Question about Element ELCFW329 32 Class LCD HDTV - 720p, 60Hz, 3x HDMI - ELCFW329 R
Imy tv wont pick up cable
I put it on cable and then auto scan but it wont pick up any chanels.I tried another TV on the same cable and it worked fine
3 Suggested Answers
ineedabin50249
  • 755 Answers
SOURCE: i have an Element ELEFT502 50 HD Digital tv. I am trying to connect my cable line to the TV but cannot get the past the auto scan screen
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
Posted on Feb 26, 2015
gopakumarg43
  • 74136 Answers
SOURCE: Auto scan issues??
The main system control memory IC fault. Check and replace it.
Before replace it, try a hard reset to this set. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Jan 20, 2016
I have a sanyo model dp55441, it powers up with no problem but when i hook it up to the cable and run auto scan it wont pick up any channels.(cable line is fine going into tv) also if i hook up my blu-ray...
sounds like the avi board and graphic control is not working they are usually on the same power line on the main board. can you try the menu setting see if they come up on there avi ext1 etc.
Sep 17, 2013 | Televison & Video
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
Lc329slx sylvania tv couldn't scan any chanel from cable
If you were using an antenna before make sure the set is now set to CATV or cable before trying to program the channels.
Jun 01, 2012 | Sylvania LC320SLX 32 in. LCD TV
The TV works however I cannot get the set to read the channels. I have cable but no cable box. Have tried to program it for over 3 hours. I've tried it using ch.3 and ch.4. through the remote. After I scan...
U used the tv remote go into ur tv SETUP.Pick Cable,before u scanning for cable chanels?U have pay cable?Must scan for cable chanels,by setup for looking for cable channels.
Mar 18, 2011 | Televison & Video
How to Chanel Scan
Tv is hook up to cable tv or free DTV air broadcasting?Have a good antenna source hook up or cable or satellite signals.Go into the tv menu go to SETUP.Go down to CH. press enter pick Cable or Air.Enter for scanning,after it done scanning will get all free DTV air or cable broadcasting channels stations signals.
Feb 08, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Same problem
try running the auto programing feature see if tha clears it up
Jun 21, 2009 | Samsung HL-R6167W 61" HDTV
I cannot find the code for my (ilo) brand TV from Wal-Mart and after the scan the scanner does not pick up on a channel I know is there. My friend has the working channel on his digital TV, but it...
try the Funai codes look on the back of your tv and see if Funai made it if so try ther codes. My Magnavox converter box wont pick up chanel 10 here for some reasion says no signal.works ok on all of the other chanels. Now if you have the orginal remote you should be able to go into the menu and go to add/delet and add that chanel to the scan if it has been deleted for some reasion.
Feb 21, 2009 | Televison & Video
Hdmi
The HDMI lead only carries the video and audio from the HTS6510/05 to the TV.
The scart carries audio and video both ways.
Re-connect the scart lead and all will be ok.
N.B. When the HTS6510 is switched on, the TV will auto-switch to the scart input. You will then need to switch the TV to HDMI to get the benefit from the DVD upscaling.
Feb 02, 2008 | Philips HTS-6500/37 System
CCVG297 broksonic 9" TV
When the channels show up in red thats an indication that they are not programmed into the TV set. Your going to need the original remote, go into the menu and then press auto scan with an attenna attached to the set. If it wont scan then you have a bad microprocessor
Sep 25, 2006 | Broksonic CCVG297 9 in. TV/DVD Combo
Element ELCFW329 32 Class LCD HDTV - 720p, 60Hz, 3x HDMI - ELCFW329 R Logo
21 people viewed this question
Top Element Computers & Internet Experts
Andrew Taylor
Andrew Taylor
richie46
Are you an Element Computer and Internet Expert? Answer questions, earn points and help others
