Question about Vizio Gallevia GV42LF 42 in. LCD Television
Buttons dont work on myvizio model e422ar - Vizio Gallevia GV42LF 42 in. LCD Television
My vizio model e422ar tv wont power on
Most likely a shorted circuit board or a defective power supply.
Feb 16, 2017 | Vizio Televison & Video
How do i can for channels on myvizio tv
You will need to buy a digital to analog signal converter, buy it on eBay, very cheap
Nov 20, 2016 | Televison & Video
I replace my tv power supply but the tv still wont stay on how do i fix this?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 03, 2016 | Vizio 42" E422AR LCD HDTV
My viziO tv model # e422ar won't stay on.It starts to power up then shuts off. off.
Jan 20, 2016 | Vizio Televison & Video
Vizio E422AR firmware update problem
see if you can rollback to your previous settings. Hope you backed up before you accepted the download. That's the beauty of restore points
Feb 20, 2014 | Vizio E422AR - 42" Class 42" viewable LCD...
Suddenly I have no sound on myVizio tv
Assuming that your remote is working and you see the on-screen volume overlay, I would check the audio settings from the setup menu. make sure it has the sound on and output to the internal speakers of the TV. If that is okay, try plugging some kind of audio device like external speakers into the output jacks on the rear of the TV. Audio rarely fails on a TV, however this could require service if you can't get any audio out of the thing.
Feb 03, 2011 | Vizio Televison & Video
2" vert. red stripe
I have worked on many Vizio televisions under warranty and what you are descriping is often a result of the X boards going bad. If the telelvision is under warranty, contact Vizio at 1-877-MYVIZIO, if it's no longer under warranty, the cost of repair is probably going to be more than the cost of a new tv unfortunatly. I always recommend buying the extended warranty's with these televisions.
Oct 04, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
Vizio vw42lf hdmi problem
The factory menu won't help you diagnose anything. If you are having issues on both HDMI ports, definitely check the cable and that the output works on the DVD player, try this on another TV if possible. If all else fails, call Vizio @ 1-877-MYVIZIO and they will send one of us techs out to replace the main A/V board, that should resolve your problem.
Aug 13, 2008 | Televison & Video
Vizio plasma tv turned off..won;t turn back on
This sounds like the main power board went bad. If this is still under warranty, contact 1-877-MYVIZIO and they will have it repaired for you. if not, let me know and I will guide you to the right part.
Jul 15, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
Vizio Gallevia GV42LF 42 in. LCD Television Logo
24 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
