Question about Epson WorkForce 600 All-In-One InkJet Printer
Epson workforce 545 prints on half letters - Epson WorkForce 600 All-In-One InkJet Printer
3 Suggested Answers
SOURCE: epson workforce 600. says it has paper jam but
FIXES FOR EPSON RX600 PAPER JAM
Posted on Jan 18, 2010
cns assoc
  • 677 Answers
SOURCE: I have a new Epson Workforce 30. It suddenly
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Mar 23, 2010
Leaving a space when printing
there is always 3mm margin in all sides of paper. Its Normal & you can not remove them.
If there is more than 3 mm than you should use nuzzle check.
Mar 28, 2015 | Epson Workforce 545 Wireless All In One...
It says paper size does not match the paper source setting, Print on Letter No Yes Remind later
Check paper tray it might have a movable plastic thing that sets the paper size . Check printer properties on settings - printers - Epson Workforce printer properties. Check software you are printing from that it has page setup and printer setup paper size set correctly
Mar 02, 2015 | Epson WorkForce WF-3640 Wireless Color...
Epson prints on short way of paper
change printer settings on PC in control panel/printers/settings
Nov 11, 2014 | Epson Workforce 545 All-in-one Inkjet...
Communication Error with Epson 545 workforce all in one printer
Go To Below official Epson Printer Page For Your problem, Communication Error
Still having Problem Then follow Us For Epson Printer Support
Feb 21, 2014 | Epson WorkForce 545 Wireless All-In-One...
Workforce 545 's ink pad is at the end of service life
As this remains unanswered but still picking up hits the Workforce 545 is basically the same design as the Epson BX525WD which is supported by a Printer Potty SoloLX kit for which installation is covered in this link
Instructions for installing waste kit on BX535WS
The error itself won't be resolved unless you find suitable reset utility such as the WICReset utility although this is a pay-per-reset solution. You can get both waste kit and reset bundled up if you want or you can go DIY to figure your own fix...
Nov 05, 2013 | Epson WorkForce 545 Wireless All-In-One...
Epson workforce 545 is printing & coping blank
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 18, 2013 | Office Equipment & Supplies
Printer will not feed paper
Print paper has to make a 180 degree turn in thr printe- is this thick, stiff paper
Jan 05, 2013 | Epson WorkForce 545 - Multifunction fax /...
How do i fix a printer jam?
First step would be to remove the paper tray and see if you can see the paper that is jammed.
Nov 04, 2012 | Epson WorkForce 545 Color Inkjet Wireless...
Epson workforce 610 printing improperly
have the printer being discussed in this thread.... the Epson WorkForce 610. I just encountered the same issue, many lines were missing from the page that I wanted to print. Ink levels were fine, but every time I try to print the same thing, the same lines were missing. I read through the solutions mentioned above and I decided to see what the printer had in its maintenance toolbox on the printer itself.
Here's a solution that worked for me!
1. Go to "Setup"
2. Under Setup, select "Maintenance"
3. Select "Head Cleaning"
The printer does the head cleaning automatically. Print another page, all of the lines should show up!
Simple, no need to buy another printer or clean the ribbon...
May 01, 2012 | Epson WorkForce 600 All-In-One InkJet...
Epson WorkForce 600 All-In-One InkJet Printer Logo
12 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
