Question about Philips 42PFL5332D 42 in. LCD Television
No Picture HiI have a Philips LCD Model # 42PFL5332/45 I have sound but no picture please advise. Thank You Dale
I have the same issue. What ended up being wrong with yours??
Posted on Sep 30, 2009
    President:
  • 563 Answers
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The TV should have at least a one year warranty from Philips. If you're out of warranty and didn't purchase an extended warranty plan, you'll have to pay for the repair yourself. The cost will likely be in excess of $300 and could exceed $600 depending on the exact cost of the circuit board needed to complete the repair. If you're in warranty, call the number in the back of your manual and they'll set you up for service. They will likely request a copy of the receipt to validate the purchase date.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. I hope this solution has earned a positive rating.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
RCA 42" Plasma 720p 600Hz HDTV black screen model # 42pa30rq I have sound npicture please advise thank you
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 11, 2014 | RCA 42PA30RQ 42 Class Plasma TV - 1024 x...
Philips 47" lcd tv #060958514738, it is less than
what you need to do is go into the equliser and adjust the settings till you are happy with it this is the only way to do it i would also maybe advise a surround sound system for around 70 dollars as you said your picture is great you may as well get surround sound to go with your home cinema experience the problem is it depends on ur hearing you may be able to adjust the equliser this would solve anyones problem but with some people their hearing is a bit more selective the tiny little speakers used in these systems make annoying background noisethe only thing i could advise is a surround sound sytem if you still notice it when you adjust the equliser but trust me it is not ur tv it is how good ur hearing is i hate a tv with tiny speakers
Feb 25, 2011 | Philips Televison & Video
Cannot change the picture format on Philips widescreen flat TV 32TA1000 32" LCD HD
Dear Dale,
We regret the inconvenience faced.
We would request you to share your contact details with us in order to get this issue resolved for you.
Thanks for your patience.
Regards
Philips Consumer Care
1800 102 2929
1860 180 1111
Jan 04, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
I have a philips lcd tv model 42PFL7332D/37. Suddenly, the picture lost, but the sounds works perfectly. Can anyone help me to solve this problem?
Tv turn on now,u just get a flashes of a picture only a few sec. than dies and have sound left only?Yes,than those 2 long boards that call the LCD inverter boards are dead.These 2 long LCD inverter boards job are to help the LCD picture screen panel to have a backlight to produced the picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
Nov 29, 2010 | Philips 42PFL7432D 42 in. LCD Television
My philips lcd tv has sound but no picture what is
change the backlight (cold cathode light) on your monitor.. If you are able to open the back of your lcd monitor carefully, the backlights are located at the upper and the lower part of the edge .. replace it with conventional cold cathode lights(protective tube was removed)... there are also instances that backlight was good but the ballast transformer is burnt. Replace the ballast. Its very cheap to replace that.
May 18, 2010 | Philips 42PFL7432D 42 in. LCD Television
42'' lcd turns on no picture/menu
Your tv is being attacked by electrical surges which seem very violent and has already damaged some logic controls. Please invest in a AC filter which will protect your tv from such spikes....... but first you need to get your tv serviced from the electrical damaged it has already suffered.
Nov 02, 2009 | Philips Televison & Video
42 inch LCD Philips TV - TV screen is black, but the sound comes through perfectly on all channels. Same result when a DVD is played into it. Model number 42PFL9632D/79. Plugged into a power centre...
hi sir
this type nof problem occurs mainly because of 3 issues...
1.jungle ic in D -board
2.colour wheel
3.cathgode ray tube/..please check them
thank u,,/please rate it
Jul 01, 2009 | Philips Televison & Video
Philips 37pf7320a/37 picture issues.
control boards on LCDs and PLASMA tvs are causing no picture , missing area , and other wierd symptoms , it will need to be tested to determine the true problem
Sep 20, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
The problem is the small signal board that is the video processor.
Mar 27, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Feb 17, 2008 | Televison & Video
Philips 42PFL5332D 42 in. LCD Television Logo
552 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
