Question about Toshiba 56H80 56" Rear Projection Television
Prjector red bulb burned out - Toshiba 56H80 56" Rear Projection Television
How to change projector bulb
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 07, 2014 | Office Equipment & Supplies
Wont power on
Sounds like you need a new bulb, or possibly new lamp. The red/green flashing is the warm up to get the bulb ready. If it's shutting down after that, instead of turning on, it means the bulb isn't working - that's a common thing, for the bulb to burn out. Possibly the lamp's bad, but that's much less likely.
Sep 01, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Need manul for Projetor RM-PJAW 10
I will be glad to send the manual to you by email if you need ,
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Jan 20, 2014 | Sony SUPERLITE PRJECTOR VPLEX120 5 PACK...
I pickd up my prjector while it was on. i turned it over an i head a POP and all the lights went on so i pulled the plug now it wont turn on... what is the prob?
The POP sounds typically means the project bulb blew (just like a typical light bulb). You can take it into a repair shop to have the bulb replaced.
Feb 25, 2011 | Dell 2300MP Multimedia Projector
My timer is running and I have swapped the black and red pins to turn on and off the lights but the lights do not come on? Were do I find the model number?
My model number is on a sticker inside the door.
I have the 300 watt, and it matches the total wattage of my bulbs.
A lot of people ask for replacement Malibu tripper pins on Fixya, so your tripper pins might be worn down. I cannot find Malibu trippers, even on e-bay. And the new timer clocks are electronic.
Check your circuit breaker to see if unit is getting electricity, including GFCIs in bathroom.
Plug hair dryer in same plug as Malibu to see if there is power
Brush a wire across the screw terminals to see if there is any spark going to bulbs.
It's unlikely that all the bubs failed at once, but if power pack shows spark on the terminals, the bulbs should be getting electricity.
If a couple bulbs burned out, the power pack can burn out the others.
Unplug power pack until you get bulbs replaced.
Unfortunately if the power pack stops operating, it is broken.
I did find some tips to help folks preserve their power packs:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Nov 11, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
No power
if there anre no leds lit on the top, the power supply needs to be replaced.
Jan 19, 2010 | ASK Proxima C160 Multimedia Projector
The picture is red, does this mean a bulb has burned out ?
there will be three bulbs, red blue and green. if the display is red, than one of the contrasting colors is shot, more likely the blue.
Jun 18, 2009 | RCA D52W19 52" Rear Projection Television
2 red lights on, no blinking. And no bulb on is the bulb burned out?
i think ur sytem in stand by mode / pcb complaint related to microcontroller.
May 27, 2009 | Mitsubishi XL8U Multimedia Projector
Picture has a green outline
your convergence ic's and possible low ohmage reisistors are at fault.there the large ic's that start with stk
Sep 10, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Blub goes out during use.
Most fans have a sense line to detect the fan is working properly, Possible the sense circuit has failed. The unit should not start if it thinks the fans are not running. Possible thermal problem with the sense circuit, since your unit starts up then stops.
Mar 10, 2007 | Toshiba TLP-ET1 Multimedia Projector
Toshiba 56H80 56" Rear Projection Television Logo
16 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
