Question about Kitchen Ranges
Stove burner over heating on low setting
When i lowered heat from 4 to 3 ,the element became bright red as if on high.
  • 3 more comments
  • Anonymous Jan 07, 2008
    I turned by front element to low and it went bright red, as hot as if it were on high
  • crispy1960 Jan 20, 2008
    Same here, not sure of the cause,though my wife likes to turn the burner on high going the wrong way past off, instead of through the numbers. Does this hurt the contacts in the rheostat?
  • Pauline Livingstone Mar 22, 2008
    I also have the same problem, though also the surface of the element started to flake off as it cooled down - does it have to be replaced?
    I have also had the same problem, but also as it cools the surface has started flaking off. Does it need to be replaced? What is the surface made of?
  • Anonymous Mar 23, 2014
    starts to heat then goes to low
  • 27 Answers
The element only does what it's told. more than likely the contacts in the switch are stuck. the switch needs to be replaced.
Posted on Nov 01, 2007
How do i change the switch
Posted on Oct 11, 2008
GE TrueTemp range JBP30W0B1WW — 3 of 4 burners stay on HIGH even when set to low/medium.
as there is no make /model listed only a guess would be the switches
Dec 26, 2015 | Kitchen Ranges
Troubleshooting electrical stove
Infinite switch, it's not cycling internal contacts are welded together, make sure control it's set on low, if the heat element. stays red hot, replace control (inf. switch).
Dec 23, 2009 | Kitchen Ranges
GE electric stove problems, our stove has 3 small burners and one big burner. When we use the big burner at medium heat it does fine then all of a sudden it starts glowing bright red and burns whatever is...
Replace the infinite heat control switch for that burner. (the burner switch that you turn with the knob to select the temp setting) If you list a full model number (usually behind the lower drawer panel on the frame of the range) I can look up the part number for you. It is not a very difficult repair.
Oct 11, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
Stove top burners and lower baking element not heating up
If all the elements are dead, check for blown fuses/tripped circuit breakers. There may be some in the range unit itself in addition to your electrical service panel. If one element is completely dead on all heat settings, the control is probably bad or there is a broken wire. If it is stuck on high for all control settings or is erratic, the control is bad - replacements are readily available and easily installed.
On ranges with push button heat selection, a pair of heating elements are switched in various combinations across 120 and/or 240. If some heat settings do not work, the most likely cause is that one of the heatings elements is burnt out although a bad switch is also possible. Kill power to the range and test the heating elements for continuity with resistance meter or multimeter.
For the lower baking element:
Again, check for blown fuses in the oven or tripped circuit breakers. The remove any wiring to the bottom element and test for resistance. If you get no reading (or a very high resistance) then your element is dead.
May 09, 2009 | Kitchen Ranges
Stove top
YOUR SWITCH IS BAD FOR THAT BURNER REPLACE THE SWITCH AND YOU WILL BE GOOD TO GO
Jan 07, 2009 | Frigidaire FEF351C Electric Kitchen Range
Ge true temp stove top burner wont stay on
dont know how old unit is or how familiar you arewiththe unit, but the burner will need to heat up and cycle off/on. no matter how high or low you set the setting it will heat to a specific temp and cycle off, if hte burner remained RED all the time the glass would crak( so dont go by appearnce of burner, the glass should dictate the temp
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
Jul 17, 2008 | GE 30 in. JP340 Electric Cooktop
I have a Inglis smooth top stove, model IME 8230. One of the front has a dial for single/dual --for quick heat up. It was working fine, til couple of days ago, it suddenly went haywire. When I turned it...
The swich for the burner is bad and needs to be replaced. The glass will be fine, but unless your just boiling water you wont be abe to use it until you replace the switch.
Apr 08, 2008 | Kitchen Ranges
Kitchen Ranges Logo
1,160 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
