Question about InFocus ScreenPlay 4805 Multimedia Projector
Bottom right corner has a tint projector bulb is good
The bottom right corner and half of the right side of the projection (i use it upside down so my problem would be on the top left if you have the projector sitting on a table.) has dimish tint, you can still see the image but barely. the bulb is good and the rest of the picture is great colorful and bright. i took it apart and it didnt seem all too dusty. i cleaned the lenses and mirrors and tried it and it still had the dimish tint. could it be a alignment problem? it worked just fine a week ago and wasnt bumped or anything.
any type of help would really really be appriciated thankyou.
  • 2,237 Answers
The colorwheel is collapsing and needs replacing. it's under a metal brace between the colorwheel and the lens. it's a 4-sided mirror tube that is glued together, and the glue wears out after a while.
Posted on Aug 17, 2009
  • jasbo
    jasbo Aug 17, 2009
    sorry! the light tunnel, not the colorwheel! i type faster than i think.
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
How do i reverse the upside down screen
You turn the unit upside down.
http://support.dell.com/support/edocs/acc/2300MP/en/usage.htm
Go to the menu.
Go to management.
Go to Projection Mode.
Front Projection-Desktop: If you want it to project right side up off a table.
Front Projection-Ceiling Mount: If you're hanging it off a ceiling.
Jun 24, 2011 | Dell 2300MP Multimedia Projector
Upside down picture
turn the projector up the other way,
or
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
Feb 22, 2011 | Epson EMP-54 Multimedia Projector
I have a KDF 46E2000.About a half hr ago i was playing xbox and noticed the top of my screen turn red from one side to the other, 1/2 in down. The very bottom of my screen is tinted blue but very...
The Optical Block is causing the problem. It has been a common problem and Sony may still have a recall on it. You can check it a 1800-222-sony. If it is not still covered, I would expect to spend 800.00 to 900.00 for the assembly plus 250.00 labor for a professional to replace it.
I hope this helps,
Skyassoc
Dec 08, 2010 | Sony Grand WEGA KF60DX100 60" Rear...
We have inherited a Sanyo Pro-X multiverse projector without an instruction manual. The projector was fixed to a ceiling but we would like to use it freestanding. When attempting to use the projector this...
You need to turn off the ceiling mode to get the picture to project correctly. This is in the Settings Menu. See page 37 of the manual which is currently available here: http://cncms.com.au/SANYO-IMs/Commercial-Industrial/plcsw30_im.pdf .
Press Menu. Then use the left/right arrows to move to the icon with the projector and screen shown. (Note: right now this row will be on the bottom of your screen and the icon will be to the left side of the row.) Press the down arrow and move to the Ceiling icon with the R. It should be the seventh icon from the upside down "Up" arrow; it's next to the Capture icon with a camera. (Normally, ceiling icon shows as an upside down R when your image is projected right-side up. There is also a rear-projector icon with a mirror image R when the image is right-side up.) Press Select and then use the arrow keys to choose the On/Off options. You may need to press Select again to save the setting.
I hope this helps.
Oct 11, 2017 | Sanyo PLC-SW30 Multimedia Projector
Our BenQ MP610 was mounted upside down for a long time. We dismounted it and took it to a funeral service to show a video and it was fine. We remounted it upside down and now the right half of the screen...
I have a benq 610 that is doing the same thing. My bulb says 564 hrs but the should last 3000 hours. I read on another site with someone having this problem replaced the bulb but it didn't help. Anyone find a fix??
Feb 04, 2010 | BenQ MP610 Multimedia Projector
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Blue tint on right side of screen.
take it down turn it on the fan may be magnetizing the frame.you may also try running a magnet over the bulb to pull the blue back into its place
Oct 17, 2009 | Sony XL-2200 - LCD projector lamp
Mitsubishi xl8u projector
go to menu and press it---press right or left arrow button and go to installation press enter.
--go down by down arrow to image reverse- use left and right arrow to adjust the image to the correct position.
Mar 15, 2008 | Mitsubishi XL8U Multimedia Projector
InFocus ScreenPlay 4805 Multimedia Projector Logo
207 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
