Question about RTO Ho Herpa Freightliner Truck Tractor
Fail 04 3216 eec61 freightliner 2011 cascada
My truck acts like not getting fuel keeps turning over no start
    New Friend:
I cannot understand anything you asked
Posted on Apr 14, 2014
Truck just shuts off i changed fuel solenoid and starter solenoid it runs great when cold then just shuts down like you turned off the key
have the fault codes read
some engines with electronic fuel injectors will do that if one ore more of the injectors fail when they get hot
Sep 19, 2015 | Freightliner 2007 BUSINESS CLASS M2 106
I got a code on a 2011 freightliner coronado. Engine 000 SPN003556 Aftrtrmt Inj 18. any ideas?
Found the list of fault codes: https://www.empiretruck.com/content/upload/files/DDC-SVC-BRO-0115%20fault%20codes.pdf
3556 18 DOC Outlet Temp Low (Low Temp Regen)
Which revealed a lot of information that is above my pay grade, starting here:
https://ddcsn-ddc.freightliner.com/cps/rde/xbcr/ddcsn/518-14.pdf
Apr 19, 2015 | Cars & Trucks
Can a battery fuse keep a 2011 Hyundai Sonota from starting
No if it were the fuse it would not turn over it may be a security feature if u have it on that model
Aug 29, 2014 | 2011 Hyundai Sonata
97 chevy 2500 truck; 350 vortex; trouble starting
Seem like your fuel pump can't keep up the pressure when engine is started. If you have a pressure regulator that isn't into the pump assembly i would change it if not then your going to need a new fuel pump assembly.
Dec 31, 2012 | 1995-1997 Chevy 1500 Truck Ignition...
Need to see fuse box in p11 primera 1999
For fuse box diagram and related diagrams click the link below:---
Fuse Box Diagram? http://schematicsdiagram.blogspot.in/2012/04/1996-chevy-cavalier-cluster-fuse-box.html
Freightliner fl112 fuse box diagram? http://technoanswers.blogspot.com/2012/01/freightliner-fl112-fuse-box-diagram.html
Where is Fuse box located?
http://howtobyme.blogspot.com/2011/12/where-is-fuse-box-located-on-2002-honda.html
Toyota Fuse Box Diagram? http://technoanswers.blogspot.in/2012/06/toyota-hilux-surf-fuse-box-diagram.html
These will help.For more help keep updated.
Thanks.
Nov 06, 2012 | Cars & Trucks
1985 grand Marquis acts like not getting fuel to start but if I pour gas directly into throttle body starts right up and runs what could be problem
Runs on the gas you pour in, or keeps running until you turn the key off ???
If the fuel pump relay fails, you would have to crank the engine until you get oil pressure to provide power to the fuel pump.
Do the injectors spray when you are cranking it ? Have you checked fuel pressure when the key is turned to start ?
Jul 11, 2012 | Cars & Trucks
1991 pickup 22re motor starts for 2seconds and then stalls or turns over and no start. Once in a great while will start and stay running but doesnt run smooth. Acts like its running on two or three...
hav you check your plugs after it happens? a black plug will tell it has too much fuel, a wite plug no fuel at all, leads tours a faulty cold start injector, you can also try to keep it alive with carb or throtle cleaner if idles you not getting enougth fuel. keep in mind compresion test, and valve adjust, this engines require it has a regular service.
good luck
Apr 15, 2012 | 1991 Toyota Pickup
My 2000 chevy s10 pickup won't start it acts like it wants to but wont
scanned wont pick up failed fuel pump--or clogged fuel filter check and test wiring --relays--connections and fuses
Jul 16, 2017 | Cars & Trucks
RTO Ho Herpa Freightliner Truck Tractor Logo
277 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
