Panasonic h43 rubber gasket has come away from the bottom of the drum will this let water throw to the bottom of the machine
  • 145 Answers
SOURCE: I have a Neptune 2000
All washers still have some water in them at the end of the cycle. If you wipe the door boot down with a mild bleach and water solution this will keep it from getting mold. If you don't do a bleach load on a regular basis I would run a hot wash with 1/2 cup bleach and 1/2 cup powder cascade with no clothes once a month to keep the machine cleaned out. I also always leave my door unlatched when not in use.
Posted on Apr 23, 2008
  • 61 Answers
SOURCE: Kenmore Elite HE3t door leaking (Model 44936)??
If the unit leaks during use with a constant drip from the 6 o'clock location between the seal and the glass on the door the solution is to change tha door seal. it is quite difficult to do I would recommend you call a local service company.
Posted on Dec 18, 2008
SOURCE: HE4t kenmore washer rubber drum gasket not attatched.
Removed the top and Front reinstalled the counter balance. the rubber gasket has a 1" tear in it which I patched with a rubber tire patch for now. Two of the locking nuts for the leveling of the machine were loose it went out of level causing the machine to rock and probably caused the counter balance to loosen up. My daughters come in from collage and over load it on weekends which adds to the machines demise. All have been warned.
Posted on Jan 19, 2009
  • 132 Answers
SOURCE: Rubber Gasket Torn
IT IS EASY :
1- IF YOU SUCCEED TO TAKE OLD gasket YOU CAN DO IT FOR THE NEW ONE
2- IT IS JUST A RUBER PEICE SO YOU CAN
3- LIKE YOU SAID a {spring securing OR CLAMP } USING A SMALL TOOL {SCREWDRIVER OR BLAYER } TO DISCONNECT THIS SECURING PIECE IN FRONT THEN
4- FLAP THE RUBBER TO INSIDE THE DRUM THEN
5- THERE IS ANOTHER SECURING PIECE HOLD THIS RUBBER WITH DRUM INSERT YOUR TOOL AND DISENGAGE THEN
6- NOTICE THE TRIANGLE IN THE RUBBER PIECE
IT IS THE MARK TO CONNECT AGAIN IN RIGHT WAY OR YOU CAN MARK BY A PEN
7- REVERS THE MANAR
YOU WILL REACH
GOOD JOB
Posted on Jun 18, 2009
  • 3230 Answers
SOURCE: I have a kenmore washer 700 series. Water is
Yes its true that this washer not worth repair.... Better you can go for a new washer..
I have a question - is there any error code on the display control?
thanks
Posted on Jul 07, 2009
Where is the H43 error sensor located in my panasonic na14av1 machine
H43 Leak detected to base of the washing machine
  • Check for source of the leak
Aug 15, 2016 | Washing Machines
When I start the washer, it fills just fine with no problems but once it starts the cycle, it gushes water from the bottom of the door
Check the bottom of the plastic inner door. If there is a crack or a gouge, have it replaced. Also check the rubber door boot for holes above the water line
May 09, 2014 | Maytag Neptune MAH5500B Front Load Washer
I have panasonic eco drive washing machine model NA-FS14x1 have error code H57 how to repair
Unscrew the back of the machine to look and see if there is any water in the base of the machine.
How old is your machine? If it's new I'd exchange it for another one like the LP or even Mag tag-
It's not easy to fix these machines and finding the real problem is sometimes a night mare.
The Panasonic error codes are difficult to find, but 'H' faults are generally faults which may or may not be repairable. Like the sump pump -or motor.
The other codes are like this: U11 indicates machine unable to drain. Blockage between drum and drain pump?? Blockage of drain hose??
U13 indicates unbalanced load. Many modern machines suffer from this, but may be related to problem causing U11 fault.
H43 indicates an internal water leak reaching its detector in the machine base.
Like any washing machine, they are great until they go wrong. The problems are usually related to the after sales service.
I hope something helps here-just my 2 cents worth!
Dec 23, 2012 | Dryers
Error code H43
Is this Panasonic?
If so, H43 code refers to an internal leak. A small amount of water on a sensor will bring up this error code.
Try to remove the back of the machine after unplugging it from the electricity and dry up any water, then try again.
If this doesn't work, contact Panasonic about this issue. They're aware of it because many users encounter this error. Tell them about the problem, they should send you an engineer to fix this.
Thanks for using FixYa - a 4-thumbs up rating is greatly appreciated for answering your free question.
Jun 06, 2011 | Washing Machines
I have a panasonic NA-168VX2 washing machine which i had put in yesterday and today it is flashing up with error code H43 what should i do?
Thank you for using FixYa. The error code H43 refers to an internal water leak. The leak is obviously only a small one or you would have noticed. A small amount of water on a sensor will bring up the error code. A simple solution is- remove the back of the machine after first un plugging it from the electricity and dry up any water then try again.
I hope this has been of some use and would appreciate your "helpfull post" if it has
Thank you
Mar 05, 2011 | Panasonic Kitchen Appliances - Others
Jan 17, 2009 | Kenmore Elite 45986 Front Load Washer
How to fit a drum rubber on a wf000
disconnect from mains. remove top
undo clamp that holds gasket to cabinet and peel away from cabinet.
there is a clamp holding rubber to tub - usually like a giant hose clip.
undo this clamp and peel rubber away from tub.
lubricate the slot in the rubber that goes on to the rim of the tub with washing up fluid
starting at the top, insert slot in rubber onto rim of tub.
work you way round in both directions pushing the slot onto the rim. this is a knack and you will have to be patient.
when completely on, refit clamp.
on outside, fit rubber onto cabinet (this is easy) and refit outer clamp.
test for leaks on rinse as water level is higher.
water will be foamy till washing up fluid washes away
Sep 29, 2008 | Hotpoint Washing Machines
Rubber piece
If you mean in the bottom of the gasket between the drum and the door the hole is to allow water to drain from the gasket to prevent standing water which will smell .
Aug 08, 2008 | Malber P25 Front Load Washer
Leaking Breville Esp6
sorry this is out of my leage someone elso will have to help.
May 16, 2008 | Breville ESP8XL Espresso Machine
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
