Question about Carson Optical Carson Dellosa CD-104284 Rib-Ticklers Gr1 Math Strengthening- Basic Skills Jokes-Comics-Riddles
How do you pass level 4 on kick box 50 percent
2006 Chevy trail blazer. Keeps getting hot. Anti-freeze is full, overflow container is half full. Every time I turn it off can hear fluid in radiator boiling and bubbling?
Pam are you sure it's boiling? If the Antifreeze is boiling I'd think you'd see steam coming out of your reservoir as the water expands into the reservoir, but you didn't say you see anything like that.
Of course engines get hot, that's why we have the cooling systems but it doesn't sound like it's "boiling" to me with no signs of visible steam unless your antifreeze level is really low?
If it's really boiling, and you antifreeze level is good, then your reservoir should be getting filled up with expanded hot water that goes into it to catch it when it expands.
If the water isn't going into the reservoir, then maybe your antifreeze level in the radiator is too low and you need to add antifreeze?
Best to fill the radiator with the engine cooled down. If you ever have to open the radiator when it's hot, NEVER open it with your bare hand as you could get scolded with boiling water. Instead use a big thick towel to remove the radiator cap off a hot engine. Again, if you can, just wait until the engine cools then open the radiator cap.
With the engine cool, you can fill the radiator with a 50/50 antifreeze mix. The 50/50 mix come premixed 50 percent water, and 50 percent antifreeze. So you can throw that stuff straight into the radiator.
Non mixed antifreeze needs to be mixed 50/50. Some people use 50 percent distilled water when they mix it because distilled water doesn't have the minerals in it that may get stuck in your radiator. That's being a bit picky about it though. Tap water works fine in a pinch. The other 50 percent is antifreeze. You can mix it right in the radiator too, put in a measured amount of the antifreeze, followed by the same measured amount of water. The water pump will mix it all together when you run the engine.
Put the cap back on and run the engine and if/when the water "boils" it should go into your reservoir. If it does boil in go in the reservoir then yes...your engine is getting hot and the antifreeze is boiling.
When the antifreeze boils, it's probably because your thermostat is stuck closed. That means the thermostat isn't letting water circulate through the radiator to get cooled. Thermostats are cheap...no more than $30 I'd say for most cars. Changing them is pretty easy too as they are usually right at the top of the engine. A mechanic may charge $100 to change it....but it's an easy job on most vehicles requiring just a couple sockets/socket wrench.
Oct 03, 2016 | Cars & Trucks
St math how do you pass kickbox level 8?
you could pass kickbox level 8 by going on the web\internet and going to youtube and search for cheats on how to pass level 8 on kick box
Jul 18, 2014 | The Learning Company Achieve! Math &...
How to get pass st math kickbox level 9?
Try the site below.
How do you pass kick box level 9 on st math
You can also check this out.
To pass the Kick Box level four at 50%, you just move one of the blue bars down to the bottom, many squares work, but I did bottom row, second box from the right. Next, put the other blue bar in the second row from the top and the second box from the right in that row and then hit go. For more information, visit http://www.pulsitemeter.com/pass/-pass-level-kickbox-st-math.html.
May 15, 2014 | Computers & Internet
How to set microwave 50%
You have to put the cook time in first and then you press the power level button (just below the number 7 on the keypad) and put the power level in. The choices are 1 through 10. Fifty percent is probably power level 5. Once you have put in the power level, just push the Start button and it will start cooking.
May 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Is there special directions to put coolant in?
Welcome to FIxYa.com
How to Fill Coolant
If the coolant system has been flushed, first add 100 percent ethylene glycol in
the amount listed for the appropriate engine application. Then slowly add clean
water to the system until the level of the coolant mixture has reached the base-of
the radiator neck. Wait for two minutes and recheck the level of the coolant
mixture. add clean water if necessary to restore the coolant mixture level to the
base of the radiator neck
When refilling the engine cooling system, add three engine coolant supplement
sealant pellets, GM RN 3634621 or equivalent, and GM approved new Ethylene
Glycol Coolant DEX-COOL GM RN 9985809.
If the cooling system is being refilled ONLY (no flush), a 50 percent ethylene
glycol and 50 percent clean water mixture should be used to fill the system. Fill
the system until the level of the 50150 mixture has reached the base of the radiator
neck. Wait two minutes and recheck the level of the coolant mixture. add a 50/50
ethylene glycol water mixture as necessary to restore the coolant mixture level to
the base of the radiator neck.
Install the radiator cap making certain the arrows line up with the overflow tube.
Close all air bleeds. DO NOT over torque the air bleed valve. The air bleed valve is
made out of brass.
Fill the coolant reservoir with a 50 percent ethylene glycol and a 50 percent clean
water coolant mixture. The proper amount of this mixture to be installed into the
coolant reservoir is listed below:
Add 0.65 liters (0.68 quarts) of a 5010 mixture of ethylene glycol and clean water
to the coolant recovery reservoir.
CAUTION: The low coolant indicator lamp may come on after this procedure. After
operating the vehicle so that the engine heats up and cools down three times. if at
any time the "TEMP' warning indicator comes on. Immediate action is required.
Air bleed vent is at the thermostat house
Thank you for using FixYa.com
Regards, Lee Davidian
Nov 09, 2010 | 1997 Pontiac Grand Prix
I cant pass the sse or get jigilypuff
That doesn't make sense. Jigilypuff is only accsessable after you beat SSE via destroying Tabuu. The percent is baessed on how much of the level you explore.
Mar 12, 2010 | Nintendo Super Smash Bros. Brawl for Wii
Heater quit blowing warm
First ensure the coolant is not low it must be at the right level or heater won't work top off the reserve expansion tank with 50 percent water 50 percent antifreeze mixture. Repalce the thermostat, purchase a Haynes repair manual at a Advance Auto parts store for diagrams and thermostat replacement procedure.
Jan 05, 2010 | 1998 Jeep Grand Cherokee
Kenmore dehumidifier M/N 580.53650200 only runs for about 1 minute, then stops. Dehumidifying level is set to minimum (40) and it's damp in the basement so I know the air is not too dry. The fan works, the...
Well to knowledge the problem 40 percent is dry. means your basement is great. humidity should be 30/50 percent 50 grows mold. also if it runs for a min the auot shut off is activating. check this first.
Manifestr
Oct 06, 2009 | Kenmore 5365 Dehumidifier
How to get the percent
percentages are just decimals, multiply the number by the percentage expressed as a decimal:
for example, to find 50% of 4
4 x .50
to find 3% of 456, take:
456 x .03
Feb 03, 2009 | Casio FX-260 Calculator
Zenith cov. problums
THose are G2 settings they have to be adjusted to certain voltages. You can ball park the adjustment by setting conrast, ad brightness levels to 50 percent. Shut color level to its lowest setting then adjust each screen control to achieve a good black and white picture not too bright. then turn your color and other controls back up. This should get it ball parked for you. Anything further and you would need the service manual. If you'd like a service manul let me know I have a link that has them at a cheap price and provides free support with them.
Jan 14, 2008 | Zenith IQC50H95W 50" Rear Projection...
Carson Optical Carson Dellosa CD-104284 Rib-Ticklers Gr1 Math Strengthening- Basic Skills Jokes-Comics-Riddles Logo
199 people viewed this question
Top Carson Optical Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Carson Optical Toy Expert? Answer questions, earn points and help others
