Question about Canon PIXMA MP610 InkJet Printer
Wont power up
Power went out power supply good but printer wont start up
2 Suggested Answers
  • 5 Answers
SOURCE: my printer power wont turn on when i press button
Try removing your printer cartridges and then the print head from the printer. If the printer powers up with the print head removed, then the print head is either shorted or clogged. If it's shorted out then you will need a new print head (usually cheaper to just buy a new printer). If you can clean the print head without damaging it, sometimes it will work again. Usaully a good 24 hour soak in alcohol or a cleaning solution will work.
Posted on Jun 06, 2010
Zebra zm400 printer suddenly will not power up
This is a thermal label printer. Some of these have power supplies like a pc, make sure you did not trip the power off button on the back by accident. In addition, make sure the power cord is still good by subbing it out with a known working one. If it has a power supply fan, verify it moves at least - even if you have to knock it with a pencil if it wont start at all. (if it does move and no power - could be a fuse inside the power supply).
Jun 15, 2011 | Office Equipment & Supplies
All lights on wont shut down wont respond
Hello, maybe you have to do what i call hard reset, unplug it from the light then look round if you can locate any fuise on the print take it off, then allow it for 1hour and try again later
May 07, 2011 | HP Deskjet F2210 InkJet Printer
The power went out and now my canon mp530 all in one printer won't turn on...the power supply seems fine...so what could be wrong?
You said the power supply `seems fine', have you removed and tested it? there should be dc voltage present. I cant remember the voltages, I think +24VDC, but it doesn't matter, either you have it or you don't.
If the power supply is good, then the problem is most likely the logic board, and is not worth repairing.
Oct 31, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Polaroid went off and wont come back on
hello,
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck...
May 29, 2010 | Polaroid FLM-4201 42 in. LCD Television
Lexmark x75 all in one. Started with communications device error. could not print. went through troubleshooting-still wouldn't print. started printing randomly(not initiated by me). Couldn't clear print...
Hi. That's quite a problem you have there. Have your attention first on the power supply. It does get hot but it's unusual if it gets very hot. Take out the power supply (the black box behind the printer where the power cord is attached). Check the power specifications. Most of the Lexmark power supply has input ranging from 120-240 Volts and an output of 30 Volts. Make sure you're plugging it in the right voltage range. Check if you're using power surge protectors or power strip, disconnect it and plug directly into a properly grounded wall outlet. Power surge protectors can also draw power away from the printer. When everything's well, try printing again. Hope this helps.
Mar 18, 2010 | Lexmark X75 All-In-One InkJet Printer
My dryer works but wont heat up anymore.It started doing this immediately after the power went out and resumed.
you may have a faulty heat unit of fuse on that heat unit, but i suspect that your problem may be improper power supply. check with volt meter at the wall plug. if good, check heater and fuse with ohm meter.
Mar 02, 2010 | Dryers
Power surge, now wont turn on
The power supply is a separate part and only runs around $29.00, even with labor it should be less than $100.00 to repair.
Aug 12, 2009 | Canon PIXMA MP970 InkJet Printer
Pc wont turn on
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Also check the condition of the USB ports if it doesnt work and the fuse. If this doesnt work then I would recommend a repair.
Jan 19, 2009 | Computers & Internet
No Power Supply
It sounds like the printer power supply, or the Main Board has failed I'm afraid. This is a job for a Technician - but make sure you know the full cost of repair before you commit yourself - it may well be more than the cost of a new printer.
Aug 03, 2008 | Epson Stylus C84 InkJet Printer
Printer will not power on
Luciro, Sounds like the power supply went bad. The power supply could be attatched to the power cord or may be in the back of the printer. It is usually removable. You may call your local computer service guy and see if they have spare parts. The bummer about it is getting the new power supply could run close to the price of a new printer. Tim
Jan 28, 2007 | Epson Stylus CX7800 All-In-One InkJet...
Canon PIXMA MP610 InkJet Printer Logo
old marine
old marine
