Question about Garden
Cracked brass fixture - Garden
Rewire a three-way switch that was wired knob and tube?
I can help u with this but will need to b able to walk u thru it,
Feb 26, 2015 | Electrical Supplies
Install 67888
67888 is a brass-and-black colored exterior single wall light fixture with black and white wire and bare ground wire.
If this is a new light fixture, and you are running a wire to it, copy following links to see basic wring diagrams.
http://waterheatertimer.org/How-to-wire-switches.html
Aug 02, 2012 | Hardware & Accessories
I have an older model 841 bath wide base fixture that has stiffened up to a point it takes a man to open and close it. It looks very much like the current 800 fixture except it has a porcelan base. i...
Below find the diagram for your faucet....
The handles are held on by a set screw either under a cap in the center of the handle, or on the side with an allen head screw
one the handle is off, you unscrew the eustecheon cap and can get into the cartridges that most likely needs cleaned or replace.
You can contact Newport brass for parts and info below...
Contact InformationNewport Brass is committed to providing the highest level of customer satisfaction. We look forward to assisting you. Please contact us using the information below.
US Customer Care Center
Aug 23, 2011 | Newport Brass Plumbing
How do I wire a single light to a on/off switch
Add a comment and say what wires you have in case following answer misses your mark.
As a general rule, there is one cable that comes from breaker box.
There is another cable that goes to light fixture.
Each cable has 1 Black, 1 White and 1 Bare ground.
So you have 2 Blacks, 2 Whites and 2 Grounds.
White wires twist together and are covered by wire nut.
Black wires each connect to a different brass-colored screw on light switch. In any order.
Bare ground wires connect to green screw.
If light fixture has wires, then black goes to black and white to white, and ground to ground.
If light fixture has screws, then black goes to brass screw, white to silver screw, and ground to green screw.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on circuit.
Jan 03, 2011 | Electrical Supplies
Cracked rear tail light fixture
find the replacement at the wreckers/junk yards
Sep 13, 2017 | 2006 Honda CR-V
"Mintcraft" faucet any good?
Hi, If you asked me, I bought from amazon/ebay depending on reviews... (that way you cant buy something not good). so.. take look Were doing more than just throwing away the key . I hope this helped you. Cheers
Apr 26, 2010 | Mintcraft L5860-03-07 ATLANTIS POLISHED...
Old Victorian Light fixture needs to be repaired. I think soldering the broken parts together would work, but I've never soldered brass parts (only simple electronic motherboards). Anyone out there that...
to solder brass u just use regular solid solder with a tin of acid flux, but u must use a Small butane fueled pin torch or a large high temperature solder iron to do the heating (this really depends on the size of the material being soldered), the brass must be clean and bright, use steel wool for this these small torches are available from any hardware store, they fuel up with butane cartridges used for refilling cigarette lighters
Jan 18, 2010 | Welding Tools
How to wire so switch controls outlet? We hooked it up. The switch controls the light fixture but no power is going to the outlet.
You should run a short "jumper" wire from the same screw that the light fixture's wire is on to the brass screw at the outlet. If you put the jumper on the OTHER side of the switch, the outlet will be always on.
Sep 26, 2009 | Leviton 5225ISP Switch and Outlet
I have a hampton bay ceiling fan & light,carriage house 52", white. the light fixture is loose, it feels like it is ready to fall. is there any way of thghting so it will not fall
Depending on where it's loose it would be tightened with the nut on the shaft/pipe going into the bottom of the fan or, tightening the screws which fasten the housing to the light fixture is -- these will be in the side of the lower cup which connects to the fan housing.
Charlie
Aug 31, 2009 | Hampton Bay 52 In. Polished Brass and...
Need to know wiring diagram for cooper single pole lighted switch
well lets see on one side you should have two brass screws that would be to interupt your lead to the fixture then you either have a brass and silver screws on the other side or you have black and white wires the black or brass is always hot the silver or white is neutral does that answer your question if not hit me back with a description of what your switch looks like
Jun 14, 2009 | Cooper Lighting Lighted Switch
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
