Question about Hoover H160E Front Load Washer
Hi I have a Hoover 1400 8kg it's now coming up with an e16. I've cleaned filter and drained and now the e16 is coming up each cycle. Is there anything I can do?
4 Suggested Answers
SOURCE: Error message EC03 appears on cotton cycle after 5 minutes into wash
I found the basic instructions that came with the washing machine and found that you need a screwdriver to undo a screw to remove the filter cover. I then gradually released the filter cover to empty the water out of the machine in small quantities into a shallow tray. I was then able to remove the filter and clear it of 2 x 20p pieces and a load of gunk. I then removed the 'washable' floormat from the drum as the rubber backing from the mat was crumbling and probably not helping the filter. Filter cleaned and cover screwed back in, mat in the bin, and everything working fine since.
I did try ringing the customer support number and after pressing loads of keys to select appropriate options; confirming my address, postcode, name, date of birth, email address, mothers maiden name, what the kids had for breakfast etc, I was allowed to ask how to get the filter cover off. Apparently this is a technical query and would involve arranging an engineer to call. I declined this very kind service option and opted for a screw driver, common sense and a positive attitude. Worked for me! No blood shed, a tiny bit of sweat whilst trying to get through on phone, and only tears of joy when I fixed it all by myself.
Posted on Jun 02, 2009
FitzOriginal
  • 842 Answers
SOURCE: hoover nextra hnf2137 wont drain
Take a look at my article http://www.fixya.com/support/t3144835-not_draining_water_not_spinning Hope this helps
Posted on Feb 02, 2010
  • 353 Answers
SOURCE: I have a Hoover HNF 6167 washer which suddenly
check your pump and FILTER
Posted on Mar 03, 2010
Hoover washing machine error code16 has come on
Hi!
Baically, Hoover washing machine error code E16 means that there are problems with the insulation of the heater. this may lead to the shutdown of the circuit breaker and other random errors, but this is difficult to prove without replacing the heating element.
Apr 27, 2017 | Hoover Washing Machines
What does e16 mean please?
An E16 error code means there is a heater insulation problem which could cause the tripping of your fuse box and other random cycle errors, but it's hard to prove without the replacement of your heater.
For more information on other error codes , watch this video .
http://www.espares.co.uk/advice/0/2531/how-to-understand-hoover-and-candy-washing-machine-error-codes
May 15, 2015 | Hoover Washing Machines
Hover DYN 7164 error E16
OK Anthony! Now you have enough money to FIX the machine! LOL. First One error begets another. So forget about the errors! You are focusing on them too much! You told yourself whats wrong with this machine! OK Give Up? It is Not Draining! It is your Drain Pump Lad! Go and buy a new one, replace but remember to unplug it first. Don\'t due all that other stuff. Run the machine afterwards on a short cycle and guess what? No water!
Jan 20, 2014 | Washing Machines
Hoover dyn8164d had code E03 then E16 now E08
Hi.
These specific codes indicate the following:
E08 means that the Motor jammed or tacho fault
E16 means that the heating element is shorted or that there is a short in the circuit containing the element.
E03 This error code indicates that the water is not draining quickly enough.
Before doing anything it is worth removing the washing machine mains plug from the power outlet and leaving the machine disconnected for at least ten minutes. This will reset the codes if no faults still exist. Then plug the machine back in and select required wash routine. If all is well, well done you just needed to reset the machine. If a fault code is still showing then it would indicate there is still a problem in the area indicated.
You said you had checked that the filter was ok, it is also worth checking that your drainage hose is not blocked or
kinked.
Jan 11, 2014 | Washing Machines
Water not draining completely.
Clean the drain filters: click on filters
Jan 24, 2013 | Kenmore Dishwashers
Nextra HNWF 3135 doesn't work hole cycle, after washing stops, doesn't rinse or spin, these steps I must set up manually, because it doesn't do. I've tried to do with different programs...
Ok hot water being still there and not draining is a clog in your drain line or pump issue. I have not yet brought up the schematic to your unit but on some units there is a clean out filter located down the bottom in which you would clean out the filter careful water does come out when you unscrew the filter on other models that do not have the filter door you would remove the lower panel on the front which would give you access to the pump and the drain lines as well even though if you do find items in the filter you still need to disconnect the drain lines going to and leaving from the pump to assure that nothing is blocking or clogging the flow of water. Im glad you replyed about the hot water still being on the inside definite clog in the drain line or pump or filter issue. If you have any further questions message me back. I await your reply Thanks
Rick
Sep 25, 2011 | Hoover Nextra HNWF 3135 Front Load...
Hoover optima machine stopped mid cycle full of water. It will not drain
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Apr 01, 2011 | Hoover Washing Machines
Hoover Nextra AA 1400 spin speed - Model HNF 3147 - wont drain the water when in a wash cycle, it will drain when I turn on the drain button but is stopping halfway through a wash. Is there anything I can...
Although you say that it drains when you operate the drain button I would still gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
John C
Mar 21, 2011 | Hoover Washing Machines
Hi I have a Hoover HNF7167. Machine was on a normal wash. When the cycle was finished the clothes were extremely wet. Put on a spin, still very wet, tried the drain cycle but this didn't work. I took...
Same problem here except the filter was clean. Got a new washing machine coming tomorrow. Looks like it could be the pump BUT after reading various web sites and auction sites it looks like it may also be the circuit board.
Jan 05, 2011 | Hoover Washing Machines
Hoover H160E Front Load Washer Logo
14 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
