Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Turn off dryer
ARM7L 125 S
I have an ariston washer dryer combo. today I turned it on to do a wash cycle. the knob no longer clicks or shows the times of other cycles. I've turned it off and on a few times but nothing helps
Ariston armf 125 washer dryer combo - YouTube
? 4:14
www.youtube.com/watch?v=zPtG5Q3qQ3Q
Oct 23, 2010 - Uploaded by troykm Rinse cycle. Correction - it does do 3 rinse cycles!! :-)
[PDF]Instruction Manual - Ariston Appliances
aristonbrand.com/media/WDG-8629-User-Manual-19510586801_AU.pdf
WASHER-DRYER ! This symbol reminds you to read this instruction manual. ... from its packaging. 2. Make sure that the washer-dryer has not been damaged.
Sep 22, 2015 | Washing Machines
Arml 125 ariston
you can get this at www.ariston .co.uk
Aug 28, 2012 | Washing Machines
We have an older dryer (ultimate care - super plus capacity) 12+ years old. It no longer "heats". Drum is still turning. I am assuming it is a thermostat - how much do those cost to repair?...
When it doesn't heat it could range from the timer to the heat element to the thermostat or even the motor so it could be as little as $125-350 to repair.
Aug 12, 2011 | Whirlpool Dryers
Need wiring diagram for electric cord attachment
Wiring Option1: Wiring Option2: OLDER HOMES AND ELECTRIC DRYERS NEWER HOMES AND ELECTRIC DRYERS range%203-wire_cord_connection_250.jpg range%204-wire_cord_connection_250.jpg
NEMA 10-30R 30AMP-125/250VOLT
NEMA 14-30 30AMP-125/250VOLT
This system can be configured depending on what your wiring situation is.
For example you could be faced with the following situations:
converting an old 3-wire outlet
to a new electric dryer
converting a new 4-wire outlet
to an old electric dryer
Feb 01, 2011 | Amana ALE643RB Electric Dryer
I am re-wiring an outlet in my garage that normally goes to an electric dryer. I want it to have 30 amp 120V. Do I just leave off the red wire? And don't they make a 4 hole recepticle that will accept...
Yes on the red wire. I don't know of a 4 hole receptacle but that doesn't mean it doesn't exist. Do you also plan to change your breaker? You'll need to disconnect the red wire and cap it.
Here's a link to some instructions on how to do your project. Good luck!
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/Change-existing-220V-dryer.htm
Mar 14, 2010 | Reliance Controls L1430P 30 Amp Plug
Dryer hums but won't turn and there's a loose yellow wire.
the belt probably broke. if you can pop the top up and look at drum that turns and dont see a belt around it then you would need a belt. remove top panel by removing two to 3 screws behind dryer on top rear. turn off power first. then you will be able to see drum. part # for belt is 661570 roughly 19.99-29.99 thats to do it your self. if you call a local servicer you are looking at 75-125 labor plus part. hope this helps and gives you a general idea of the prices you are looking at to repair
allbrandsappliancerepir.com.
Sep 16, 2009 | Kenmore 73952 Gas Dryer
Electric heating elment.
Somewhat,
I have a ref. thermometer, round metal type I got a Wal-Mart that I check the dryer temp at the discharge. I bent the metal bottom so I can lodge it in the discharge pipe, turn the dryer on and watch the temp. Normally on high heat it will go up to 140-150 and cool down to 120-125 then cycle back on.
Jan 24, 2009 | Estate EED4300SQ Dryer
Dryer exhaust temperature
on high turns off at 155 medium high 150 medium 140 low 125 extra low 105 all theese are plus or minus 10 degrees
Feb 15, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer starts to work and then stops working after a few minutes
doesn't usually happen so quick but may be a blockage in the air duct. take top off. if i remember right, duct runs across the back to the dryer fan. check for lint build-up. if poor air flow, an overheat stat will cut off the dryer
Apr 02, 2007 | Indesit WA 125 Front Load Washer
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
20 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
