Question about Elna Sewing Machines
Noise when sewing
Clunking sound when using machine, think it's coming from spool
    Problem Solver:
  • 10 Answers
Have you cleaned and oiled it, they get noisy if not oiled
Posted on Nov 14, 2014
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 22 Answers
SOURCE: Jammed spool pin on a Brother CE5000 PRW sewing machine
Try a little oil and let it set befor pulling.
Posted on Nov 10, 2009
Testimonial: "Awesome solution- thanks so much!"
  • 96 Answers
SOURCE: kenmore model 158.17810 sewing machine noise
that is a fifty fifty chance you have to take. It may be something minor rubbing or you could have a slightly bent shaft underneath making noise
Posted on Dec 13, 2009
  • 11 Answers
SOURCE: How do I fix thumping/clunking sound?
make sure your needle is facing the right way, some needles if you look at the front and back you will see a groove side and a flat side sometimes it is hard to tell the difference depending on needle style.. hold it up to light and look at it from the side the difference will be slight but you will see a difference groove should face the back or if your presser foot is out of wack (lol so technical terminology) it could cause needle breaks and noise you can detect damage to the presser foot if this is happening.... only other thing i can suggest is to make sure bobbin is securely snapped into the housing if not it can cause problems with the needle picking up the bobbin
Posted on Apr 08, 2010
SOURCE: I purchased a White Sew
We had the same issue. The needle was facing left/right instead of front/back. Once I unscrewed the needle and repositioned it so that I could thread it front/back, I was able to get it to catch.
Posted on Dec 06, 2010
My berinina sewing machine is making a clunking noise but the stitches look fine . how do i find out whats causing the noise?
first ck that your needle isn't hitting the bobbin !! that's the #1 thing that happens to make funny noises !! use a flashlight and view needle turned by hand as it slips into center of bobbin !! then also ck that darning lever isn't part ways engaged that will do it too !!
Aug 19, 2016 | Sewing Machines
My singer curvey 8763 is making clunking noise when start sewing and then stop working
possibly out of time with the bobbin . take in to a shop for checkup
Feb 05, 2015 | Singer Sewing Machines
Husqvarna Viking - Thread gets caught up on the underside of material when trying to sew.
There are two things that come to mind that may be causing the problem.
1) Change the needle, for it could be bent even thought it may not look it. (This is the most likely cause).
2) Have a look just inside and check if any screws have come loose. This has happened to me. (Even the repair man did not find it.
Nov 29, 2013 | Sewing Machines
A "clunking" noise when stitching
some sewing machines have more sounds than others, check to make sure the bobbin is setting securely in the bobbin case,and if that doesn't
solve the noise problem then ,it would be a good idea to have the machine serviced
Dec 31, 2012 | Sewing Machines
Loud clunking noise when sewing. . . then it starts to stutter then it stops & gives me an error. It doesn't occur when reverse sewing though
try these suggestions
change the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not damaged or warped
make sure the bobbin is not over full
make sure the bobbin is inserted correctly into the bobbin case
make sure the bobbin case fits securely into the machine unless it's
a drop in bobbin
if these suggestions don't help then the machine may need to be
checked at a repair shop
Sep 11, 2012 | Brother CS6000i Computerized Sewing...
My bobbin thread keeps breaking and the machine starts sewing then it slows down and the thread breaks. It makes a terrible noise.like a clunking sound.
change needles
make sure the needle is inserted correctly
check the top thread tension--3 or 4 usually is good
some needles & thread do not work togeather-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
if none of these suggestions work then you should consider taking it to a repair shop to be checked
Nov 17, 2010 | Singer 3116 Simple
Apr 08, 2010 | Brother CS6000i Computerized Sewing...
Kenmore model 158.17810 sewing machine noise
Dec 10, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
66 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
