Question about Kenmore Sewing Machines
Trouble installing bobbin case on consew 2053r-1
SOURCE: Threading a consew RB-1 sewing machine
Send an email to me at dbjamie@msn.com and maybe I can help. I'd need more info. on your ploblem. I'll start you off with these two things assuming that your difficulty is with the bobbin as you state "underneath & threading". Notice the white painted dot on the the machine arm at the drive pully. Notice the white dot on the pully. Allign these two. Tilt the entire machine head back so that it is resting on the word verticle finger stop (or get underneath the machine). Bobbins are loaded by pulling the small chrome lever w/ your thumb & index finger (this is an unlocking latch). Do so moving it outward to about 90 degrees. Usually while you do this the holder and bobbin just pop out. To install u just snap then on. It's placed when u hear a click. For more info email me directly. Doug
Posted on Jun 18, 2010
  • 54 Answers
SOURCE: thread stuck around the bobbin housing on my
try cleaning all that you can out of the bobbin case then try very carefully to bump it backward (opposite) with the hand wheel . Be careful not to knot out of timing. sounds like you have thread in between bobbin case and hook
Posted on Aug 17, 2010
SOURCE: consew 230 machine, how to dis engage needle to wind bobbin.
I have an old Consew 230B and need an operating manual can any one help me. Thank you
Posted on Mar 23, 2011
SOURCE: needle hits bobbin case on consew 206rb
try these sites for video's & information
youtube
ehow
sewusa.com
fixsewingmachines.com
Posted on Apr 16, 2012
SOURCE: Consew 255rb-1 Problem is once a while the tread jame under the bobbin case. After sewing as started it can go on or if you stop and re-start it could be OK or it will start jamming again and have to
change the needle
clean under the needle plate & in the bobbin area for lint & loose threads
Posted on Apr 19, 2012
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
I am having trouble threading the bobbin on a consew cp 206R. I can't figure out what to do with the thread to anchor it in order to load the bobbin. I usually use an origional electric Singer machine that...
If I understand your trouble, I put the bobbin on the machine ready to be loaded with thread. I feed the thread from the inside of the bobbin through one of the holes to exit on the outside. I hold tight onto the thread and start up the bobbin feed drive. once it is covered by several layers of thread, you can let go since the thread will not slip out.
If I did not understand your question, here are a few sites that show how to thread the Consew CP 206R as well as how to "reset" the timing if you happen to get a jam while sewing. http://www.youtube.com/watch?v=PIKml4yGLSc
https://www.google.com/search?q=consew+cp+206R.&oq=consew+cp+206R.&aqs=chrome..69i57&sourceid=chrome&es_sm=0&ie=UTF-8
http://www.youtube.com/watch?v=H-pL2vISk2k
If you want to download a manual: http://www.devicemanuals.com/productsupport/Consew_CP206R_manual.html
Good Luck and Happy Sewing!
May 18, 2014 | Singer 3116 Simple
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
Needle hits bobbin case on consew 206rb
youtube
ehow
sewusa.com
Apr 15, 2012 | Consew 206RB
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
I need a manual for a model 230 consew, I recently bought it from a friend, I want to learn how to thread it, and wind my bobbins, can you help me, unable to find one
You can go to the consew official website and download the PDF file for the 210 model. It's the same as the 230 r-1 (which i have). I found this information by calling the consew headquarters. You can also download a PDF with the full parts list for the 230 model specifically. This link may help http://www.consew.com/default.aspx?pageId=4
Apr 06, 2011 | Sewing Machines
Thread stuck around the bobbin housing on my
Apr 06, 2010 | Consew 339RB-3 Sewing Machine
I recently moved and can't find the belt to my Consew 226. Having problems finding a replacement. Can you help!
Go to www.consew.com and download the parts list for the 224 Consew. It's the same as the 226 for parts. Or, go to www.diamondneedle.com. They have nearly every part you're likely to need. I got bobbin case screws, a hook, some metal reusable bobbins, and some needles, all at very reasonable prices.
Oct 16, 2009 | Consew 226R-1
Thread braking
Check the condition of the top pressure discs and the bobbin case tension. Check for wear in the hook - is the bobbin case seated correctly? Check the tension spring in the bobbin case. I doubt timing has anything to do with the problem. Unless the hook's picking up the top thread a little late, thereby "spearing" the thread. The hook could be catching the thread loop too late. Sounds to me like there's a parts or a small adjustment problem. You don't mention thread or needle size. That's another area of concern at times.
May 22, 2008 | Consew 226R-1
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
