Question about Pentair 2 hp WhisperFlo InGround Pool Pump WFE28 ()
MY 1000GPH INTEX FILTER PUMP IS DISMANTLED BUT I CANNOT GET THE IMPELLER OFF THE SHAFT
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
There should be a backwards threaded screw take that off then hold the back of the motor shaft and unscrew the impeller regular threads
Posted on Sep 07, 2014
Pump is running but not pumping
Possible broken impeller from motors shaft, common Intex problem.
So...
As a technician of more than 30 years in the Pool/Spa Industry, And with the rise of these Quasi-Pool or Spa wannabe's, popping up everywhere, I have seen SOOOO Many frustrated customers and owners of these units, with very similar problems and non working pool and spas!
Unfortunately these Intex products are Mass Produced by the Gazillions in China, and then unleashed on the general American public? Who believe that it will work and last, but come to find that they usually don't last a season! Some die sooner, and yet some do last a little longer. AND, there are no available parts to repair! They make you buy a complete replacement control unit! So if your controller panel has a bad button, no available part, whole new control system! Heater stopped working? No available element to replace, whole new controller! Pump not pumping water or leaks - yep, No impeller or shaft seal available, Whole new pump, Etc. etc.
So many customers of mine, regret their purchase.
So...To try to help, and maybe get them back into a splashing good time or... Back in Hot Water..
I tell them ... SQUEAK! And do it loudly and often!
Maybe they will listen and OIL that Sqeak?
look here...
http://www.intexcorp.com/contacts
then if if budget allows, don't buy another Intex component, if you get no help from them, get a Real Pool Pump and if possible, mate it with a Real Pool Filter, not just toys.
Something like this...
Hayward S144T1540S Pro Series Top Mount Sand Filter 14 Inch 4 way Valve...
Jun 10, 2015 | Intex Automatic Salt Water System for ...
What is psi for Intex model 637r
Will it pump with no filter?
Did you replace with new filter?
do you have valves? Are they open?
Pump could be bad, broken impeller!
Mar 27, 2015 | Intex Pool & Spa
How can I get my impeller to work when I plug it in it does nothing?
The impeller shaft could be binding. Also, the pump could be unable to spin the impeller at all, in which case you may need to replace it.
Jul 13, 2014 | Intex Krystal Clear 1600 GPH Model SF15110...
Intex pump flowrate drops
you may have a dirty filter. Check your filter to be sure. Remove the filter from the pool equipment and see if it runs fine for longer period of time. The filter would be the only restriction in your Intex system for water flow.
Rod
US Parts Center
Jan 17, 2013 | Intex 1000 Gallon Swimming Pool Filter...
What is an impeller
the impeller is the most important part of the pump when motor kicks on impeller spins pulling and pushing water through it check to see if it has something glogged in it also try backwashing filter...
May 30, 2012 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
Intex Krystal Clear Filter/Pump Model 635 replacement parts for the pump
my intex 635 pump impeller is broken i need a replacement part. i do not have the money for a new pump.
Jun 30, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Is the intex 4000 pump any good.... do you lots filters...
I have the new 4000GPH pump and its awesome! The pump itself needs modifying just a bit. As for your pool, get rid of the plunger valves. They restrict the flow by about 1000GPH or more. There is a plastic grate in the inlet side of the pump. I just took a small file and sharpened the leading and trailing edges to smooth things up. The biggest thing is with the plunger valves. I modified some PVC fittings so I can use 1.5 inch ball valves. When my pump starts up, you see the water moving. I no longer have problems with **** settling to the bottom of my pool. Oh, and it will run an automatic cleaner with ease.
I dont recommend using the 400GPH pump with hoses smaller than 1.5 inches as there will be too much pressure and is likely to cause problems.
Mar 07, 2009 | Intex 4000 GPH Filter Pump
Pentair 2 hp WhisperFlo InGround Pool Pump  WFE28 () Logo
41 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
