Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Gaggia brewining problem
Hi my gaggia platinum vogue does not brew cos the green light machine is "ready" is on but the coffee button isn't on
EsWorld
  • 1618 Answers
SOURCE: User Manual for 90800 Gaggia Coffee Maker
Check out this site they have a wide selection of manuals. http://www.espressotec.com/store/pc/Support-Manuals-c12.htm
Posted on Sep 16, 2009
EsWorld
  • 1618 Answers
SOURCE: Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Posted on Nov 26, 2009
Testimonial: "Thank you very much for your quick response. I've ordered the steam switch. "
  • 109 Answers
SOURCE: My gaggia titanium says it's brew unit is blocked
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
Posted on Feb 22, 2010
  • 3 Answers
SOURCE: Gaggia Platinum Vogue Built in Grinder
Just use the whole bean. Using pre ground coffee through your grinder will screw the blades completely.
However if you have a decaff option that allows you to put coffee directly into the brewer that would be ok........just dont put it into your hopper that feeds the grinder.
Posted on Mar 09, 2010
SOURCE: On my new Gaggia Vogue the eclamation mark is
3 things I can think of...
1. if the steam/water knob is not exactly at the off position my exclamation mark flashes.
2. have you primed the water circuit?
3. taken the brew group out and put it back in?
good luck. it's a great machine once it's working!
Posted on Dec 26, 2010
No coffee brewed
clean and service brew unit as per instruction manual
Jan 03, 2013 | Gaggia Platinum Vogue 90800 Espresso...
Does anybody know how to get rid of flashing red exclamation light on my gaggia platinum vogue?
It does not need to be descaled as this is not the descaling indicator...The water circuit needs to be primed. Turn the knob to the water drop and drain water into a bowl. Hold the water drop button down while this is happening until the red light turns green. Presto.
Oct 07, 2011 | Gaggia Platinum Vogue 90800 Espresso...
On my new Gaggia Vogue the eclamation mark is flashing all the time and it has never produced any water through the steampipe. Done all the suggestions in the manual but no succes. Water enough, coffee...
Nov 26, 2010 | Gaggia Platinum Vogue 90800 Espresso...
Mar 03, 2010 | Gaggia Platinum Vogue 90800 Espresso...
Gaggia plat vouge
It sounds like the brew unit needs to be lubed because it is not turning with the gears on the motor drive.
Nov 11, 2009 | Gaggia Platinum Vogue 90800 Espresso...
There seems to be a lot of water in the dump box.
The amount of water will vary with the strength of coffee selected.
On the front control under the cup symbol is 3 beans,pressing these will increase strength .
All bean lights on strong.
All details should be in the manual or available online.
Oct 21, 2009 | Gaggia Platinum Vogue 90800 Espresso...
What does it mean when the red exclamation mark light is flashing?
Either you need to prime the pump, or the brew unit is not in correctly, the steam knob is not in the right position, the tray is missing.
Sep 20, 2009 | Saeco Odea Go
Sep 15, 2009 | Gaggia Platinum Vogue 90800 Espresso...
Gaggia platinum leaking from milk island
The problem is the steam valve leaking.
It does not close fully and leaks.
You will find that when you turn the knob is seems very loose.
A service is required.
Jun 23, 2009 | Gaggia Platinum Vogue 90800 Espresso...
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
20 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
