Question about Dyson DC15 Animal Bagless Upright Cyclonic Vacuum
Sweeper won't turn on and blowing dirt
Sweeper will not turn on in the upright position. When you turn it on to sweep the floor it blows dirt out instead of suctioning it up.
AceKiller
  • 7 Answers
SOURCE: No suction in upright position
Check the adapters at the bottom. They're supposed to move cleanly when you lower the handle. It's pretty obvious if there's an air gap when you lower the handle, and you should hear the suction in the air gap.
And...call Dyson...their support is great!
Posted on Nov 07, 2007
chrispurs1
  • 372 Answers
SOURCE: Suction not working in upright
Hi.
You will have A blockage in either the wand or hose, completely remove them from machine the hose unclips at the bottom back of machine,
Now switch machine on with this removed if machine sounds ok then remove the blockage from hose or wand.
If machine still poor suction & noisey with hose & wand removed check the (U) shaped inspection port for blockages.
Let me know how you get on.
http://dysonmanuals.llc.nu/index.htm
Posted on May 18, 2008
ollieboy41
  • 36 Answers
SOURCE: No suction when carpet cleaning. Also won't stand upright
Its possible that it may be blocked in the foot of the vaccum. try going through your instruction manual to locate details on how to disassemble the suction brush and connecting ducts. If you dont have one then use this link to download it. http://ubermanuals.com/node/1870
Let me know how you got on
Cheers
Posted on Jun 10, 2008
chrispurs1
  • 372 Answers
SOURCE: no suction when vacuming floors
Hi.
There are 2 types of Dc07 one is clutched & has two belts the second has only one belt going from motor to brush roller.
Lay machine on its side pull back handle as if you are to vac carpet switch machine on look to see if brush roller is spinning.
If it is not spinning unplug machine from mains supply & remove the sole plate by turning the three plastic screws to unlock position, Lift sole plate away if you have non clutched machine you will now see the brush roller with A belt going from this to the motor shaft belt may have snapped or come off so replace it.
If your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive.
If you still have no brush rotation after doing all this then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
There are service manuals available for these repairs at this site
Posted on Jul 05, 2008
SOURCE: Dyson won't go back into upright position to engage suction
The dyson.com website had a solution for this particular problem. Just press in a button in the area around the right wheel while lifting the rear of the vacuum up. This allows the base to roll forward enough to go back into the upright position. I did this and it worked. All fixed.
Posted on Jul 09, 2008
Hose tool won't pick up, sweeps floor ok
No blocks in the hose? Compress it and run a coat hanger through it.
Feb 10, 2016 | Dyson DC41 Animal Bagless Upright Vacuum...
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
I need to change my sweeper belt on my Dyson 14 Animal
When turned on and set to sweep the sweeper makes a loud noise like it has something stuck in it but the brush is turning abut not does not have a lot of sucking power. It started the other day when a blanket with tassels got caught and wund up in the brush and sucked up in the sweeper a bit. Tried to pull out while running and came out but made the loud noise. If I take off the brush then it does not make the noise when on. I think it might be the belt grooves are worn and slipping when the sweeper is in the sweeping on mode. Sorry, do not know the technical sweeper terms.
Dec 13, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Blowing out dust
The reason most vacuums blow dust is because there is little or no suction in the foot of the vac. on this model, check to make sure that the hose is installed in the recepticle on the back to draw vacuum from the floor. verify the filter is clean, and there is no obstruction in the bottom foot.
Jan 18, 2009 | Hoover U5507900 Elite Rewind Bagless...
Brush roller will not turn when I star to sweep.
maybee there is hair in it, do u know how to fix a psp that doesnt read games
Jan 15, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Dust blowing out of the side of vacuum
make sure that the filter in the dirt cup is in place.
Dec 30, 2008 | Eureka Whirlwind Litespeed 5740 Bagless...
Won't start
Did you verify that the switch did not get moved to BARE FLOOR rather than CARPET. If it is not on CARPET the brush will not spin.
Dec 12, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Your instructioons do not say how to get the sweeper to move so that you can sweep under the sofa.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=682948
Generic problem for all Vacuums
Your instructions do not say
Posted by ohmizes on Jun 18, 2008
Your instructions do not say how to get the sweeper to move so that you can sweep under the sofa.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. there are not too many sweeper that actually get under the sofa when most sofas go almost to the floor and some uprights go flat and some sweepers but if the height of the sweeper or vacuum exceed the height of the sofa underneath then either one or the other cannot clean under the sofa if the height exceeds the sofa height limit without leaning your sofa back or lifting it up to clean.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 18, 2008 | Vacuums
Dirt Devil M084600 Dynamite
If it is only 2 months old, then it is under warranty, take it in for warranty repair. There may be a circuit breaker on it, usually on the back at the bottom, it there is, push it to see if it has tripped.
Feb 25, 2008 | Dirt Devil M084600 Dynamite Bagless...
Dyson DC15 Animal Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
