Question about MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker
My 2003 key pulls right out
My 2003 ram 1500 keys come out in all positions ..It sucks....
  • firestomper2 May 11, 2010
    you need your ignition colum looked at.
  • 245 Answers
Replace the ignition switch to take care of this issue.
Posted on Jun 26, 2009
I have a 2001 dodge ram 1500 and i changed the starter, crank position sensor, tried a different ignition but the ignition still would not turn the engine over... Im thinking about wiring up a push start...
unless you have the key fob also,you need a new ignition switch,with key fob and key with a chip in it,the switch turns on the fuel pump when the chip is recognized,take it to someone that knows what they are doing,you CANNOT hotwire it.
2001 dodge ram 1500 key fob Bing
Mar 09, 2015 | 2001 Dodge Ram 1500 Truck 2WD
2000 Dodge Ram 1500 turns over but wont start, I've checked the air filter, and listened for the fuel pump, and checked the spark plugs for a spark, but I still haven't figured this one out.
Check your Fuel pump turn you key to the on position and remove your gas cap put your ears right up against the hole and get someone to turn the key on and off a couple of times you should hear a noise if you don't your pump is gone.
Sep 26, 2013 | 2001 Dodge Ram 1500 Truck 2WD
2007 dodge ram 1500
Do you have power to the injectors and coil with the key switch in the on position ?
Jul 01, 2013 | Cars & Trucks
Trouble code P 0513 2003 Dodge ram 1500
This Code means incorrect immobilizer key. If this is a battery powered combination chip and remote, the Battery voltage may have dropped to change the frequency of the part.
But since it only happens at certain positions of the keyswitch there may be a problem in the keyswitch reader. I read about most problems denying a start or failing to continuing to run after starting. Your exact problem was not listed.
There are several components for this system. There may be moisture in the key or condensation from the cold. Put key in closed jar of rice to dry it out.
Plase rate my info.
Jan 23, 2013 | Cars & Trucks
2003 dodge 1500 ram engine will not turn off after i turn off ignition and take key out
My guess would be a stuck relay or something with the key switch.
You could pull the relays to see if one will kill the engine, or check for power at the key switch.
Aug 21, 2012 | 1996 Dodge Ram 1500 Club Cab
How do you replace the ignition switch in a 2006 dodge ram 1500
First take off the cowling around your steering collumn It should be only 2 screws on the bottom of your steering collumn. You won't be able to get the bottom half all the way off, but you can get to what you need to do.
You need to pull the bottom half away from the bottom as far as you can without breakng it. Underneath where your inginion switch is there is a little round hole, a bit smaller around then a cigarette. You need a probe or something L shaped to stick up in there i believe a standard pen will work as well. Put your key in the ignition and turn to the on position. Put the L shaped probe in the hole in the bottom of the ignition, turn the key to the on position. While pushing up on the probe and your key in the on position you should be able to pull the old ignition switch out fairly easily. You might have to jiggle and wiggle it a little.
When you put the new one back in, just line up the spring loaded tab (the one you pushed in on at the bottom of the ingnition to get it out) and have the key in the on position like it was when you took it out. It should slide right back in. Turn your key to the off position and your key should slide right out. Put the column back on and your all done! I hope all goes well
Mar 16, 2011 | 2006 Dodge Ram 1500
03 Dodge Ram intermittent blower fan operation
The wire that connects to the ignition switch that goes to the A/C blower fan is misplace upon connection.And its not grounded to any other lines.
Jul 28, 2009 | 2004 Dodge Ram 1500
Problem with starting my 2003 dodge ram
My father has the same problem with his 2001 Chrysler Sebring, the key will go into the ignition switch but wont turn. Called the dealer and seems the tumblers inside the ignition have gotten stuck, the solution... put the key in the ignition and tap it gently with a hammer (plastic tip if you have it) and it worked fine. Not sure what the guys at Autozone are pull but on a Ram 5.7 Hemi there are individual coils, not one, I should know I also have a 2003 Ram 1500 and have changed the plugs (not fun)... I have a code scanner (Hypertec) and when I've gotten a check engine light I check it with the scanner. Turned out mine had a problem with the air sensor in the intake. $15 part fixed the problems. Good Luck.
Apr 18, 2009 | 2004 Dodge Ram 1500
Problem starting my 2003 dodge ram
no if you took it to autozone obviously you have a good ign coil.im sure you have tried turning the wheel at the same time you turn your key. other than that i would replace the lock cylinder and key.
hope2help shack
Hoe to remove the ignition switch in 05 ram 1500
Step1 Disconnect the negative battery cable from the terminal on the battery. Remove the upper and lower steering column covers by unscrewing or unclipping them. Step2 Remove the steering wheel by lifting off the center cover, disconnecting the horn wire and removing the retaining nut and washer. Make a mark on the steering wheel spline and the wheel itself so you can line it back up precisely. Pull the steering wheel straight back to remove from the shaft. Step3 Take off windshield wiper and turn signal switches by pulling them off as you did the steering wheelmag-glass_10x10.gif and disconnect the wiring. Slide the spacer sleeve off of the steering column. Step4 Unscrew the ignition switch mounting screws. Pull out the ignition switch. Disconnect the wiring connector from back of the ignition switch. Simply loosen the tabs and pull it out. Step5 Insert your key into the ignition. Turn the ignition switch to the locked position. Depress the retaining pin with a small screwdriver and turn the key to the Off position to free the cylinder. Once it is free, turn the key to lock position and remove the key and key cylinder. Step6 Install your old key cylinder into the new ignition switch assembly. Make sure the contacts in the cylinder and assembly line up. Reattach wiring to ignition switch, slide it into place, screw in mounting screws and reassemble steering wheel and switches.
Feb 21, 2009 | 2005 Dodge Ram 1500
MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker Logo
74 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
