Question about GE Heating & Cooling
Ge asw12 compressor shuts on and off
Compressor keeps shutting off after only a few seconds
oscarn
  • 109 Answers
SOURCE: cooling
Check if the condensar ( outside fan unit) is getting enough free ventilation. IF there is no free air flow you will mostlikely be triping the unit due to short cycling. Ie the unit is pulling its own discherge air causing the compressor to trip due to high back pressure
Posted on Sep 07, 2007
  • 619 Answers
SOURCE: thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Posted on Jan 08, 2008
SOURCE: Compressor fan
The fan should be running if the compressor is running.Check fan capacitor and check windings in fan.Check to see if fan is short to grond.If the fan is not running the compressor is no cooling off.
Posted on Jul 11, 2008
SOURCE: maytag M6Q10F2A window A/C unit about 4 years old
buy a new effecient A/C
I had the same problem but it was my bedroom one so I swapped out my living room A/C into my bedroom and put the new one in the living room.
Posted on Jul 17, 2008
  • 17 Answers
SOURCE: compressor keep running in off position
you could have a relay or contactor inside the unit welded closed, therefore compressor will keep operating when unit is off. replace compressor contactor.
Posted on Feb 10, 2009
The compressor of my GE PFE 29PSDASS floor model comes on for a few seconds then goes off. The lights remain on. What is wrong?
Refrigerator Repair Help ' Appliance Aid
www.applianceaid.com > ... > Refrigerator Help Section
I heard a sizzling noise inside my freezer section and it looked like something ... Myfridge makes a bang noise when it shuts off; My Frost free fridge will not run at all; Myfridge is making screeching/squeak noises; My GE SxS fridge door has ... an amp meter, each compressor is rated in running amps ( see model/serial tag ...
GE Refrigerator Repair Online Manual ' General Electric ...
www.appliancerepair.net/ge-refrigerator-repair.html
FREE ONLINE GE refrigerator repair manual - Diagnose and troubleshoot ... to know basically how the bloomin' thing works, and then get on with fixing it? ... Chapter 5: GErefrigerator problem: Refrigerator is not cold and compressor is ... Do you have somequestions that you would like to ask a professional GE repairman.
Dec 17, 2015 | GE Refrigerators
Aew12aq compressor will not shut off
u have defected thermostat or the comp. could'nt exist the desired temp, don't hesitate to e-mail me on a.refaei@eajb.com.sa
May 15, 2013 | General Electric 12,000-BTU EnerStar...
Things in freezer melt and re-freeze
Your condenser fan motor at the compressor is either filthy or needing to be replaced. Air flow is pulled over compressor to keep it at a good operating temp. If the fan cannot pull air across compressor it will over heat and shut down on overload. Imagine working in yard on hot summer day and wearing a dust mask over your mouth and nose. Your body shuts down more needing more rest. Same thing with refrigerators, they have to be able to breathe properly also.
Jan 27, 2010 | GE Freezers
Not cooling
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Dec 17, 2009 | GE Profile PSC25PSWSS Stainless Steel...
Maybe is it not compressor fault?
If you are 100% sure the compressor is not shutting down, then the expansion valve is bad, assuming that model has an expansion valve.
If a functional compressor stops producing cooling, then the refrigerant flow has stopped. Without refrigerant flow, heat transfer does not happen, and the attempt to pressurize the gas causes the compressor to get very hot.
It's possible that the valves in the compressor are shot, as well. If it's a thermostatic expansion valve, try applying heat to it to coax some flow through it.
Oct 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Outdoor A/C unit fan
If the fan and compressor are shutting off. its possible its cycling on a low pressure switch. probably low on freon.
or you have a low ambient kit to keep pressures up during low outdoor temps while ac is running just the fan will shut off, however thats not a typical thing to have a residential system
Sep 20, 2009 | Heating & Cooling
No cold air. compressor works for seconds and shuts off
Replace the compressor, if it quits running after a few seconds, it is more than likely your compressor causing the problems
May 29, 2009 | 1992 Honda Accord
Cycling compressor
The pressure switch will shut off when the set pressure is obtained. Usually about 100 to 120 lbs. If the compressor stops at lower pressure than mentioned you may try to adjust the pressure by looking under the switch cover for adjustment screw/nut.(no more than a few turns) Increase pressure by increasing spring tension. Quick cycling is usually caused by air leaking from tubing, drain valve or check valve. After compressor shuts off unplug it from the outlet and spray soapy water on all fittings and drain valve. Repair leaks and test for quick cycling, however the compressor should reach 100-120 before shutting off. Some small compressors have a thermal reset but that usually takes a few minutes to reset. Pressure switch is defective if it shuts off before setting mentioned. Enjoy
Dec 11, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Heating & Cooling Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
