Question about Finis Neptune MP3 Player
My mac does not recognize my finis neptune - Finis Neptune MP3 Player
My windows will not accept my device. What driver do I need? Neptune Finis
Windows does not require a driver to use this device. If connected via a USB port, it should be recognized by Windows as a removable disc drive and will show up under the "My Computer" menu, or "This PC" menu, depending upon Windows version. There is no other GUI or assistant type software utilized.
Aug 08, 2016 | Finis Audio Players & Recorders
IMac does not recognize it
First connect one of wires/connector(the thing that is use to connect it to the computer) to the computer and the other end to the mp3,(also check to see if there is any bumps,loose wires, or broken parts of the connector. If it is damage it won't do any) If it's not damage, I think you go to file explorer then to my computer/my pc there should be an area where it shows all devices.It should be there. If not try going to control panel then to hardware and sounds. Look at the autoplay then click on the link for changing the settings for media and devices. If that doesn't work go back to control panel and go to devices and printers then click on add device. It should be able to recognize it.
Jan 16, 2016 | Finis Neptune Underwater MP3 Player
Why won't it recharge?
The charger or the wire that connect to the power source could be damaged, or the error can sometimes be resolved by the reset button.
Sep 05, 2015 | Finis Neptune Underwater MP3 Player
Suddenly does not recharge battery. So it stays dead
The battery may have failed suddenly and is unable to recharge.
My computer is not recognizing that the device although it did in the past
Try reinstalling the driver for your device or recovering the operating system to a time when the device was recognised
Jul 09, 2015 | Finis Neptune MP3 Player
My neptune stop playing randomly
I had the same problem after logging less than 1000 yrds.
I dont have THE solution. Nor does Fnis.They offered a discount on the new model. Im looking for a firmware flash. if I find ill let you know
May 02, 2015 | Finis Neptune MP3 Player
How do you fix a Finis swimp3 1 gb not recognized by the computer
There are a couple reason why a SwiMp3 1g will stop recognizing on your computer. Below are some things to look for and tips to try to get your unit working correctly again.
First, pull the cap of the USB and check if there are any signs of corrosion occurring on connection. If so, it is easily removed and prevented from happening again. Once the corrosion is safely removed off the USB your unit will recognize in your computer and charge correctly again.To remove corrosion try running HOT water over the USB. Scrub with a toothbrush, pick with your nail or a butter knife ect. Also, if the hot water does not work you can also try rubbing alcohol. Once most of the corrosion is off, the unit should charge and connect properly.Corrosion is actually caused from moisture and chlorine not the actual water so a way to prevent corrosion from happening again is to run fresh water over the USB and pat dry after each swim.
If the SwiMp3 is a 2g (yellow and black) contact Finis technical support for the firmware links and instructions to fix this issue. Also, you can visit www.finisinc.com/support and create a support ticket regards to your product or review walk-through tips on the product. Thank you,
Finis Customer Service
Apr 27, 2012 | Audio Players & Recorders
My computer do not recognize my swimp3
hi MIke my computer does not recognize my swimp3 surf. Can you help me
Feb 24, 2011 | Finis SwiMP3 Surf MP3 Player
Computer won't recognize the SwiMp3, I've tried pressing the reset button to no avail. When plugged in I get the slow red flashing LED
Equationgirl,
When this issues arises it is in most cases an indicator that the unit has reached its end. Please contact me via email for steps on how to resolve this issue. mmoss@finisinc.com for I am the Head Tech for FINIS, Inc.
Feb 08, 2011 | Finis Swi MP3 Player
Finis SwimP3 charging but not listed on removable disk drive.
Cyn,
Generally the computer should recognize the Swimp3 Player just like it would a flash drive or thumb drive. Remove the drive from your USB Port, press and hold the RESET button for 4 seconds and then try again.
That will usually clear up any hiccups you're having with the swimp3 player.
Plug it back in and look in My Computer again. On my Windows PC with XP it pops up and asks what I want to do with the drive.
After Resetting, you may also want to try it on a second computer to see if it is recognized. If it isn't working then, it could be the electronics, and your gift giver can check with the place where it was purchased.
I hope this helps.
Michelle
Swimp3 by Finis Dealer
May 09, 2010 | Finis Swi MP3 Player
Finis Neptune MP3 Player Logo
324 people viewed this question
Top Finis Audio Players & Recorders Experts
Are you a Finis Audio Player and Recorder Expert? Answer questions, earn points and help others
