a document
Hello
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 14, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Ink absorber
Canon PIXMA IP2000
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
Aug 11, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Waste Ink Absorber full - Canon Pixma
Reporting solution by daweed:
"WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEM
This is true with many Canon Ink Jet Printers: Eventually, you'll get an error message "Waste Ink Tank Almost Full, Contact Your Canon Repair Center". Canon is totally sly about this, and is actually a pretty ridiculous design flaw that they should be ashamed of- planned obsolescence. Anyway, don't let this problem discourage buying an otherwise fantastic Canon printer.
This problem will also be indicated by flashing orange lights on your printer. Different flashes for different models.
LOOK IN YOUR PRINTER MANUAL TO KNOW WHAT NUMBER OF FLASHES INDICATE. In any case, your computer printer software will also tell you exactly what is going on.
You need to do this after you get the WASTE TANK ALMOST FULL message and the printer continues to work, but BEFORE the WASTE TANK FULL message and the printer completely stops. I think. ;-)
Here's the fix:
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings. From what I gather, its both a time consuming and expensive proposition to take to Canon to fix. And they won't tell people how to do it themselves. Well, I WILL. And this works.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free. You have to be slightly mechanical to do this. If you get this message and you've never used a screwdriver and are all thumbs, well, Canon gotcha. But give it a shot even then, or give it to someone halfway coordinated to do this for you.
7) Print away!
I did this and it works fine! No more error messages and so..."
Mar 13, 2008 | Canon PIXMA iP90 Mobile Printer
Waste ink absorber almost full-Canon S900 inkjet
It doesn't matter if you change (wash) the waste ink pad absorber or not, if you reset the error code il will work ok. The waste ink sponge can be full if you had a lot of cleaning done since using the printer, fact is that latest after the error appears the second time, you had to clean it.
  • 1) Figure out how to open the printer by removing the side and inside top plastic panels. Just look at the thing and use your brain. Its all pressure clipped in place, no screws (at least on the S900 and similar models, probably still the same on this years models.) Look for slots and triangles on the 960.
  • On the i960 you'll have to remove the power buttons assembly on the front- take out the two screws, unplug the internal white electro connector plug CAREFULLY, then you can undo the last clip that holds the top in place.
  • 2) No need to remove the ink cartridges in this process- so don't. The mechanism is held down in place in the case by two screws at the very bottom on the outside bottom of the metal chassis inside. Remove these screws then lift up the mechanism. It should lift out fairly easily, but remain attached by wires-- just place it on the top edge of the case.
  • 3) You'll see the blackened (from waste ink) felt pads on the bottom. WEAR GLOVES-- this is skin indelible ink, the only thing that will get it off your hands is CLOROX. Period. There are two skinny pads that sit on top of a larger pad. Note how they fit together.
  • 4) Lift the pads out and rinse out thorough in a sink until very little or no ink comes out. There's no need to use chemical or soap cleaners, just use plain water from the tap and the spray nozzle. Keep rinsing and squeezing the pads, but don't twist them like a towel, squeeze and fold in half however to really get the ink out.
  • Lay flat in the sun for a few hours to dry. Use a hairdryer to get the last bit of moisture out then replace in the printer, and put everything back together.
  • 5) RESET the printer electronics, so you won't get the stupid "waste ink tank full" message any more.
  • WASTE INK TANK RESET PROCEDURE
    Canon BJ F900, F890, F700, F500, S900, S820, S750 and S520
    Turn off the printer.
    Press and hold the RESUME button, then press and hold the POWER button.
    Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily.
    You are now in Service mode.
    Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
    1. service/factory test printout, including ink sensor check
    2. EEPROM info printout
    3. EEPROM initialization
    4. Clear the waste-ink counter
    5. Printer model setting. (more selections beyond this- leave this alone)
    After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
    Jan 13, 2008 | Canon S900 InkJet Printer
    Canon S900
    Category : Printer does not respond, or operate Description : The print head holder does not move to the center
    Close the front cover, and check the power lamp indication status (blinking or lighting). List of power lamp indications Blinks in green After lighting in green, blinks in orange 2 or more times Lights in orange Blinks alternately in green and orange, 1 time each this is the option i got on the canon website for printer head not moving to the center. but the light indication given does not match with these options.
    It is better for you to go to the above link and see what options suite your problem and follow the instruction given by the manufacturer.
    the link is :http://www.canon-asia.com/index.jsp?fuseaction=support&prod_type=bj&country=IN.
    select your model (i990) then step by step troubleshooting. follow the online instructions.
    Jan 08, 2008 | Canon I990 InkJet Photo Printer
    Canon s400 doesnt print only blinks eight times
    The tank is situated on the RHS.
    The Print Head rests there when not in use.
    Open the flap to expose the Print Head,slide the Print head across to the left.
    On the area where the Print head rests, there is a black plastic square of plastic which contains 2 narrow vertically positioned ink pads.This is also spring loaded.from underneath.
    The pad on the left is for BLACK the other Color.
    These become saturated with ink during the cleaning process.
    I suspect the Print Head has a built in sensor to detect overloaded waste tank.
    The pad can be removed this by hooking it out, sideways.
    Unless the pads are leaking ink everywhere I wouldn't remove it.
    Use Cotton Buds to soak up the excess ink. I used about 15.
    Then.....
    Turn off printer
    Hold down RESUME button and press POWER button.
    Keep holding down POWER button and release RESUME button.
    Press RESUME button 2 times, then release BOTH buttons.
    The GREEN light will flash and stop flashing.
    When the GREEN light goes out, press the RESUME button 4 times.
    Press the POWER button and the printer should turn OFF
    If not press the POWER button once more.
    My experience was when turning the printer on at a later date the POWER and RESUME lights still flashed.
    All I did was press the RESUME button and the printer operated as normal.
    Jan 06, 2008 | Canon S400 InkJet Printer
    Canon S900 InkJet Printer Logo
    213 people viewed this question
    old marine
    old marine
