Question about Keurig Platinum B70 Coffee Maker
Drain inner tank - Keurig Platinum B70 Coffee Maker
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
You can't. It will always have about 2 cups of water you can't get out.
Posted on Sep 28, 2014
6 hp 4 stroke with integrated fuel tank. I use an external tank, after use It appears to still have fuel in the integrated tank. How do I drain this fuel?
Or you have to suck the tank out. Or, just turn your fuel valve onto the 'inner tank' position a run the engine.
Sep 30, 2017 | Boating
How do You change the antifreeze on a 2002 Volvo S40 1.9t
There will be a drain plug in the bottom of the Radiator so you can drain the old Coolant out. Close the drain plug and refill from the Coolant Tank on the inner fender well. Fill it with the engine off then start it up and finish filling to the full line on the coolant tank.
Mar 01, 2015 | 2002 Volvo S40
How do I get water out of the inner tank of my B60 Keurig?
Turn off and unplug the Keurig brewer. Remove the water reservoir from the machine, empty it into the sink and place aside.
Move the machine to the side of the sink with the back hanging over the sink. Locate the drain cap on the back of the machine, and remove the drain cap.
Empty the water into the sink. Do not tilt the machine more than 90 degrees while emptying to make sure all water drains. Replace the drain cap. Place the machine back on your counter or in storage if you do not plan to use it.
Oct 08, 2014 | Keurig B60 Coffee Maker
Drain inner tank
Primer defective and needs replacement.
Apr 29, 2013 | Keurig Special Edition B60 Coffee Maker
No washer fluid
Probably need to remove the tire and inner wheel well liner to gain access to the tank. You might get lucky and get at the pump without having to remove the tank. Unhook the connector and pop the pump out of the rubber grommet. If tank is full, all the fluid will instantly drain out.
Dec 02, 2012 | 2006 Dodge Magnum
Popping noise in water heater. What is it and how do I fix it?
What is probably happening is that you have a build up of minerals on inner tank lining and when unit is heat it expands the tank and the deoosits at a different rate which is what is causing the popping noise.
I would turn power off to your heater and hook a garden hose on to drain valve.Route hose to safe area as the water being drained will be hot. Open drain valve and see if you can get it draining good.If it is then shut off water supply to heater and open hot side of faucet nearby to prevent vacumn from slowing down draining. I would drain as much as I could then close drain valve and faucet and refill tank. I would do this several times to try to get all sediment flushed out.Hopefully this will help with your noise and make your heater last longer and work more effceiently. Good luck and thank you.
Feb 13, 2011 | RELIANCE ELECTRIC WATER HEATER
HOW CAN I GET THE WATER OUT OF THE INNER TANK OF MY KEURIG
You can't. This model does not have a drain, and the water will stay in the inner tank forever!
If you plan on storing the brewer for a length of time, make sure you run several cycles (without k cups) before using it again.
According to Keurig, water remaining in the tank will not damage the brewer nor cause any mold to form due to it's stainless steel inner tank.
Sorry for your troubles, and hope this helps! Happy Brewing!
Jan 07, 2011 | Keurig B60 Coffee Maker
Wont switch tanks
Try cleaning your fuel lines, fuel pumps if seperated at the tank, and fuel filters. If you have ever run out of gas in either tank, sediment from the bottom could have clogged the lines. Pump float might be stuck on an inner cavity or drain line inside tank. It may be switching, but if the float is stuck on something inside the tank, it will say it is empty when it is full. Tell me if this helps. I have recently replaced the entire fuel sys in my vehicle.
Nov 16, 2010 | 1987 Ford F 350
I cannot turn the drain plug valve to shut it off so air pressure will build up in the tank. I can remove the whole plug but not the inner valve. What direction is it threaded?
Drain plugs are standard npt thread and are removed by turning counter clockwise. New drain plugs are available at lowes for under $4. Good luck.
Sep 13, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Keurig Platinum B70 Coffee Maker Logo
669 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
