Question about Frigidaire Washing Machines
Mold in front door gasket
We just noticed that we have a significant case of mold in the front door gasket. Is there a best way to clean that mold away? We have tried to wipe it using bleach and that does not seem to be doing a great deal of good.
  • Frigidaire Master
  • 5,323 Answers
TRY LETTING VINIGAR SET ON IT OVERNIGHT
Posted on Mar 31, 2015
SOURCE: Sour Smell in clothes
I had this same problem as everyone (especially with a front load washer) has. After research... I have found a product that I now tell everyone about. I found it on the web called 'smellywasher.com'. A nontoxic product by Laundry Specialist sounded good. I was willing to do anything to cleanup the smell and mildew from my machine. So I gave this a try and it REALLY WORKS!. Just as they claimed, my washer now smells clean and with no real effort from me. Now I just do a periodic cleaning and I will never have to worry about this again. (and bleach will harm the gaskets). I also use vinegar in the fabric softner dispenser instead... this insures my clothes are rinsed well and works to soften my laundry. Hope this helps and pass the info on..... THIS REALLY WORKS....which you cannot always say about products.
Posted on Jan 11, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt series washing machine front gasket mold
Hi.
The quickest way to solve your problem is to fit a new door seal.
Then each time you finish a wash, clean and dry the door seal.
At least once a week, depending on how often you wash, do a hot wash with powder, but no clothes in.
This is called a maintenance wash.
This should solve your problem.
The door seal probably got into its present condition because of several different reasons, namely:washing at too low a temperature-not using sufficient powder- amongst other things.
the mould is actually living bacteria, not a pleasant thought
Please positive feed back if you find this helpful
Cheers and good luck
Posted on Nov 24, 2008
barkencoa
  • 3463 Answers
SOURCE: mold on rubber gasket front load washer
It is a long process trying to explain how to solve your problem, but if you go to the following site, you will find an in depth article on how to solve the problem.Just navigate to the article you want.
www.washerhelp.co.uk.
This should help you.
Posted on Dec 07, 2008
marka19
  • 1430 Answers
The door seal need to be pulled almost inside out to be a able to thoroughly clean it. I usually use a 50-50 mix of bleach water but other cleaning products like oxyclean may work better. After cleaning run a load with no clothes in it to remove any residue. Now if the mold has gotten deep into the rubber and still looks blackish after cleaning it will get moldy real soon and replacement will be the only solution. The key is from day one to leave the door open as you do and also wipe the door seal with a towel after each use. Not to defend frigidaire but most of the other brands have the same issues, some worse. If you need to replace the door seal or if the wire ring pops off when cleaning here is a link that should help http://appliancehelponline.com/washerdoorseal.html
Posted on Jul 13, 2010
Testimonial: "Did not know we could replace the seal. yes, the mold has stained the gasket. Thanks, will check this out."
blueextc3221
  • 15935 Answers
SOURCE: foul odor
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%4
Posted on Sep 28, 2010
How to clean the mold of the rubber
If you have mold on the rubber gasket of your Duet front loader, I can almost assure you that you have lots of mold in other places in the machine. Front loading washing machine are almost hermetically sealed and if the door is left closed, the inside just never dries out. This is just a perfect environment for the growth of mold and other fungi. Once mold gets established in materials such as rubber gaskets, it can be very difficult if not impossible to eradicate because mold grows "roots" deep into the pores of the material, making it very difficult to remove. Eradicating the mold may result in damage to the gasket since my "cure" is to paint on full strength bleach on the moldy surfaces with a brush or sponge (wear gloves). Repeat if necessary. You may wind up having to replace the front door gasket to get all of it. It will probably take more than one application to fully eradicate the mold from the VISIBLE surfaces of the rubber gasket. If you remove the detergent dispenser and peer inside the opening, you may see a lot more mold inside the cavity. If you see mold inside the detergent dispenser cavity, imagine what the rest of the inside of your machine must look like. Do you run a periodic cleaning cycle as advised in the operating manual? Have you read the operating manual? Do you use the absolute minimum amount of HE (non foaming) detergent? Factory instructions for cleaning the door gasket call for mixing 3/4 cup of bleach into 1 gallon of warm water and applying this mixture to the affected gasket area, let stand 5 minutes and wipe the area down with a dry cloth. My experience has shown that this is a grossly inadequate concentration to deal with a deeply seated mold problem in the door gasket. To run the cleaning cycle, the factory calls for 2/3 cup of bleach to be added to the bleach dispenser. "Use of more than 2/3 cup of bleach will cause product damage OVER TIME". Initially, I would definitely consider using a whole lot more bleach than recommended and run two or more consecutive cleaning cycles. Then EVERY USE OF THE MACHINE: wipe the door gasket and all the creases and folds dry with a sponge, remove the detergent dispenser and wipe the cavity dry, leave the drawer out to dry on a clean towel, leave the door open, buy a cheapy plastic box fan and place it inside the machine and let it blow air around the inside of the machine for an hour or so to dry it off quickly, run a cleaning cycle at least once a month. If this sounds too involved or difficult, I would suggest switching to a top loading washer that is much less prone to develop mold growth as air can circulate in these types of machines to a much greater extent than the front loaders.
Sep 12, 2014 | Whirlpool duet Washing Machines
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    What is the best way to clean the mold off the door gasket
    I use to have the exact same washer. When Maytag was Maytag before the merger with Whirlpool they suggested using a mixture of bleach and Sunlight power dishwasher detergent. You can also usually find a washing maching cleaner like Tide washer cleaner or Washer Magic. Run it on the longest and hottest wash cycle. Stop the maching during the wash portion and wipe the door seal down well with a rag and ware gloves. Also make sure that the little drain hole in the center of the bottom of the door boot (gasket) is not not blocked up with lint or anything. If your mold problem is really bad you might have to call a repair man out to replace the gasket and clean inbetween your inner and outter tubs.
    Feb 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
    The gasket around the opening from the front door gets nasty. How do I best clean this?
    a little bleach in water works well and kills the mold. be careful not to tear the gasket, easy does it. a old tooth brush also helps. some of the spray cleaners also work
    Feb 04, 2011 | Frigidaire ATF6000ES Front Load Washer
    My miele w3033 has mold in the rubber gasket. wha...
    hi,
    you can purchase a cleaning product to run through the machine but white vinegar on a 95c wash also works.don't put any clothes in it though. if it has eaten into the door seal too much you can easily have them replaced. always leave the door open after each wash for about half an hour to let it dry out otherwise a damp environment is perfect for bacteria to develop. lots of hot washes and the door open prevents this.
    May 19, 2010 | Miele W2240 Front Load Washer
    How do I clean the front door gasket area?
    Here is a tip that I wrote about that problem...it tells you how to clean your washer and also how to prevent it from coming back...
    I will also include a tip I wrote on washer maintenance...
    http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
    http://www.fixya.com/support/r4312694-washing_machine_maintenance
    heatman101
    Asker's Testimonial " heatman 101 Just wanted to say thanks for helping me with the mold
    Apr 07, 2010 | Frigidaire ATF6000ES Front Load Washer
    I have mold growing where the rubber seal is around the door. I have a ine year old and I am worried about washing his clothing.
    A nicely moist area,
    ...could try to kill all the mold with dilute chlorox (put some in a spray bottle--can also use on feet after the gym to prevent contamination from athlete's foot/feet)(or the shower mold killers which usually just have chlorox [sodium hypochlorite or similar]); then in future leave the door ajar when not in use so the area can dry (assume front loading), and if it is the large gasket style that still leaves a moist area behind itself--could put a wedge like a popcicle stick or few to allow air behind the gasket.
    ...any mold that is visible and therefor in contact with the clothes going in and out, should be easily removed...there should not be any mold in the washing compartment as the bleach and hot water used for whites would always kill the mold; so the only contact point is at the exterior (cleanable) when removing finished clothes.
    ..likely there is plenty of mold exposure in his environment beyond this----this is nothing like the problem with flood contaminated walls/floors and unseen mold that could spew forth significant amounts of spore load.
    Aug 09, 2009 | Washing Machines
    Mold on gasket; front lint trap clogged; washer reeks
    run an all hot water cycle using hilex bleach should kill the smell and mold
    May 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Mold on gasket
    The mold is common with the front loaders all you can do about the mold is wipe out the water that is in the gasket after a wash and leave the door open. DO NOT TRY TO CLEAN WITH BLEACH. The bleach will make the gasket weak and cause it to rip and then cause a leak.
    Mar 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Washing Machines Logo
    27 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
