Question about Sewing Machines
How to install design plates in model 158.18130 sears kenmore sewing machine
SOURCE: Kenmore R/W 19000 Model 385.93200
You will have to purchase the EasyImport software that comes with the ata card. it is about $150. Right now I am having trouble with the program recognizing and registering imported images. In Vista the program shuts down after registering an image. I am searching for the software to see if there is an update to use with Vista. I really liked it with XP, but right now I am not too pleased.
The format is a JEF format. Tell the machine (vista) to only open the JEF with this program if you have it. I have had less problems with HOpe this helps.
Anne
Posted on Apr 29, 2008
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
SewTechWayne
  • 186 Answers
SOURCE: Kenmore Sewing Machine Model #158.18032
You probably have a bind in the feed dog mechanism. If you can remove the covers and manually force them down you will see the hinge points that need to be oiled.
Unplug first!
Good luck.
Posted on Jan 30, 2009
  • 980 Answers
SOURCE: I need a manual for a Sears Kenmore sewing machine model 148.231
Try www.sewing-machine-manuals.com and click on relics and don't be put off by the word relics
Posted on Oct 24, 2009
Looking for a manual for sears kenmore portable sewing machine model 158.13200
Search the internet for:
Manufacturer + Model + the word "Manual"
Nov 22, 2015 | Kenmore Sewing Machines
I have been looking for 3 days! Still can't find the manual for the Kenmore Sewing machine model #148.13110! Please can someone HELP terryrp@icloud.com
Unfortunately, the manual is not available for free. Sew USA, http://www.sewusa.com , has various Kenmore sewing machine manuals available. I believe the manual you need will cost $10: http://www.sewusa.com/Sewing_Machine_Manuals/Kenmore_Manuals/Kenmore_1311_Instruction_Manual.htm .
I hope this helps.
Dec 02, 2014 | Kenmore Sewing Machines
I have an older model Kenmore Sewing machine model # 158 12310. I was told by a local sewing machine repair business that it was not worth the money to have it cleaned and oiled. The machine works fine.I ...
Do you have your owners manual? If not, go to Sears parts direct and buy one. This will tell you where to put the oil. Now you probably will want to get under the throat plate, just use a small stubby screwdriver and take off the throat plate, usually you find something that looks like felt and thread. There is not felt, so clean that little bugger out. Sometimes you can find tips on the internet for lubricating and cleaning. I think the repair person was not very knowledgeable to say that, the older machines made better than anything today. Take care of it, I still have my first sewing machine, an Old Kenmore and it is my work horse, It will sew anything that my new expensive machines cannot handle.
Dec 28, 2010 | Kenmore 15516 Mechanical Sewing Machine
E1, E2 error messages after needle breaks. Cleaned everything as good as possible, still getting message. I have a Kenmore Model 385.19233
Theirs a problem with the fuse on those machines. The e1 indicates that a fuse has been blown. check out the link for more details.
http://www.sewingmachineryrepair.com/forums/index.php?topic=79.0
Aug 31, 2009 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
