Question about Rosewill RCAD-11003 USB3.0 Adapter For IDE/SATA Device
Rosewill RCAD-11003 hardrive not recognized
Computer will not recognize SATA harddrive
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: My macbook pro doesn't recognize
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Posted on Jun 24, 2011
The hard drive in my Astone AP360-T PVR (THIS IS NOT A COMPUTER) is no longer recognized. Has been working for years now it's as if it no longer exists. What can I do if anything?
Usually if a harddrive is suddenly no longer showing and has been running for years it has reached the end of its lifetime. You can check whether this has happened:
In case you have access to a computer or laptop you could take the harddrive out of the AP360-T PVR and connect it to the computer instead. (This can be done either with a SATA-2-USB adapter or directly to the onboard SATA controller.) If the computer recognizes the harddrive the problem lies with the AP360-T PVR. In case the drive does not get recognized it has died and needs to be replaced.
Jul 12, 2017 | The Computers & Internet
Can Rosewill RCAD-11003 be used with windows 8?
The RCAD-11003 is a hot plug and play device which is supported by windows 8 natively. It WILL work on windows 8.
Oct 17, 2013 | Rosewill RCAD-11003 USB3.0 Adapter For...
I need to know what hardrives are compatible with my computer
You can buy any HDD/SSD as long as it has some sort of SATA connection. The differences between SATA, SATAII, SATAIII are mainly speeds. But all will be recognized by your machine.
Nov 07, 2012 | Computers & Internet
My WD elements ext hard drive was working fine earlier, now all of a sudden it is not registering on either of my computers. What can I do to access my files?
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Aug 11, 2010 | Western Digital Elements powered by WD 320...
Computer does not recognize Portable Harddrive
restart you system then plug it into different port if still not working then change the wire of ur hardrive...
Plz dont forget to rate
Sep 07, 2009 | Electronics - Others
HARD DRIVE PROBLEM.
If the first drive will get recognized on another computer but not yours it would lead me to believe that the controller on your motherboard went out. But the part about the non os drive not getting recognized at all leads me to believe that drve went out. First i would definately take the drive somewhere to have the info transferred or if you can hear it spin up you might get lucky and it will work after you get your os to boot. it wouldn't hurt to have it backed up though. Before you do anything too drastic try to get your hands on another drive and see if you can get your PC to recognize any drives, if not then you will need a new motherboard.
Dec 23, 2008 | Computers & Internet
Trying to install a new sata harddrive but win xp does not recogn
check bios and set the parameters for the new hard drive. These parameter should be found on the hard drive itself
Dec 10, 2008 | Dell Computers & Internet
500g harddrive
It broken. if you want your data back youl have to spend alot on data recovery.
Jul 24, 2008 | Western Digital My Book Essential Edition...
My Computer doesn't recognize Ion 320 GB Harddrive
Well if its lighting up, then the drive is receiving power, or the enclosure atleast. Forget that case, extract the drive, and seek out something more reliable and more solid. Preferably an aluminum enclosure with no fan.
seek out Weibetech.
Oct 15, 2007 | IOGear ION (GHD335C160) 160 GB Hard Drive
Rosewill RCAD-11003 USB3.0 Adapter For IDE/SATA Device Logo
246 people viewed this question
Top Rosewill Computers & Internet Experts
Alun Cox
Jim Thurston
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
