Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Station are on, can't turn off
Stations turn on, but do not tun off.
  • Intermatic Master
  • 5,089 Answers
Directions on how to set favorite stations on a 2003 pontiac sunfire radio
AM / FM RADIO
Setting Preset Stations
The six numbered pushbuttons let you return to your
favorite stations. You can set up to 18 stations (six AM,
six FMI and six FM2) by performing the following
steps:
1. Turn the radio on.
2. Press AM FM to select AM, FMI or FM2.
3. Tune in the desired station.
4. Press and hold one of the six numbered pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return.
5. Repeat the steps for each pushbutton.
RADIO WITH CD ( BASE LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 18 stations (six AM, six FMI and six FM2) by performing the following steps:
2. Press AM FM to select AM, FM1 or FM2
RADIO WITH CD (UP LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 30 stations (six AM, six FMI and six FM2, six XM1 and six XM2 (USA only, if equipped), by performing the following steps:
2. Press BAND to select AM, FMl, FM2, or XMI, or
4. Press EQ to select the equalization.
5. Press and hold one of the six numbered XM2. pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return and the equalization that you selected will also be automatically selected for that pushbutton.
6. Repeat the steps for each pushbutton.
Additional details could find in your Owners Manual; hope this helps (remember to rate this answer)
Jul 02, 2011 | 2003 Pontiac Sunfire
Not all stations will operate when turned on. Stations 1,2,3,4,5,7 work while stations 6,8,9 do not.
Look at the wiring on the timer. What are the colors of each of the wires from station 1 to station 9. Is there only one cable of wire coming in to the timer or are there two?
It sounds more like a wiring problem than a timer problem.
Are those 3 stations together somewhere?
Gary
Mar 19, 2011 | Garden
Can't set the radio stations
When you find a frequency that you
want to store in memory, press one of pre-
set tuning buttons 1through 6 and hold until the
preset number stops flashing.
The number you have pressed will flash in the
preset number indicator and then remain lit.
The selected radio station frequency has been
stored in memory.
The next time you press the same preset tun-
ing button the radio station frequency is re-
called from memory.
May 29, 2010 | Pioneer DEH-2800MP CD Player
How do i preset radio stations on my jvc hx-d77 sterio. i lost the owners manual so i know this is a stupid question.
it should be as easy as tunning to the station that you want and then press and hold the preset button you want till it blinks or flashes
Mar 08, 2010 | Audio Players & Recorders
Pioneer premier deh-500ub presetting stations
Storing the strongest broadcast
frequencies
BSM (best stations memory) lets you automatically
store the six strongest broadcast frequencies.
1 Use MULTI-CONTROL to select BSM in
the function menu.
2 Press MULTI-CONTROL to turn BSM on.
The six strongest broadcast frequencies are
stored in the order of their signal strength.
# To cancel, press MULTI-CONTROL again.
Tuning in strong signals
Local seek tuning lets you tune in only those
radio stations with sufficiently strong signals
for good reception.
% Press LOCAL repeatedly to select the
desired setting.
FM: OFF—LEVEL1—LEVEL2—LEVEL3—
LEVEL4
MW/LW: OFF—LEVEL1—LEVEL2
The LEVEL4 setting allows reception of only
the strongest stations, while lower settings let
you receive progressively weaker stations.
You can also perform this operation in the menu
that appears by using MULTI-CONTROL.
Selecting alternative frequencies
When the tuner cannot get a good reception,
the unit automatically searches for a different
station in the same network.
1 Use MULTI-CONTROL to select AF in the
function menu.
2 Press MULTI-CONTROL to turn AF on.
# To turn off, press MULTI-CONTROL again.
! Only RDS stations are tuned in during seek
tuning or BSM when AF is on.
! When you recall a preset station, the tuner
may update the preset station with a new frequency
from the station’s AF list. No preset
number appears on the display if the RDS
data for the station received differs from that
of the originally stored station.
! During AF search, sound may be temporarily
interrupted.
! AF can be turned on or off independently for
each FM band.
Apr 20, 2009 | Car Audio & Video
In my n73 the visual radio is not working.every time i tune but the tunning can't find any stations.need help
it depend on the SIGNAL STATION, you must find a specific location that the signal is very high to catch the wave to your radio station, or it maybe the antenna of your fon is weak
Apr 01, 2009 | Nokia N73 Cellular Phone
FM Radio doesn't work
it may be that the fm detector has failed or possibly a tank(tunning coil)
Aug 31, 2008 | RCA RS2664 Shelf System
Station Tunning
iv'e never seen a radio that can scane 0.1 they usually go 0.2. Normally headunits will scan if you hodl down the next button for a second. If you press it real quick it will go up .2 instead of scanning. However some don't, hope this helps.
Feb 02, 2008 | Kenwood DPX-400
Tunning -- Newbie
I haven't done this on mine yet, but on most you simply tune to the desired station then HOLD IN the preset button you want to assign it to until it blinks or some such indication of setting acceptance.
Jan 16, 2008 | Kenwood KDC-MP205 CD Player
How to set Stations
u set up the channel u want with "tun.up"\"tun.dn" press the "mem.ch" for five sec untill it flickers or beeps now u know its in the memory do so 4 any station u want
Feb 01, 2006 | Jensen SAB-55 Radio
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
41 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
