Question about Kenmore 64602 Electric Dryer
Kenmore 96273100 not spinning - Kenmore 64602 Electric Dryer
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Need wiring diagram for Kenmore model # 96273100
need diagram for replacement timer
Jan 29, 2011 | Dryers
Kenmore 110 Dryer Model 96273100 won't start but I hear ticking in the timer. I replaced the PTS. Still nothing.
Replace the thermal fuse located on the left side of the main exhaust duct.
It is 1 and 1/2 inches long by 1/2 inches wide and white in color.
Sep 17, 2010 | Kenmore 659 Electric Dryer
Hello: I have a Kenmore model 96273100 dryer that is not heating. I have changed out the heating element with a new one, but the problem still remains. Is there a sensor that could be out? If so where and...
TODD, LOOK FOR A WHITE PLASTIC SENSOR NEAR WHERE THE EXHAUST VENTS OUT THE BACK. IT WILL HAVE TWO SMALL WIRES THAT GOT TO IT---PULL THE WIRES OFF AND HOOK THEM TO EACH OTHER TO COMPLETE THE CIRCUIT. PLUG IN THE DRYER AND CHECK IT. IF THAT IS THE PROBLEM REPLACE THAT FUSE. THAT GENERALLY BLOWS WHEN YOU HAVE BAD VENTALATION. GOOD LUCK.
Jan 15, 2010 | Dryers
Kenmore washer dryer age?
The age is determined by the SERIAL number. If you post back with each appliance serial number, I can tell you what year they were manufactured. Include any letter designations that are in the serial number too.
Jul 23, 2009 | Kenmore 600 7965 Dryer
Keeps Popping Thermal Cut-Out 96273100
What you gotta do is open the machine up, remove the blower/filter housing. Get the **** out of the blower housing wash out the filter portion. Then all will be kosher again Kimosabe.
Feb 16, 2009 | Kenmore Dryers
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Clothes Dryer not drying
Hello, check to make sure that the dryer is venting properly, is the hot air getting out of the vent ?. If not clear the restriction or unkink the vent then try again. good luck
Dec 16, 2008 | Hotpoint NVL333EY Electric Dryer
Kenmore 64602 Electric Dryer Logo
18 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
