Question about Canon imageRUNNER 8500 Copier
Ir 6000 error 61-002 - Canon imageRUNNER 8500 Copier
Ir 6000 error code 0061-01
It just Need Cleaning (or change) of Primary Carona Wire
Nov 04, 2013 | Canon imageRUNNER 6000 Copier
IR 6000 - Error conde E10,E12 and E14 after 5 to 10 min of starting
Error E10/E12/E14: Main cause: The main motor (M1)(M2)(M19) is faulty. The DC controller PCB is faulty.Mode of detection:0000 The clock pulse do not arrive for 2 secs or more after the main motor drive signal
For more help you can check the canon iR6000 service manual from below link:
http://goo.gl/yhuA4J
thanks
Jan 12, 2013 | Canon Service Manual For Ir 6000
Error e350 canon ir 6000
pls help canon ir6000 error E350-3000 solved the problems
Jun 27, 2012 | Canon Service Manual For Ir 6000
Ir 6000 error e00061-0001
All ya had to do was Google it.
Jun 02, 2012 | Canon imageRUNNER 6000 Copier
My canon ir 6000 is showing an error codes E000001-0000 How it will solve?
Your error code is for the fixing unit solve by checking the follwoing:-
1. Fixing lamp.
2. thermistor
3. Fixing assembly if receiving PD
5. if no Potential difference received they the power supply is not okey.
Jul 13, 2011 | Canon imageRUNNER 6000 Copier
IR 5000i and iR 6000
1 needs a new potential control sensor and pcb. this needs to be installed by a certified tech, However it can be the laser that needs replaced. The procedure isnt fun, this is a difficult problem to resolve.
2. this just needs a new thermistor sensor for the fixing unit. that part shouldnt cost more than 15 bucks. If fixing unit is worn past its life it should be replaced.
Jan 21, 2009 | Canon iR5000-6000-L1 PS Ver 1.0
Cannon ir 6000 ver 8
my copier show error for E601.Than i am change hard disk.now display only download mode.i want ir 6000 version 8 flash software. please help me....
Nov 19, 2008 | Office Equipment & Supplies
ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
Jan 26, 2008 | Kyocera RI-3530 Black and White Copier
Canon imageRUNNER 8500 Copier Logo
35 people viewed this question
old marine
old marine
