Question about HP xw4600 Workstation Linux Installer SATA-SAS PC Desktop
Laptop hp compaq nx6110
Can´t boot only show the windows and hp log and the key f10 when you press f10 does not go to set up menu. and sometimes ask me to set up the date and report error 123.
pls if you can help me on these issue.
i appreciate in advance for your help.
Att.: Christian Geraldo.
  • galukeny Jun 18, 2009
    no yet i wiil try to follow your sugestio.
    and come back for you.
    thanks.
  • galukeny Jun 19, 2009
    good morning tech.
    i´ve problem on printing to excel.
    when i print something all the paper come out black. but when i print from other applications like word its print without any problem.
    what might be the problem then? printer or the excel program?
    thank u for your help.
    i appreciated.
    christian gerald.
    President:
  • 828 Answers
This tim buy or change your cmos battery, its weak and ask for assistance on your technician...
Posted on Jun 18, 2009
How to change boot up menu to cd rom
when your laptop sets up press F10 that will take you to your BIOS ...next go to "ADVANCED" Next go to BOOT OPTIONS...NEXT go to BOOT ORDER.... To change the order of your boot, use the + and - keys, after you get the cd-rom first in order, hit F10....go over to the "FILE" and save changes and exit. Your laptop will restart on its own ! to change the setting back just reverse the boot order ! :)
Jan 26, 2013 | HP Compaq Presario 2100 Laptop
Power-on Password
b> If your HP Compaq 6715B laptop is lost or stolen, the power-on password can protect the valuable data on your computer. Even so, there may be times you'll want to clear that password and knowing the right procedure will make that easier. Once the power-on password is cleared, the Compaq 6715B will no longer require you to enter a password just to start up your laptop.
Shut down your Compaq 6715B and wait for it to power off. Press the "Power" button to restart the laptop. Tap the "F10" key after the Compaq splash screen appears. Wait for the setup menu to appear. Use the arrow keys to navigate to the "Security" menu and scroll down to the "Power On Password" option. Delete the entries in both boxes, then press the "F10" key. Choose the "Save Changes and Exit" option to exit the setup menu. Wait for the laptop to restart and verify that the laptop does not prompt for a power-on password. Hope this helps.
Dec 15, 2012 | HP Compaq 6715b Notebook
Only the cursor show on the screen
try enter the bios setup, check if the hard drive is detected or not. go to the boot order. set the hard drive as a first boot order. save the change by pressing f10. if it still can't log on to the window, run the recovery console... it should fix the problem
Jun 13, 2012 | Compaq Presario 700 470024-192 Notebook
I have hp d530 sff decktpo pc I can't able to go bios setting window while booting by pressing del or F10 key also pl suggest me.
Sometimes the button to get into the Settings/Bios is F1 or F2.. just go through and test each one of these out. Also sometimes just one press isn't enough, tap on the key a couple of times ot make sure the computer recognizes it.
Mar 30, 2011 | HP Compaq d530 SFF PC Desktop
HP Compaq nc6220 PC Notebook Boot sequence
1) Turn the laptop on
2) AS SOON as you see > F10 = ROM Based Setup, in the lower left corner of your LCD screen, press the F10 key.
3) You will see the headings > Main, Advanced, Security, and Tools.
Use the appropriate Arrow key to highlight Advanced. (Look at the Navigation guide to see the proper key to use)
Press the Enter key.
4) Use the appropriate navigation key to highlight > Boot Order
Press the Enter key
This will show you the Boot Order Sequence.
What you are doing now is just looking around. You haven't changed any settings yet.
If you need to change the Boot Order Sequence, you have to use the appropriate navigation key, and highlight Multiboot, and then press the Enter key. Disable Multiboot.
Save changes.
If you do Not save the changes, it will be like you have done nothing at all.
[The navigation guide shows you the key/s to press to navigate around in BIOS Setup.
You may see,
Page up/Page Down, or -/+
Left Side Arrow key, or Right Side Arrow key.
Enter key ]
If this is not what you had in mind, please post in a Comment.
Nov 25, 2010 | HP Compaq nc6220 Notebook
Reformat
(A) Try interrupting the boot sequence and telling the computer to boot using the last known good configuration. Here's how: 1) Turn the computer on, and press F8 repeatedly until the boot options menu appears (the menu items include "Start Windows Normally," "Use Last Known Good Configuration," etc.). Use the arrow keys to select "Last Known Good Configuration" and press ENTER. The computer should boot correctly.
if it dont this is the procedure given below to format the whole operating sys 1) Put the CD in the CD drive and turn the computer on. 2) As the computer begins to turn on, you should see the message "Press __ to enter setup" (it's usually F1, F2, or F4 - models vary). Press that key.
3) You should then see the Setup screen for the BIOS ("Built-In Operating System") - using the arrows, find the "boot disk priority" settings and select your CD Drive as the first priority.
4) Exit setup, saving changes (usually by pressing F10). The computer should then boot normally using the CD.
Jun 18, 2009 | HP Compaq Presario v3000z Notebook
Compaq e700 boots to windows did not load . with the options of safe mode and so on . but will not go past this . and i cant get the bios to open so i can boot from a cd what is the keys to open bios ...
upon restarting, you can go to boot selection menu by pressing function keys (hp/compaq enters most likely F2, F10 or F11) you may try it one by one.
Mar 06, 2009 | Compaq Armada E700 PC Notebook
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Laptop running slow - tried a registry cleaning program but still not performing properly. Might need to restore to factory settings. How do I do this? Laptop is HP compaq nx9005 Thanks
Should be at boot time a f10 key. On your HP screen, it's esc for boot menu, F10 for the system recovery.
You'll probably need the disk.
Sep 10, 2008 | Computers & Internet
Hp pVILLION DV 1000
This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
The following steps are for most HP Pavilion and Compaq Presario Notebook PCs. The boot order can be configured on the Advanced tab in the BIOS settings menu. The steps to modify the boot order may vary depending on the model of your computer. On most HP notebooks the boot order can be configured using the following steps:
  1. Turn on or restart the computer.
  2. While the display is blank, press the F10 key to enter the BIOS settings menu. NOTE: Some notebook PCs use the F2 or F6 key.
  3. Use the right and left arrow keys to select the Advanced tab.
  4. Use the up and down arrow keys to select Boot Order .
  5. Follow the on-screen instructions to change the boot order.
Reset the boot order to the default settings Use the following steps to reset the boot order to the default settings:
  3. Press the F9 key to reset the BIOS to default settings.
  4. Press the F10 to save the changes and exit the BIOS settings menu.
I think it will you to fix your problem.
If still have problem then tell me more about it.
Thanks
Iqbal
Mar 18, 2008 | HP Pavilion Elite M9060N PC Desktop
HP xw4600 Workstation Linux Installer SATA-SAS PC Desktop Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
